Unity Lutheran Church (Southgate, MI) - My visit for a rummage sale was limited to the main lobby and fellowship hall, but to my luck, an education program in another wing had an online virtual tour, which helped me identify the detectors by chance (thanks TheCarson116 and VintageCollections). This system has a unique variety of devices!
Annunciators/panel:
<Unknown
Detectors:
<Fenwal CPD-7021 ionization units (with unknown bases) in the classrooms.
Pull stations:
<EPC 275 models, which are rebranded Mirtone 73303U units.
Notification appliances:
<The flush-plate version of the Faraday 6120-5511 horn/strobes; at least the one in the main lobby has a conduit box mounted on a gray Faraday/Simplex/Setco flush plate, giving a hint as to the original system!
It’s similar to what happened to that one 7000T- oops I mean 7002T that I spotted, which is obviously more weathered and stuck in a wall.
It might be connected to the security system, looks like one of the smokes is a DSC smoke alarm. It could have replaced something because I doubt 7002T would have been used
That poor 7002T. It’s just there, stuck in the wall.
What was it? Its deleted.
Delta Hotels Daytona Beach Oceanfront - Daytona Beach Shores, FL
A very basic hotel system.
Panel: FireLite Addressable Panel (Either an MS-9200UDLS or MS-9600UDLS)
Common Areas/Corridors
Pulls: BG-12LX’s
Detectors: SD355s
AVs: L-Series horn/strobes and strobes
Units
Detectors: Kidde i12040 residential smoke alarms
AVs: Advance series low frequency sounders
ADA Units
Detectors: Gentex hearing impaired smoke alarms
AVs: Advance series low frequency sounder/strobes
Daytona Grande Resort - Daytona Beach, FL
A massive Simplex system, which is very uncommon in the area
Panel: 4100ES
Pulls: 4099-9006’s
Detectors: TrueAlarms
AVs:
Indoor: TrueAlertES speaker/strobes, strobes, and speakers (both wall mount and ceiling mount)
Outdoor: A mix of TrueAlertES speaker/strobes and Wheelock ET70WPs and weatherproof Eluxas
Units
Detectors: TrueAlarms (Not on sounder bases oddly enough. The one in the room I stayed in wasn’t polling either which I found odd)
AVs: TrueAlertES speakers
Here are some fire alarm devices in a public high school. This system is an EST addressable system (haven’t seen the annunciator yet so I don’t know exactly what panel the system could have), and some devices include 270 pull stations, Genesis strobes, SIGA smoke detectors, and Wheelock MB-G6-24 bells. (There is also a vintage IBM class change bell in one of the pictures).
Here is the annunciator, so therefore the fire alarm panel is an EST3.
Some Alarms on a Recent Trip:
I went on a short road trip this past weekend to Rapid City, South Dakota for someone’s wedding. We only went to four places that had fire alarm devices, but I took photos at all of them. One thing I did notice in Rapid City is that Siemens appears to have just as much (if not more) of a “monopoly” on the market than in my area.
Holiday Inn Express & Suites- Rapid City, SD (Rushmore South location):
This hotel was opened in 2019. It has 4 floors, and is a pretty typical Holiday Inn location. This hotel has a Siemens Cerberus PRO Compact system with Z-series notification appliances, and just one MSM-K pull station near the annunciator at the front desk (likely connected to a monitor module). For detection, they have Siemens mostly OP921 smoke detectorss, but the breakfast area has an HI921 heat detector, and the seating area directly outside of the breakfast area has an OOH941 multi-criteria smoke/heat detector (to avoid false alarms from cooking). Oddly, this hotel uses several Kidde residential hardwired CO detectors placed in key areas (such as the kitchen and pool area) for CO protection. As for the rooms, they have an equally odd setup. They have typical Kidde residential smoke alarms for local fire protection, but they actually used Gentex low frequency sounders for whatever reason. My only thought would be that maybe Siemens hadn’t yet released their LF sounders, but I have no idea how they are handling the synchronization (or if they are at all).
Here are some photos:
Walmart Supercenter (Stumer Road Location)- Rapid City, SD:
This Walmart location has a very new Bosch system with new System Sensor LED L-Series devices. Unfortunately, based on the fact that this Walmart was built in the early 2010, this system likely replaced a Wheelock SAFEPATH system. Other than the horn/strobes, the only components I saw were a few annunciators, and a pull station.
