Make Up a System (2.0)
My former middle school probably had my favorite system of all the schools I’ve gone to.
The school was divided up into three areas, first, there was the original part from the 60s. This contained two wings of classrooms, a cafeteria (that was also being used as an auditorium at the time), a gym, and all the main offices. They had Simplex 4903-9236 horn/strobes in the hallways, science rooms, and one in the cafeteria, gym, and one in each of the locker rooms. There were Siemens U-MHU-MCS horn/strobes for all of the classrooms, as well as additional ones in the cafeteria, gym, and locker rooms. I do not know what the original system was, but I believe the new system was a Siemens MXL.
There was a newer wing that was added on to in the 80s. This addition included dozens of classrooms and a new auditorium. The original alarms were on 2903 light plates which were in various places throughout the hallways. The alarms in this area were entirely comprised of Siemens U-MHU-MCS horn/strobes, which were installed directly onto the 2903 light plates, and more were added in the classrooms.
The newest wing from the 2000s added even more classrooms and a second gym. This area had all Simplex TrueAlerts.
All of the initiating devices were Siemens throughout most of the building. In the newest wing, they had Simplex pull stations, but they still had Siemens detectors which was interesting.
I’ve been watching more of Disney’s “Recess” on Disney+, and with the new school year here and Halloween approaching the “Recess: Taking the Fifth Grade” direct-to-video movie that served as a finale for the series. So I’ve decided to come up with this…
Third Street School was built in 1951 as a K-6 elementary school. The original fire alarm system was an Autocall system, with the panel installed in an electrical room in the basement, set to Continuous. The alarm signals throughout the school were Faraday Type 2 single-projector horns, and there were Autocall non-code break-glass stations in the appropriate areas.
Semi-related, the school was also built with an old Simplex clock system, with 6" Autocall vibrating bells for the interior school bell. A couple of 10" Autocall bells with protective cages on the gongs were installed outside, including one facing the playground of course.
The school underwent some repairs and renovations in 1978 after a possible structural failure was detected. In the process, the fire alarm system was replaced. A Simplex 4207 fire alarm system was installed, with the panel placed in the main office for easier access by the school faculty and the fire department. A 4308 annunciator with the red rectangular indicator lamps was installed near the main entrance. All of the alarm signals were Simplex 4051 horns on 4050-80 light plates with black “FIRE” lettering; the system was set up so the horns sounded on Continuous while the 4050-80s flashed on a slow March Time via the 4207 panel’s coding wheel. Some of them were installed right into the wall with flush-mount backboxes, while others had to be installed with the red surface-mount backboxes. The new pull stations were Simplex single-action 4251-20s (with the wire cages over them in the gymnasium), and there were also ESL 523C smoke/heat detectors and Simplex 4255-1 heat sensors in the appropriate areas.
The old Simplex time system was replaced with a newer Simplex clock system, and as a result, all of the school bells were replaced with Simplex 4090-2 6" vibrating bells, even outside! For the most part the bells were either surface-mounted on 4x4 backboxes or installed on semi-flush trim plates, depending on where they were placed, but the two bells in the gymnasium were flush-mounted behind gray grilles. Some of the original 1951 Simplex slave clocks remained intact where applicable, while others were replaced with newer clocks. The master clock eventually had to be replaced in 1997, with a Simplex 6400.
In 1983, a Simplex 4051 horn in the auditorium was found to be inoperable, and so it was replaced with a Simplex 2901-9833 horn.
In 1987, one of the two Simplex 4050-80s in the gymnasium was smashed by a dodgeball, and was replaced with a Space Age AV32 light plate (the Simplex 4051 horn survived the hit and thus remained intact.)
In 1991, the Simplex 4051 horn in the receiving area near the kitchen failed, and a Simplex 2901-9838 horn replaced it. Meanwhile in one of the hallways, a Simplex 4050-80 light plate was removed and replaced with a 4903-9001 light plate, with the 4051 horn re-mounted right onto it.
