Here’s a looot of stores I went to this weekend.
The new Aldi renovation near my house has a Fire-Lite Endurance 50X system with 6 ceiling mounted System Sensor L-Series alarms in the shopping area in a checker pattern with 3 being horn/strobes and 3 being strobes. In the cold area there are SpectrAlert Advance horn/strobes or strobes. The store also has 2 System Sensor carbon monoxide alarms and a Honeywell siren by the entrance door. The bathroom corridor + the bathroom themselves have remote strobes. The only pull is a Fire-Lite BG-12. (The original alarms before the renovation were SpectrAlert Classics and BG-10s)
La Salsa (originally Sunrise) has white ceiling System Sensor L-Series horn/strobes. There are no visable pull stations or annunciator, and the smoke detectors are old (Pyrotronics?) smoke detectors. There was no original system, so some of those detectors could have been smoke alarms. Outside, there is a SpectrAlert Advance weatherproof strobe with a non-ADA MASS strobe (theres one outside each door on the plaza. That tells you how old the place is and how overdue the system was.
Toy’s R Us in Vernon Hills has a VERY OLD Gamewell System with Simplex 2901-9838 horns on 4903-9101 strobe plates, TWO on each thin piller! Some of the -9838 horns are turned 90°. Pulls are Gamewell Centuries.
Petco in the same area has a dated Radionics system with lots of System Sensor SpectrAlert horn/strobes. Pulls are BG-12s rebranded by A.D.T.
A brand new gigantic Menards has a Fire-Lite Endurance 200X system with System Sensor L-Series horn/strobes and strobes. Pulls are all Fire-Lite BG-12s.
A Target in Mundelien has a mid-point Radionics system with white SpectrAlert ceiling horn/strobes and remote strobes and Radionics T-Bars. It’s under renovation right now, so it could become a modern Fire-Lite system.
Home Depot - Waltham, MA
ORIGINAL SYSTEM (before ~2014)
Panel: EST IRC-3 (the panel was located at the entrance)
Pull stations: SIGA-278’s
Signals: Wheelock AS horn/strobes and RSS strobes (all ceiling mount)
CURRENT SYSTEM
Panel: Some sort of Silent Knight system, judging by the annunciator at the entrance.
Pull stations: SD500-PS’s
Signals: SpectrAlert Advance horn/strobes and strobes. (also ceiling mount)
I have NO idea why this “upgrade” happened. :x
Menards | Waite Park, Minnesota | Built in: 1990s
Actual Store:
Fire-Lite BG-12 “classic” Pull Stations
Classic SpectrAlerts (wall-mount on the ceiling :roll: )
Garden Center:
Wheelock MTWP (post-2003 version)
Simplex 2099 Pull Stations
Exterior:
Wheelock 7002T Horn/Strobe
No smoke or heat detectors as far as I can tell.
[quote="Chase Reinhardt" post_id=78136 time=1515013465 user_id=3744]
CF Market Mall has an EST3 system (saw the annunciator), with EST 757-5A-TW (white) horn/strobes and 757-1A-TW (white) horns in the hallways, mounted on the ceiling, with the FIRE lettering vertically. In the stores, there are EST 757-5A-T (red) horn/strobes mounted either on the ceiling or the wall. The Toys ‘R’ Us in there has Edwards 882-2B horns instead of Integrity horn/strobes, possibly from the 1988 renovation. The Safeway in there has an Integrity horn/strobe in the passage to it, but the main horn/strobes in there are System Sensor SpectrAlert P1224MC, There are also white-painted Edwards flush-mounted Adaptahorns everywhere, not sure if its part of it or not. Pulls are Edwards 270-GAO (not two-stage setup tho) in the main mall, and Grinnell-rebranded Notifier MPS-950B in the Safeway. The strobes are synchronized, but not the horns, and they do code-3
I was here again, and there ARE outdoor signals, although they are hardly noticeable. On one side of the mall, there’s an EST 757-1A-T horn beside a sprinkler bell, and in some sheltered outdoor areas, there are EST 757-7A-T horn/strobes, a few other sides have EST 405-7A-T strobes. The Safeway’s entrance has a System Sensor P1224MCK horn/strobe. All Integrities (indoors and outdoors) are 15/75cd. Some EST 757-7A-TW horn/strobes are in the stores, most on ceiling but some on walls. Smokes are EST (GE) SIGA-PS, and some pulls are EST SIGA-270P (older EST logo). the system is also programmed for audible silence. The EST 3 was added in the 2004 renovation.
[quote=randomperson post_id=80334 time=1525555373 user_id=3878] [quote=randomperson post_id=77672 time=1512080370 user_id=3878]
40 Second Avenue - Waltham, MA
Pull Stations: Notifier NBG-10L’s (and a Fire-Lite BG-12)
Detectors: System Sensor 2400’s
Signals: Wheelock EH-EL1-WM-24 and AS horn/strobes
I was here again, and saw the panel, a Notifier System 5000 with several troubles on it. (probably due to construction on the 3rd floor)
I was here once again, and the construction is done and the troubles are gone! :smiley:
I assume that no fire alarms were replaced or put in due to the construction?
