Redoing the ones I already did for these two schools from Disney’s Reccess.
Third Street School was built in 1928, and has gone through a few renovations over the years.
Panel
Notifier NFS-3030 w/ DVC, replacing a Notifier AM-2020 that replaced a Standard Electric Time Alarmatic that replaced the original SET UAX-3 (which was installed when the fire alarm system was automated in 1955)
Notifier NCA-2 Annunciator in Lobby, replacing a graphic annunciator
Cerberus Pyrotronics System 3 for elevator recall
Initiating Devices
The main pull stations used are Standard Electric Time 200117s. There are two Edwards 270-SPO, a Fire Lite BG-6, and a handful of Notifier NBG-12LX pulls that replaced broken 200117s. NBG-12LX pulls can also be found in the auditorium, gym, and the renovated Kindergarten & 1st Grade wing.
For smoke detectors, there is a mix of Statitrol, ESL, System Sensor (2400, i3), and Notifier (FSP) models. Most of the Standard Electric Time heat sensors are still intact, but there are a handful that have been replaced with Edwards 280 series and Notifier heat detectors. As for elevator recall, they use CP DI-3 smoke detectors.
Pull rods were previously used, but these were removed in 1972 when the new fire alarm system was installed.
Notification Appliances
The main signals used here are Standard Electric Time 450 horns on Light Plates. These signals can be found in the hallways, large rooms, media center, and cafeteria. There is a SAE 2DCD horn on an AV32 light plate in the basement, a FOS 6120+5511 in the media center, two Gentex GMS horn/strobes (one in the third grade hallway, another in the locker room), a P2R in the fifth grade hallway, and a Mircom Select-A-Horn/Strobe in the kitchen. Some restrooms have System Sensor P241575 strobes. Three classrooms have System Sensor P241575 horn/strobes. One light plate has a Federal Signal 450D horn, and another has an RSS strobe hooked up to where the light was. The auditorium and gymnasium have System Sensor SP2R1224MC speaker/strobes.
The kindergarten and first grade wing have Wheelock MT-24-VFR horn/strobes throughout (set to code-3 horn) with RSS strobes in the restrooms and storage closets. Outside that wing, there is a Wheelock ASWP horn/strobe (set to code-3).
Renovated classrooms also have Wheelock MT-24-VFR horn/strobes as well.
The original system used SET rebranded IBM 4030-2 horns, which were removed when the system had to be replaced in 1972.
Clocks/Bells/Intercom
The PA System is a Bogen Multicom 2000, replacing the original Stromberg System. The master clock panel is a Lathem LTR-512, replacing a SAL 3000 which replaced the original SET master clock panel.
For speakers, the hallways, media center, and cafeteria all use Bogen MB8TSQVR speakers. Classrooms, locker rooms, meeting rooms, and offices have Bogen ASM1 speakers. Classrooms also have Bogen CA10A call in-switches. Meeting rooms have AT10A volume controls. The auditorium and gym use Atlas Sound Megaphone speakers.
The renovated Kindergarten and First Grade wing have ceiling mounted Bogen CS1EZ speakers with classrooms and the art room have CA10A call in-switches.
Previously, the school used Lowell speakers throughout the campus, with classrooms having Standard Clock/Speaker combos.
As for clocks, there are Lathem digital clocks throughout the school, for the most part replacing the original analog Standard Electric Time clocks. There is a HUGE clock outside the school’s playground.
As for exterior bells, there are mostly Standard Electric Time 10-Inch Vibrating Bells. However, some were replaced with Faraday and Edwards 10-Inch Bells. There are two Wheelock MB10 bells that replaced two SET bells outside the K/1 wing. The internal bell is a 5-second tone over the intercom.
Prior to the installation of the SAL 3000, and eventually the Bogen Multicom 2000/Lathem LTR-512, the school had 6-inch Standard Electric Time Bells throughout the building, with one Edwards 6 inch bell.
98th Street school was built in 1928, was renovated and expanded in 1989, and has received a few minor renovations since.
Panel
Simplex 4100, replacing the IBM 4205-2 from 1955
Simplex 4602 annunciator in the foyer
Initiating Devices
The pull stations for the most part are Simplex 4521-20s, but a couple have been replaced with 4099-9002s. Smokes are a mix of older 2098 series and TrueAlarm smokes. A few Simplex rebranded ESL heat detectors and newer TrueAlarm heat detectors are present too.
The Kindergarten and 1st Grade wing has Simplex 4099-9003s and TrueAlarm smokes.
Originally, the school had IBM Chevrons (and a single 4521-20), pull rods, and IBM heat detectors (with two ESL smokes).
The main signals here are FOS 6120+5511 horn/strobes. These horn/strobes are installed in the classrooms, hallways, media center, cafeteria, and kitchen. There is a Simplex 4903-9217 in a hallway, two Wheelock NS horn/strobes set to code-3 (one of them is in a classroom), and a TrueAlert in the teacher’s lounge. Restrooms and areas requiring additional strobe coverage have FOS remote strobes. Outside, there are three FOS 6120+5511 horn/strobes, and one Wheelock MT-WM horn/strobe.
The auditorium and gymnasium have Simplex 2902 series speakers on 4903 strobe plates. One strobe plate has a Wheelock E50, and there is a TrueAlert speaker/strobe in the auditorium.
The kindergarten & 1st grade wing of the school has Simplex TrueAlert Horn/strobes and strobes.
The WHOLE system does continuous (the NSs do code-3), the speakers play the standard 4100 slow whoop tone and the message heard in https://www.youtube.com/watch?v=https://www.youtube.com/watch?v=OesgMec3sj4  (with the 4100 whoop tone instead of the hi-lo tone you hear in the video).
Originally, the system had IBM 4030-2 horns, along with one Simplex 4050 and two 7004Ts
The PA system is a Rauland Telecenter 21, replacing the original Stromberg system. The master clock panel is a Rauland 2524, replacing the original Edwards model.
For speakers, hallways, the cafeteria, auditorium, and gym have Rauland ACC1411 speakers. Individual classrooms, the media center, and offices have ceiling mounted AC1400 speakers. Classrooms also have Rauland TCSCS1 call-in switches. Outside, there are Rauland megaphone speakers. Originally, the school used Executone and Stromberg speakers throughout the building.
As for clocks, the school uses Rauland digital clocks throughout the building. These clocks replaced the original Edwards clocks of course.
The bell is a chime tone over the intercom. Prior to 1989, the school had Edwards chimes throughout the building (with one Simplex chime), and Edwards 10-Inch Bells outside.