Between 1995 and 2000, some random ESL 523C smoke detectors that failed were replaced with Simplex 2098-9201 photoelectric smoke detectors. A couple of them even replaced Simplex 4255-1 heat sensors in areas where allowed! During this time a few other Simplex heat sensors were replaced with Simplex 2098-9441 heat sensors (their rebrand of the Chemtronics 601.)
In 1997, a couple of Simplex 4251-20 pulls that were found inoperable were replaced with Edwards/AIP-270 pulls.
In 1999, a failed Simplex 4051 horn in the hallway outside the cafeteria was replaced with a Simplex 4901-9805 electromechanical horn, mounted right onto the 4050-80.
In 2001, or whatever the year “Recess: School’s Out!” takes place in, the Simplex 4207 panel started having some issues, and so a Simplex 4005 fire alarm panel took over for the system. The 4207 cabinet was gutted and modified for terminal wiring usage, with the 4005 panel installed right next to it. Also as part of this, the ESL 523C smoke detector in the main office was replaced with a Simplex 4098-9601 TrueAlarm smoke detector, and the Simplex 4051+4050-80 horn/light in the boiler room was removed and replaced with a Simplex 4903-9252 horn/strobe.
During 2008-2015, a few Simplex 4251-20 pulls that were found inoperable were replaced with 2099-9756 dual-action pulls, and some more conventional TrueAlarm detectors replaced failing ESL 523C smoke detectors and Simplex 4255-1 heat sensors.
In 2016, the Simplex 4051 horn in the music room failed, and so a Simplex 4903-9426 TrueAlert horn/strobe replaced it, mounted right onto the 4050-80 plate with the light disconnected.
Yeah, I figured they too should have a Simplex system, since their school bells (as heard in the intro and in most episodes) sound exactly like the Simplex bells at my first elementary (now K-8) school.
[quote=wiley209 post_id=87722 time=1601001338 user_id=47]
Wait, I’ve done this school before!
Castleblanca Junior Senior High School was built in 1909 as a 3 story 400 student campus. Major expansions occurred in 1921 (new senior high gym and auditorium), 1949 (classroom addition), 1968 (planetarium), 1979 (Jr High classroom addition), 1989 (new junior high cafeteria), 2010 (new STEM wing, plus new pool), and 2011 (new senior high classroom addition)
Fire Alarm
Panel
[list]
  • [*]Current System: Simplex 4100ES INFOALARM - Voice Evacuation Campuswide
  • [*]Original System: Simplex 4100 replacing a coded Autocall System which was tied into a Simplex 4207.
  • [/list]
    Annunciator
    [list]
  • [*]Current System: Simplex 4603 in main office
  • [*]Original System: Graphic Annunciator in Front Lobby
  • [/list]
    Initiating Devices
    [list]
  • [*]Current System: Pulls are Simplex 4099-9001s. Smoke detectors are all Simplex 4908-9601s mounted on 4098-9788 bases. Heat Detectors are all Simplex 4098-9733s also on 4098-9788 bases. Duct detectors are also Simplex models.
  • [*]Original System: The 1909, 1921, and 1968 buildings had Autocall FNC pull boxes, and a few Simplex 2099 and 4521-20 pulls. The 1968 building had two Edwards 270s. There was also an EST 270-SPO as well. A mix of older Autocall heat sensors, and ESL and Simplex smokes were extant as well. The 1979 and 1989 additions had Simplex 4521-20 and 2099 pulls, as well as Simplex 2098 smoke detectors.There were also pull rods in the 1909 and 1921 buildings.
  • [/list]
    Notification Appliances
    [list]
  • [*]Current System: The entire school uses Simplex 4906-9151 speaker/strobes. These can be found pretty much everywhere except for the cafeteria, media center, and swimming pool. The cafeterias and media center have Simplex 4906-9154 speaker/strobes ceiling mounted. The pool has Wheelock ET70WP speaker/strobes.All restrooms have 4906-9101 strobes. Outside, there are Wheelock RSSWP strobes next to STH speakers. All speakers play a slow whoop tone and the standard Simplex voice message.