[quote="Simplex 4051" post_id=80666 time=1527886035 user_id=18]
I have no idea, I was not in the area that was redone (if they did replace any signals, they probably used Wheelock Exceders.)
Best Western Hotel in Mesa:
Panel: Simplex 4002:
Alarms: Simplex 2901-9833 with Strobe Plate (unknown if it’s a 2903-9001 (light) or 2903-9101 (strobe)) + Simplex 4251-20:
Smoke Detector: Simplex 2098-9636?:
The alarms are set on continuous :shock:. I know because the alarms were accidentally tripped when I was at the hotel. Eeeek.
BMO Bank of Montreal (in the same building with the Smashburger and Sobeys Liquor previously mentioned, the building probably has an EST QuickStart) in Royal Oak, has EST G1R-HDVM horn/strobes. Pulls are EST SIGA-270, smokes are all SIGA-PS.
Canadian Tire in Airdrie has a Notifier ONYX system (panel at service entrance, unknown model #), with System Sensor SpectrAlert P1224MC horn/strobes. Pulls are Notifier NBG-12LX.
Barbecues Galore in NE Calgary has an unknown system, possibly Edwards, with an Edwards 439D-10AWC bell. The only pull i saw was a classic Edwards 270-SPO, without the words “FIRE ALARM” at the top.
Here’s an interesting system at another, older high school in my school district. The school was built in 1918, and had several additions throughout the 1920s, 30s, and 40s, and the addition of a second auxiliary building behind the school in the 1950s (which unfortunately I’ve never been in), PLUS a major addition and renovation in 1975. Phew… this school has been through a lot, but it’s scheduled to be replaced in 2019, and what will happen to the old campus is unknown. In any case, y’all only care about the fire alarms, so I’ll go ahead and share this wacky system. Obviously, as I mentioned above, I’ve only ever been inside of the main building on the campus so I have no idea if the auxiliary building has the same system or not. The panel is (allegedly, according to the fire alarm inspection records) a Simplex 4020. Bizarrely enough, the pull stations are all Edwards 270-SPOs, and the smoke detectors are a mixture of Edwards SIGAs and Simplex TrueAlarms. Of course, because we can’t have any consistency, the notification appliances are mostly Gentex SHG-series horn/strobes, mixed with the standard medley of newer Wheelock devices that you get with every school in my district. I’m pretty sure there are a few Edwards Genesi somewhere in the school too, but I didn’t see any the last time I was there. The older Gentex devices are all coded to continuous, but the newer devices are all coded to temporal.
Sort of unrelated, but ironically enough one of the things that this school is known for is having five different bell tones depending upon which wing, building, or floor you’re on. Some areas (like the gymnasium) still have mechanical Simplex bells from the 1970s, while some areas (like floors 2 and 3 of the original building) still have the original 1950s Faraday chimes. Other areas just have a tone over the PA (which also varies), and I’m pretty sure the industrial arts wing has some mechanical horns that are still in use.
Boston Common parking garage - Boston, MA
Pull stations: EST SIGA-278’s
Detectors: SIGA2’s in some areas
Signals Genesis speaker/strobes
Finally the website’s back up!
Portillos in Vernon Hills has a semi-old Fire-Lite system. There were two Gentex SHG horn/strobes, SpectrAlert wall-mounted strobes on the ceiling, one SpectrAlert Advance ceiling mount strobe, and a few wall mounted horn/strobes. Pulls were either Fire-Lite BG-10s or BG-12s, didn’t see.
Banff Gondola (main building) has a Notifier NFS2-640C system (installed around 2015-2018, replacing an EST 6616) with two Edwards 439D-6AWC bells on EST 403-5A-R strobe plates. Near an exit, there is an Edwards MB6-24 bell. On one pole, there is one of the two Edwards bell/strobe combos mentioned above, and the other side has an EST 202-5A-T strobe. The gondola boarding area has an Edwards 439D-10AWC bell with an EST 202-5A-T strobe beside it. Pulls are Edwards 270-SPO, heat detectors are Edwards 280B-PL, smokes are Edwards EDW1451A/EDW2151A (aka “doorknob” smokes). The components are all from the original system.
Banff Gondola Upper Terminal has a Notifier NFS2-3030C system, with mainly Wheelock HSWC horn/strobes and Wheelock HNWC horns (first time I’ve saw Wheelock Exceders)! There are a few Wheelock STWC strobes in the building. Some areas have Wheelock HSW horn/strobes. The stairways have Wheelock HNW horns. The gondola area has System Sensor P2R and P2RK horn/strobes. Outside, on the 4th floor balconies (and possibly the others) have Wheelock HSR horn/strobes and Wheelock HNR horns. Pulls are Notifier NBG-12LX (all had flashing green). Smokes are System Sensor 2151, and some have sounders.
Miette Hot Springs has an EST QuickStart (older one), with mainly Edwards 439D-6AWC bells. One is installed upside down. In the pool area outdoors, there is a Notifier KMS-10-24A bell. Pulls are mainly Mircom MS-401, but there was an Edwards 270-SPOB (bilingual) by a staff room. Smokes are Edwards EDW1451A/EDW2151A and one System Sensor i3, heats are Edwards 280B-PL.
