hi have 2 options to help you with the Password
sent you DM
Regards
sent you DM
Regards
Hi, I’ve got an ‘07 7100 running on V7.1-001, I was wondering if there was a backdoor on it as I’m trying to default the panel. Thanks
Hello all, also looking for a backdoor password for 7100 running V7.2-024. Have a building we are doing a buildout in and previous installing companies did not have the codes and management has changed several times. Any help would be appreciated.
hi
sent you a direct message with an option to your problem
regards
Can you DM me options for accessing Level 4 on a FCI-7100 Ver 6.3-011
Hey I’m having a similar issue where we took over an account and they did not leave us with the password if you could pm that over that would be fantastic
Did you end up getting the passcode?
Hey I also need some help with this
Hi sent you DM
unfortunately the 7100 dont have an easy backdoor
Hello i need loopexplorer
Hello! Needing assistance with a backdoor entry to access level 4. Default code is not working
FLEX 600 Series
RAN2
Part no. 71905
We have several of these panels that have been locked out of, ILI-MB-E3. Any chance you have a tool to get into them? Thank you in advance.
Will need this code as well. Got one from a building, replaced with notifier. 444444 does not work
What about panels that a previous installer (no longer in business) disabled any panel editing? Right password or not, if I try to access the config menu, I get an error that config is disabled because panel was FCP programmed.
I’m willing to wipe this thing clean and reprogram the whole system. Hours of programming is still gonna be cheaper than replacing the entire panel and all the devices.
hi, if the panel is v7 firmware or up can be programmed with CAMWorks soft, either way, level 4 must be known, if you need help retrieving the level 4 password send a DM
Doesn’t appear that I can DM you… I have a version V7.1-001
yeah seems that the forum has changed some things, now the option is the chat but needs to be enabled on settings
Ah.
So how can I get this passcode
Thanks
Noticed you may have solution to gain level 4 for 7100
this was installed in 2021 at a school and cannot locate installer.
looking for solution besides new chip set. thanks
Hi, I’m looking to add some devices to a Gamewell 7100 for a remodel. It’s running on software version 7.1. The panel was installed by a previous contractor, and we don’t have access to the Level 4 password. Tried the default, and no luck. Any help would be appreciated!