  • [*]Original System: Signals in the 1909, 1921, and 1949 buildings were Autocall rebranded IBM 4030-2 horns, two of which were replaced with Wheelock 31T horns. Areas that were the former (Jr High) cafeteria had Simplex 2901-9846 horns on 4903 strobe plates. The 1968 building initially had 2 4040 horns, but one was replaced with a Wheelock 7004T. The 1979 building had Simplex 4050 horns on 4050-81 light plates, plus a single Federal 350 replacing a 4050. There were also two Simplex TrueAlerts replacing dead horns. The 1989 building had 2901-9846 horns on 4903 strobe plates. There were a few Wheelock MT4-115WMs scattered as spot replacements for broken signals as well. All restrooms had 4904 strobes.
  • [/list]
    Intercom, Bell
    Main Head End Equipment
    [list]
  • [*]Current System: Rauland Telecenter VI
  • [*]Original System: Dukane Compact, replacing a TOA
  • [/list]
    Admin Phones/Mics
    [list]
  • [*]Current System: Rauland TC6434 phone at receptionist desk, TC4333 phones in other offices
  • [*]Original System: Tandy Mic next to Rack
  • [/list]
    Speakers/Call Switches
    [list]
  • [*]Current System: The school has Rauland ACC5WB speakers in the hallways, media center, planetarium, and cafeterias. All offices, classrooms, plus hallways in the 2010 and 2011 additions have Rauland ACC1100 speakers ceiling mounted, with all classrooms having TCDPB2 call in buttons. The auditorium, gyms, and swimming pool have Atlas AP15 speakers. Outside there are Rauland AC1411 paging horns.
  • [*]Original System: The 1909, 1921, 1949, and 1968 buildings had Realistic power horns throughout, with IBM or Simplex Clock/Speaker Combo units in classrooms. The 1979 addition had Dukane speakers throughout the building, including Simplex clock/speaker/call switch units in classrooms. The 1989 addition had ceiling mounted Dukane speakers.
  • [/list]
    Bell
    [list]
  • [*]Current System: Chime tone over intercom - https://www.youtube.com/watch?v=Kr8dUwPz3B4
  • [*]Original System: The 1909, 1921, and 1949 buildings had IBM 6 inch bells in the hallways, with classrooms having buzzers in the clocks, with 10 inch bells outside. Some Edwards and Wheelock 6 inch bells were installed to replace broken IBM bells. The 1968 addition had two Simplex STR-6 bells, and one Federal Signal 10 inch Bell outside. The 1979 and 1989 additions had Simplex 4 inch bells inside the hallways and the cafeteria, with 10 inch bells outside. Two Edwards 4 inch bells replaced broken Simplex bells, classrooms had buzzers in the clocks.
  • [/list]
    Clock System
    Master Clock
    [list]
  • [*]Current System: Rauland 2524
  • [*]Original System: Simplex 6400 replacing a R83, replacing an IBM system
  • [/list]
    Clocks
    [list]
  • [*]Current System: The whole school has Rauland 2522 clocks throughout, with the ones in the hallways being wall-mounted dual units.
  • [*]Original System: The 1909, 1921, and 1949 building had a mix of Simplex, Lathem, Edwards and IBM clocks. The 1968, 1979, and 1989 buildings had Simplex and Lathem clocks.
  • [/list]
    Seashell Towers was built in 1997. It is a 30-story beachside condo building.
    Panel
    • Simplex 4120
    Annunciator
    • Simplex 4603-9101
    Initiating Devices
    • Pulls are Simplex 4099-9004s, behind Stopper II covers. Smoke detectors are all Simplex 4098 series devices. The ones in guest rooms on sounder bases. There are also Simplex 4098 series heat detectors as well.