Jasper Brewing Company has a Simplex 4010 system, with Simplex 4906-9127 horn/strobes. Pulls are Simplex 4099-9001.
Bearspaw School has an EST QuickStart system, with EST G1R-HDVM horn/strobes. There is a Mircom BL-6B outside, possibly disconnected. Pulls are EST SIGA-270, smokes are EST SIGA-PS
Winners in Beacon Hill has an EST (GE) QuickStart system, with EST G1R-HDVM horn/strobes. Pulls are EST SIGA-270, smokes are EST SIGA-PS.
Northland Village Mall has a Siemens system (possibly a FireFinder XLS), with mainly Siemens U-MMT multi-tone/strobes (some with FIRE lettering on sides, some on the front with bilingual letterings) The Walmart there has ceiling mount U-MMT’s on the walls. There are some Siemens-rebranded bilingual Wheelock MT-24MCW multi-tone/strobes, possibly a replacement. There are possibly different signals replacing U-MMTs, I’ll get into that in another post. Pulls are Siemens HMS-2S (bilingual)
A FedEx, a Subway, and the rest of the stores in a mini-plaza in Mundelien have a Wheelock NS horn/strobe by the door and a Grinnell RMS-1T T-Bar under. Nothing else.
[quote="Chase Reinhardt" post_id=79495 time=1520822822 user_id=3744]
Best Buy in Beacon Hill has a Simplex 4010 system, with Simplex 4906-9127 horn/strobes. Pulls are all 4099-9001.
Update: I was here again, the system has been replaced with a Simplex 4007ES Hybrid, and all the devices remain intact. This store is in a medium-sized plaza.
[quote="Chase Reinhardt" post_id=80870 time=1529888846 user_id=3744] [quote="Chase Reinhardt" post_id=79495 time=1520822822 user_id=3744]
I was here yet again, the plaza’s outdoor signals are System Sensor P2RK horn/strobes.
A small plaza near Royal Oak (which has the Planet Organic and Jerusalem Shawarma previously mentioned, and a liquor store and a floral shop), has a Notifier NFS-320C (panel in Planet Organic) system, with System Sensor P2R/P4R horn/strobes, set to 30cd and 15cd. Outside the Planet Organic, there is a System Sensor SRK strobe. Pulls are Notifier NBG-12LX, smokes are System Sensor 2151.
Boston Logan International Airport - Terminal C - Boston, MA
Panel: Simplex 4120, located in the Fire Command Center near the Alaska Airlines baggage service office.
Pull stations: 2099-9795’s in older areas, 4099-9003’s in newer areas, 4099-9006’s in the newest areas.
Detectors: Newer and older TrueAlarms in some areas.
Signals: 4903 speaker/strobes and 4902 speakers in older areas. TrueAlert speaker/strobes (both wall and ceiling) and remote speakers in newer areas. The check-in hall has a few Wheelock E70 speaker/strobes. There’s also at least one Wheelock ET-1010 speaker outside.
Minneapolis St. Paul International Airport - Terminal 2 - Fort Snelling Unorganized Territory, MN
Panel: Honeywell XLS1000 (rebranded EST3)
I saw an annunciator, and it was displaying multiple troubles. No surprise, it’s EST.
Pull stations: Honeywell S464G1007’s (BG-12LX’s)
Detectors: System Sensor/Honeywell 2251’s (older and newer)
Signals: Wheelock 8-inch (S8) and E70 speaker/strobes in most areas.
Some areas (e.g. restrooms) use E90 speaker/strobes.
Some areas near the parking garage have AS horn/strobes. (left over from the previous system)
Loring Green West Condominiums - Minneapolis, MN
Panel: EST3, located in the front office.
Detectors: SIGA’s in common areas. (and at least one SIGA-PD)
SIGA2’s with sounder bases in individual units.
Signals: Genesis speaker/strobes in common areas, and remote speakers in stairwells, and remote strobes in some common areas.
Atlas/Soundolier “L31-70-A” speakers in individual units.
There is also an Integrity speaker/strobe outside, and an Integrity speaker in the greenhouse.
[quote="Chase Reinhardt" post_id=77961 time=1513653067 user_id=3744]
Brookfield Place has an EST voice-evac system, with mostly EST Genesis GC-S2 speakers high on the ceiling. One side of the hall has EST Genesis G1-VM strobes, but the other side has EST G4-S2 speakers. In the hall that leads to Scotia Centre and in the hallway that leads you to Bow Valley Square, have EST GC-S2VM speaker/strobes. Pulls are all EST GE SIGA-270, under Stoppers.
I was here again, there is an EST 757-1A-S25W speaker down a stairwell, the smokes are EST SIGA2-PS.
Stampede GrandStand Stadium has a Notifier ONYX-series system, with System Sensor P1224MC horn/strobes. Pulls are Notifier MPS-950B, and one Notifier N-MPS-series pull.
Erlton Stampede station has an EST system of some sort, with Edwards MB10-24 bells on EST 403-5A-R strobe plates. Pulls are EST SIGA-270, smokes are EST SIGA-PS.
