Hello everyone. This is my freshman year of high school and at my high school there are these silver grill plates on the walls. Typically next to fire alarms, and in the older areas of the building. My school also has fire alarm signs hanging from the ceiling that are from the 50s. Anyone know what alarms might be behind the grills or what it is. Thanks.
Here are my theories:
I’ve seen large grilles like the one in the first picture. They could have bells or horns, and in some cases, both. There are other components in your school (i.e., pull stations, detectors, panel, older/disconnected devices) that could give clues as to what the original system was. Even old clock systems are sometimes indicative of the brand of an old alarm system (i.e., Simplex, Edwards, Standard Electric). Do you know of any other schools in your area with similar setups like the ones at your school, or what brands they use or have used? Sometimes, old hardware could still be concealed behind those grilles, but you may not want to arouse suspicion in case of surveillance cameras or anybody nearby.
I’m betting those fire alarm signs are insights into one or two things: Your school may have had a manual pull-rod system tied in to the electronic alarm system, or those signs may serve as indicators of a pull station underneath. It’s also possible there could be a wall scar or metal plate instead, indicating that there was an old pull station. If a wall scar is round, for example, there may have been a Standard Electric pull station there at one time.
Although they’re not always the best quality, old pictures from your school’s archived yearbooks are also great clues. You may be able to find them at your local library.
Considering the Adaptabel on the left, I would guess your school originally had an Edwards fire alarm system with flush-mount Adaptahorns. The rectangular metal plate between the bell and square plate may have been the place of a clock or public address speaker.
Reminds me of the grills at the college I attended. The system used to be a very old Edwards system in the original wing, which had these grills with Unelco 4" bells for class change, and then the 6" Edwards 24 single stroke bells.
Here’s an example of a late 60s high school that used to have an old Edwards system. The plate is where the 10" single stroke bells used to be. I think there was a surface mount bell or horn next to the school bell, and then a clock system. Here is a picture of a typical IBM box, looks about the same size.
If you can ask your school if ou can get your hands on a “FIRE ALARM” sign I might buy it from you
No, my school wouldn’t. People have already asked
At my college, they have Simplex bells behind grilles. Under or next to them, they have Simplex or Federal Signal Speaker Strobes. In the dorms, they don’t have any grilled bells. But, they do have EST Integrity horns as well as Federal Signal Speaker Strobes.