    Indicating Devices
    • The main signals here are Simplex 4903-9150 speaker/strobes. These can be found in the main lobby, all elevator lobbies, and in the restaurant, gym, and event center. Some were replaced with Simplex 4906 speaker/strobes. ADA condos usually have Simplex 4903-9148 speaker/strobes. Hallways, as well as the condos have ceiling mounted Wheelock ET90 speakers ceiling mounted, with hallways having Simplex 4904 strobes. Some 4904s were replaced with TrueAlert strobes. The arcade, offices, and playroom use Wheelock ET90 speaker/strobes, with one ceiling mounted TrueAlert speaker/strobe.
    Jayson High School is a huge high school that was originally built in 1976. It had 3 buildings. One which is the Original building,One from 1995, and one from 2015
    Building #1 (originally built in 1976 and expanded on in 1998)
    Panel:
    1976-1998: Simplex 4208
    1998-Present: Simplex 4100+ (System set on continuous)
    Notification appliances:
    Simplex 4051s on 4050-80s as the main alarms
    Simplex 2901-9833 on 2903-9001 replacing 6 dead alarms
    Simplex 2901-9838s on 4903-9102s replacing 2 dead alarms
    Wheelock MT-24-LSM as the main alarms in the 1998 addition (on code 3 tone)
    Wheelock LS1M-24 as for the main remote strobes (found in classrooms,restrooms, and smaller rooms.
    Wheelock RSS replacing a older Wheelock strobe.
    Simplex 4903-9425 replacing some alarms in the older section of the building.
    System Sensor P4RL replacing a dead 2903 combo
    Pull stations
    Simplex 4251-20s as the main pull stations.
    Notifier BNG1 replacing 5 4251-20
    Simplex 2099-9754s replacing several 4251-20s
    Simplex 2099-9761s for the main pull station for the 1998 addition
    Fire Lite BG12Ls replacing 3 4251-20s and 1 Notifier BNG1
    Smoke detectors:
    Simplex 2098-9201s with 2098-9651 bases in the entire school building (both old and new sections)
    Simplex 4098-9714s with 4098-9792 bases replacing several 2098-9201s.
    Simplex 2098-9211 heat detector with the 2098-9651 bases used for science rooms and restrooms though out the entire school building.
    Annunciator
    Simplex 4603-9101s in the main entrance,Fitness wing entrance, performing arts entrance and main office.
    Building #2 (built in 1995 and expanded on in 2016)
    Panel
    1995-2016: Simplex 4100+ (Coding: continuous from 1995-2016)
    2016-Present: Simplex 4100ES with Voice Evac for the 2016 area of the school. (Coding: Code 3 for the horns) (tone: 4100ES Whoop) (Message: same message as herd in this video https://youtu.be/ICfYj0WKuqg)
    Simplex 4903-9221s for the main alarms
    Simplex 4904-9138s for the remote strobes
    Simplex 4901-9817 was the outdoor fire alarm until gotten replaced
    Simplex 4903-9241s replacing a few 4903-9221s
    System Sensor P1224MCWs replacing 10 9221s
    System Sensor S1224MCWs replacing a 4 4904-9138s’
    System Sensor P1224MCK replacing the only 4901-9817
    Simplex 4903-9431s replacing several 4903-9221s
    Simplex 4904-9171s replacing several 4904-9138s
    Wheelock MT-24-MCW-FW replacing a 9221(set on Continuous horn)
    System Sensor P2R replacing a 4903-9241
    Simplex 4906-9154 as the ceiling mount alarms for the 2016 addition
    Simplex 4906-9153 for the wall mount alarms for the 2016 addition
    Simplex 4906-9103 for the wall mount remote strobes for the 2016 addition
    Simplex 4904-9104 for the celling mount remote strobes
    System Sensor P2WL replacing a P1224MCW.
