What sort of devices do you have in your personal collection that you’ve never seen in use in a public building?
Off the top of my head, I can only think of two in my collection, the older (1970s-80s) version of the Honeywell S464 and my EST Genesis speaker/strobe with the blue strobe. I’m sure I have a few others too.
The Gentex GOS (the multi-tone version of the SHG – otherwise known as the predecessor of the Commander2/3/4), the Simplex 4903-9102 light plate, and, oddly enough, the Wheelock RSSP strobe plate.
Alarms I could have included on this list would have been the Wheelock 34T horn and the Simplex 4901-9822 horn. The former is from a rather small Chinese restaurant close to my house (and it’s mounted on the ceiling). (My parents are usually the ones – usually not together – that order food from there, but this was after I got a haircut one time.) The latter was found in one section of the mall near where I live, which I didn’t even know they were there until I actually heard them go off for a test (I recognized that it was the sound of a fire alarm, but I didn’t know what that really was, until I looked for any fire alarms in that area of the mall).
[size=50]If anyone recognizes the buildings I just mentioned, please don’t mention them publicly.[/size]
System Sensor L-Series (Compact Version)
Amber strobe devices (SpectrAlert Advance/ Genesis)
System Sensor Low Frequency Sounders
Simplex Mechanical Horns
Kidde B5 pull stations
SpectrAlert Classic Chime/Strobes
Siemens/Faraday UMM-Ts
Amseco motor horn/strobe
Wheelock AES-EL1-WS-24
Mine would be:
Chubb I-Scan O-IV (I’ve seen other versions of the I-Scan series but not this one)
Legrand MCP varient (I’ve only seen a varient that has “ALARME INCENDIE – APPUYEZ ICI EN CAS DE NÉCESSITE” lettering on the membrane, while mine has a blank membrane)
Ademco 623-12 (including 622 same as the 623 minus the heat sensor): Never encountered these at all.
Edwards Heat Detector (only found in USA/Canada): Quite obvious
SAFT Optimo 60 (Exit sign minus the EXIT sticker) : Too old, this model is known to have its non replacable NiCD batteries leaking and the plastic shell cracking away, hence its rarity.
Let’s see:
- Simplex 4080 10" bell
- Faraday 10123-1
- System Sensor RP2415/75ADA
- Space Age V-33 strobe (newer, 110 Cd)
- Federal Signal 450 A1 (gray)
- SpectrAlert Advance CHR
- SpectrAlert Advance HW
- Gentex GEH24-R
- Gentex GX93-R
- I’ve probably seen an EHS-EL1 at some point
- I have the rusty cover to a circular Standard Electric pull station
- I don’t think I’ve seen a white Integrity horn/strobe
That’s interesting… the gray 450, GEH24-R, and GX93-R are all pretty surprising to me, since I’d consider those to all be fairly common devices.
System Sensor MHW or FCI MS-2
For me it would have to be a red Wheelock WST-24 strobe.
That’s really surprising actually.
I don’t think I’ve ever seen a GX-90S with the newer clear strobe anywhere. I’ve seen the older versions and the remote horns, but never the horn-strobe versions.
Also, the MA. Never seen one without an SS strobe.
I’ve only seen GX-90s that were remote horn and never had a strobe on them.
System Sensor i3 2WTA-B
System Sensor 2300TB
System Sensor CH241575
System Sensor RRS-MOD
Wheelock HSPW-24-HFR
Wheelock RSSPA-24MCC
Notifier BNG-1RS
Potter SH-1224
I’m excluding security equipment.
My Norelco smoke detector that used to hang on a ceiling in our current home is the only device I haven’t seen in a public building.
Wheelock MT-24-IS-CFW, Edwards 884, System Sensor PC2WL, Radionics D571S, Simolex 59AV-WRF, Simplex 4901-9817, and Cerberus Pyrotronics EC-S17-S.
I’ve seen most of the devices in my collection out in the field at some point, with the major outliers being the panels I own, since they are usually locked away in electrical closets somewhere:
- Simplex 4007ES
- Fenwal 3220
- Siemens SXL-EX
- Potter Electric Signal ZIP
- Siemens / Cerberus Pyrotronics System 3
As for my Ansul AutoPulse 2000, DMP XR-500, and FCI FC-72 panels, the only time I’ve seen them in a building was moments before I removed them :lol:
As for initiation and notification devices, I don’t remember coming across any of these in public:
- Simplex 4048R Horn
- Honeywell Q43-3A3CK1 Horn
- Gamewell M-69 Pull Station
- Notifier NWS-24 Strobe
- Pyrotronics MFS-2 Pull Station
- Faraday F625T Pull Station
I don’t have a collection but I have never seen a Simplex 4041 in person before.
I have no collection however I have never seen a bluepoint police alarm or medical alarm installed in a building. I think most people here have never seen such.
I have never seen a Gentex SHG.
These are all ones I’ve never seen in-person, I have seen some installed in pictures online:
Simplex local T-Bar 4251-21L, Edwards Adaptabel 435-6P1, Edwards Adaptabel 340 (just the version I own with the green and white label), Edwards Adaptabel W326, Edwards Adaptahorn 372, Federal Signal model 53, Faraday model 161 bell, Vulcan Autosonic Mk. 30-A
As for residential smoke detectors I own; Jameson Code One CD-1, Honeywell TC89B, Honeywell CD200A, Sears/Nalcor 246.57474, Vulcan Autosonic Mk.SRO-4, GE Home Sentry 8201-201, GE Home Sentry 8202-201, Gillette 941, Gillette 929, Fyrnetics Lifesaver 0908, Statitrol 907A2
Another alarm I’ve seen online is the GMS but I have never saw it in person.
Another few devices I’ve never spotted in public buildings:
Luminox STD 65-CES (IP 66 Waterproof version of the Luminox STD 65, for those who don’t know what the Luminox STD 65 is, it’s technically an exit sign with built-in emergency lights): I’ve never seen one.
Neutronic MCP (unknown model #): Quite common but in my area most MCPs I’ve found were eithier Nugelec, AVISS Security/DEF/Fare or Legrand.