Cathedral of Our Lady of Perpetual Help Church- Rapid City, SD:
The main building of this church is very old, and has no fire protection whatsoever. The main entrance/ballroom was opened in 2024, and that has a Potter system. It has the typical rebranded Gentex notification appliances, but I didn’t see any smoke detectors or pull stations. The new area is sprinklered, though, and the system is also likely monitoring the kitchen hood Ansul system. There’s also likely a PAD300-PD or PC-2P smoke detector (depending on whether it’s an addressable or conventional system) above the panel.
In this next photo, you can see that there was supposed to be a wall mounted device, but the projector screen would have blocked it when it came down, so they changed to a ceiling mounted device. I’m glad they actually did all the right things in this case!
Culver’s (Mt. Rushmore Road Location)- Rapid City, SD:
This location has a pretty basic Siemens system from the mid 2010s. I didn’t see any components of the system at all, other than the notification appliances (not even an annunciator!). It is a modern sprinklered building, so I’m not too surprised, but I’m not sure why there was no annunciator. The notification appliances are Siemens ZH-MC-R horn/strobes, and ZR-MC-R remote strobes.
Here’s a photo I took:
Quite bizarre if you ask me that a single place would have both horn/strobes & bells like that (with the latter mounted on the ceiling of all places no less. Odd how the school bells are also mounted there (was there no wall space for either of them?). Interesting combination of old & new EST logo 270-SPOs though.
Interesting mix of Wheelock bells and Genesis on an EST system.
Its official, i dont have any more fire alarm pictures to show, yay…
Unknown Faraday panel (decommissioned)
Montgomery MFG Co. time system (decommissioned)
Golden Age Services Senior Center- Mandan, ND
This building appears to have been built at some point in the 80s. It originally had a Simplex system (likely a 2001 repack or 4001) with 2903 horn/light or horn/strobe combos, and the “whiffle ball” style smoke detectors. That old system was replaced somewhere around 5-7 years ago.
Current System:
Panel: Likely a Fire-Lite ES- series panel
Notification Appliances: System Sensor P2RL horn/strobes mounted on 2903 back-box adapter plates
Pull Stations: Fire-Lite BG-12LX addressable pull stations
Detectors & Other Initiating Devices: Fire-Lite SD365 smoke detectors, and H365 heat detectors. The kitchen Ansul system is also likely connected to the system. The building is not sprinklered, so there are a lot of detectors.
Other Notes:
This system is likely one of the newest Fire-Lite systems in my area. They were extremely common in the 2000s and 2010s, but they sort of disappeared for new systems in my area after that. Since then, the only Honeywell systems I’ve seen have been a few GW-FCI and Silent Knight systems, as well as a Johnson Controls IFC2-3030 system’s CPU getting changed over to a Notifier NFS2-3030.
Major Update:
This past Thursday (5/21/26) was the last ever day of school for this building. However, there is some very good news: the building won’t be getting demolished! Instead, it will be a replacement for the local senior center. The building will be remodeled, and it will be repurposed to provide assistance, socialization, and activities for senior citizens in the community. Considering that the fire alarm, intercom, internet/wifi, and security camera systems in this building have all been fully replaced and upgraded within the past 10 years, it’s crazy to see that all go, but I’m very happy that this building is going to have a good purpose, and will not be demolished.
Here’s a horn/strobe I saw in the background of one of their “last day” celebration photos:
This device is one of the many TrueAlertES horn/strobes that can be found on the system. This device is in the gymnasium, and is located directly behind the basketball hoop, but it has no cage. This is how it was done when they upgraded several of the 1960s elementary schools in my district to 4007ES systems. Surprisingly, none of them have been damaged yet.
EST3 system at a hotel
Anaheim Convention Center
Been to this place before (for milball), was constructing volleyball courts for a volunteer fundraiser. Got a somewhat wider look at the system
Cool exit sign posted above an entrance leading outdoors
Dual action Simplex T-Bar. There were single-action variants of these elsewhere
The highlight of the trip: some sort of N/A that has a dual projector horn (FS PR2?) attached to it. There was a similar N/A with a dupro horn on the other side of the beam too, in better shape. Considering the entire place had Wheelock E70-Rs everywhere, I’m betting that the N/As were 70-Rs too (visual notification was handled by RSS remote strobes in this section of the building; regular E70 speaker/strobes covered the rest of the building) Funny thing is, the N/A the horn was attached to was white, so it would’ve been an E70-W.
Didn’t get any smokes on here, but there were a few
Sorry. I am catching up after being away from the forums for a few months. Anyway, that horn next to the phone is a Wheelock ringer
Oh cool! Are they rare or uncommon?