    Pull stations
    Simplex 2099-9795s for the original area
    Simplex 4099-9006s
    Smokes
    Simplex 2098-9201s on 2098-9651 bases
    Simplex 4098-9714s on 4098-9792 bases
    Simplex 2098-9211s on 2098-9651 bases
    Simplex 4098-9733 on 4098-9792 bases
    Annunciator
    Simplex 4603-9101
    Building #3 (built in 2015)
    Panel: Simplex 4100ES with voice (voice and tone are the same as building #2)
    Wheelock E50-24MCW-FW
    Wheelock RSS-24MCW-FW
    Wheelock E60-24MCC-FW
    Wheelock RSS-24MCC-FW (round model)
    Wheelock ET70WP-2475W-FW
    Pull stations
    Simplex 4099-9006
    Smokes
    Simplex 4098-9733s on 4098-9792 bases
    Annunciator
    Simplex 4603-9101 with remote microphone
    Stadium system
    Simplex 4004
    Wheelock AS-24-MCWs
    Wheelock RSS-24MCW-FRs
    Wheelock ASWPs
    Wheelock RSSWPs
    Simplex 2099-9756s
    Simplex true alarm conventional detectors
    Emergency lighting
    Building #1
    Lithonia Titans in the original school with some Dual Lite LXs and LZs
    Dual Lite Excaliburs for the 1998 addition
    Building #2
    Dual Lite Excaliburs for the original school
    Dual Lite Sampras for the 2016 addition
    Building #3
    Dual Lite EVEs
    Stadium
    Dual Lite EZ-Snap
    Dual Lite Exite
    Dual Lite EZ2s
    That took a long time to type
    The Tellis Island Convention Center was originally built in 1958 as the Lyndanbergh School for Witchery, which ran until 1974, when Tellis Island’s Management purchased the school for use as a convention center for part of the Tellis Island Resort. Three Major Renovations and expansions occurred: 1984, 1995, and 2006.
    Fire Alarm
    Panel
    • Current System: Notifier NFS-3030 with AMG, tied into an Autocall TFX-400, and in turn to a Pyrotronics System 3
    • Original System: Standard Electric Time TAX-3M
    Annunciator
    • Current System: Notifier NCA-2 in Lobby
    • Original System: None
    Initiating Devices
    • Current System: The unrefurbished areas have Standard 200177 pulls, with a lone RSG T-Bar. The 1984 areas have Pyrotronics MS-51s, along with a few BG-12s. The 1995 areas use RSG T-Bars exclusively, and the 2006 areas use Notifier NBG-12LXs. As for smoke detectors, it’s a mix of Pyrotronics DI3s, ESL, System Sensor, and Notifier FSP models.
    • Current System: The 1958 areas of the building have 4 Federal Signal 350 horns, along with a couple of ZNSs. The 1984 areas have Wheelock 7002s, along with a Gentex GMS in the cafeteria. The 1995 areas have FOS 6120-5512 horn/strobes, along with a few Wheelock MT24-LSMs and Wheelock AS horn/strobes. There is a P2R in the office. The 2006 areas, along with the auditorium, gym, and most lecture rooms have System Sensor SP2R1224MC speaker/strobes, along with System Sensor Spectralert Classic remote strobes in all restrooms.
    Of note, the whole fire alarm system is due to be replaced soon with a Simplex 4100ES INFOALARM, with 4099-9001 pulls and 4098 series smokes. Along with TrueAlert ES Speaker/strobes and strobes.
    The clock and bell system was by IBM, but was removed in 1995.
    Here’s a long one (probably the longest and biggest of the bunch
    Yellwood Area was originally a apartment complex built in 1930s. Originally it was one building (B1) but in the 1950s they had a second building (B2). Then in the 1980s they built phase 1 the 3rd building but in the 1990s they built phase 2 (B3). Along in the 90s they built 2 more buildings (B4 and B5). In the 2000s they built B6 and B7. B8 was built in 2013, B9 was built in 2016, and B10 was built in 2019. But when they added shops and etc it became a small area. Yellwood has its own grocery store, Outlet mall,Community center, and church.
