I'll go first showing off some of my Alertek panel products.
Current Alertek panel products
MFP-4 ("Modular Fire Panel" Version 4) -- This panel is an expandable panel, starts with 1 zone all the way up to as many as you can fit in the building. Each zone is able to automatically detect fires or be manually actuated by a push station. It has two add-on modules available, the MFP-4Z, which is a zone coder module (one NAC for each zone coded independently), and the MFP-4V (adds voice evacuation)
Installations so far: 6
Alertek Modular V.1 (Not to be confused with the MFP series) -- This panel is an older panel. It has zone cards with two zones each, and NAC cards where you can disable the NAC. It also has voice evacuation which works by using a trick with a resource pack to play custom sound files in the game. It also has walk test.
This product line will soon be replaced with a new series code-named "Revolution" which will change the way fire alarms are done in Minecraft.
Installations so far: 2
Alertek 8000 -- very large experimental panel that has some interesting features.
Installations so far: 1
Alertek AutoLite II -- Very tiny 1-zone panel with an automatic fire detector meant for small single-story buildings only.
(No image)
Installations so far: 3
Discontinued Alertek panel products:
My oldest Alertek panel, the "MiniMaxi" (minimal space required, maximal functionality) which would be the equivalent of a 70s system in real life.
And here's some devices on that system. A push station and a horn/light.
Installations made: 2
Alertek MiniModular -- a fairly successful panel for small to medium sized buildings. Does voice evac in a method similar to the Modular panel (above). Replaced with the MFP-4 panel.
Alertek NanoModular -- a successful attempt at making a ridiculously tiny panel. Replaced with the MFP-4 in order to have an automatic fire detector.
Installations made: 4
Alertek MiniMaxi II Addressable FACP -- another experimental panel. This panel's design was scrapped though. When you pressed a button it, it displayed a list of alarmed devices in the nearest player's chat window.
Installations made: 1
Alertek AutoLite -- Same as the AutoLite II except used a hopper clock as its timer circuit. Was recalled after a duplication bug developed in one of the development versions before Minecraft 1.8, which caused the fire detectors to fail. Every AutoLite system installed was replaced with an AutoLite II.
Installations made: 3
(No image)
Alertek Lite -- Very tiny 1-zone panel meant for small single-story buildings only. Replaced by the AutoLite, then by the AutoLite II.
(No image)
Installations made: 6
Alertek FireSentinel -- Very unreliable minecart based fire detector. Used before 1.8 introduced the fill command. Due to its huge size, loudness (from a minecart moving around) and potential to fail at random, it was only installed once.
(No image)
Minetech panel products:
Minetech M-FA Mk.1 -- This is the last panel on the server to be entirely hardwired -- no command blocks anywhere. It still works too.
Minetech Maxalert 3000 -- This is in a large indoor mall. It's one of the largest panels on the server -- it has 46 NACs and about 50 zones. Yes you read that right, 46 NACs. Every store in this mall has its own NAC for selective testing store-by-store.
Minetech MFA-W-10 -- Looks almost identical to the MFP-4. Predecessor to that panel, did not have an automatic fire detector.
(No image)