    Panels:
    Current: Notifier NFS2-3030 with DVC (2013-Present)(controlling B1,B2,B3,B8,B9, and B10) (plays a 520hz tone with Notifier default message)
    Building #1
    The building had no system from 1930s-1962
    System #1 (in service from 1962-1983) (replaced due to upgrade)
    Panel: None (the system functions like this shown in the video https://youtu.be/EYbcJwJ1kIA)
    Pull Stations: Edwards 270SPO
    N/A: Edwards AdaptaHorns (surface mount)
    System #2 (in service from 1983-2002) (system replaced due to renovations)
    Panel: Simplex 2001
    N/A:
    Simplex 2903-9001s with 2901-9806s
    System Sensor MA (replaced 1 9806)
    Wheelock MT24-WM (replaced a 2903 and a 9806)
    Pull Stations:
    Simplex 4251-30s
    Notifier BNG1R (replaced 1 4251-20)
    Smokes:
    None
    System #3 (2002-2013)
    Panel:
    Notifier AFP-200
    N/A:
    System Sensor P241575Ws
    System Sensor S241575Ws
    System Sensor PA400Ws
    System Sensor P24110K
    System Sensor P2Ws (replaced several classics)
    System Sensor SWs (replaced 2 Classic remote strobes)
    Pull Stations:
    Notifier NBG12LXs
    Smokes:
    Notifier FSP-751s
    Notifier FST-751s
    Notifier FSP-851s (replaced a few FSP-751s)
    Notifier FST-851s (replaced a couple FST-751s)
    Annunciator:
    Notifier LCD80TM
    System #4 (2013-present)
    The system is the same as System #3 of B1 but the panel was replaced with the single 3030
    Building 2
    System #1 (1966-1995) (replaced due to upgrade)
    Panel: None (works the same way as System 1 of building 1)
    Pull Stations:
    Edwards 270SPO
    Simplex 4251-201 (replaced a Edwards 270SPO due to a fire that happened in floor 3)
    N/A:
    Edwards adaptahorns
    Simplex 4040 (replaced a Adaptahorn. Same reason why that 270SPO got replaced)
    System #2 (1995-2013)
    Panel: System 500
    N/A:
    Gentex SHGs
    Gentex GXSs
    Gentex GX90s
    Gentex GX90Ss
    Gentex Commander 2 (replaced a SHG)
    Gentex Commander 3s (replacing several different devices)
    Wheelock NS (replaced a SHG)
    Wheelock RSS (replaced a GXS)
    Pull Stations:
    Notifier BNG1Rs
    Notifier NBG12Ls (replacing some BNG1Rs)
    RSG RMS1T (replaced 2 BNG1R)
    Smokes:
    System Sensor 1400s
    System Sensor i3s (replaced 2 1400s)
    System Sensor 2151s (replaced 5 1400s)
    Chemtronics heat detectors
    System Sensor 5601s (replaced a lot of heat detectors
    Annunciator: ACM-16AT
    System #3
    Panel: Main NFS2-3030
    A/V: same as System 2 in B2 with replacements
    System Sensor P2R (replaced a SHG)
    Pull Stations: Same as System 2 in B2 except there Minimods behind them
    Notifier NBG12LXs (replaced a BNG1R)
    Smokes:
    Notifier FSP-851 (replaced every 1400)
    Notifier FST-851 (replaced every Heat detector)
    Annunciator: NCA2
    Expansions (in 2020):
    Panel is the same.
    Pull Stations:
    NBG12LXs
    N/As:
    System Sensor P2RL
    System Sensor SRL
    System Sensor PC2WL
    System Sensor SCWL
    System Sensor HWL-LF
    System Sensor P2WL-LF
    System Sensor P2RK
    Smokes
    Notifier FSP-951s
    Notifier FST-951s
    Building #3
    System #1:
    Panel: Simplex 4002 (1987-2013)
    Pull Stations:
    Simplex 4251-20s
    Simplex 2099-9754s (replaced a few 4251-20s)
    Notifier NBG-10L (replaced a 2099-9754) (no longer in the system)
    FCI MS2s (replaced 2 4251-20s)
    Notifier NBG12L (replaced the NBG10L due to the recall of the NBG10s)
    N/As:
    Simplex 2901-9838+Simplex 2903-9101s (main alarms in the Phase 1 part)
    Simplex 2901-9838s+4903-9101s (main alarms in the phase 2 part)
    Simplex 4903-9220s (replaced 15 Simplex 2903 combos)
    System Sensor P241575s (replaced a 2903 combo and a 4903 combo)
    Wheelock NS4 (replaced a 4903 combo)
    System Sensor P4R (replaced a 4903-9220s
    Smokes:
    Simplex 2098-9110s (System Sensor 1400s) (main smokes in phase 1)
    Simplex 2098-9209s (main smokes in phase 2)
    Annunciator:
    Simplex 4602-9102
    Simplex 4602-9101
    System #2:
    A/Vs and the pulls are the same but there were some additions (like mini horns in the rooms) and renovation of the main entrance.
    Pull Stations
    NBG12LX (main entrance pull station and replaced a 4251-20)
    N/As:
    System Sensor P2Rs (main entrance alarms)
    System Sensor SRs (main entrance alarms and restroom’s alarms (both old and new parts))
    System Sensor P2RL (replaced a P2R)
    Smokes:
    FSP-851s (replaced all the old smoke detectors)
    FST-851s (replaced all the old heat detectors)
    Annunciator:
    NCA2
    Building #4
    Panel: Notifier AFP-400 with AMG (1995-present)
    N/As:
    Wheelock E-7070-LSM-24
    Wheelock MIZs
    Gentex SPKE4-15/15-WR
    Gentex GXSs
    Gentex GX90s
    Wheelock E70s (replaced 3 Wheelock speaker strobes and replaced 2 Gentex speaker strobes)
    System Sensor SP2R1224MCs (main alarms in the 2004 addition)
    System Sensor S1224MCs (Main remote strobes in the 2004 addition)
    System Sensor PA400W (main mini horns in the 2004 addition)
    System Sensor SPSR (replaced 2 classics and 1 SPKE4)
    System Sensor MHW (replaced 2 PA400Rs)
    (Note: the Wheelock devices and the Gentex devices were mixed around in the original part of the building)
    Pull Stations:
    Notifier BGX-101Ls
    Notifier NBG12LXs (replaced a lot of BGX-101Ls and were the main pull stations in the 2004 addition)
    Smokes:
    Notifier CPX-551s
    Notifier FDX-551s
    Notifier FSP-851s (2004 addition)
    Notifier FST-851s (2004 addition)
    Annunciator:
    Notifier LCD80
    (The system is networked to the NFS2-3030)
    Building #5
    Panel:
    Notifier AFP-400 (1996-present)
    N/As:
    Phase 1 (1996)
    System Sensor MASS241575ADA
    System Sensor SS241575AD
    System Sensor PA-400Ws
    Phase 2 (1998)
    System Sensor S241575s
    Pull Stations:
    Notifier BGX-101Ls
    Notifier NBG12LXs (replacing lots of BGX-101Ls)
    Smokes:
    Notifier SDX-551
    Notifier FDX-551
    (System networked into the NFS2-3030)
    Building #6
    Panel:
    Notifier NFS-640 (2001-present)
    A/Vs:
    Wheelock ASs
    Wheelock NSs
    Wheelock MTs
    Wheelock RSSs
    Wheelock MIZs
    Pull Stations:
    Notifier NBG12LXs
    Smokes:
    Notifier FSP-751s
    Notifier FST-751s
    Annunciator:
    Notifier LCD80
    (System is networked in to the NFS2-3030)
    Building #7
    Panel:
    Notifier NFS-640 with AMG (2006-2009) (panel replaced due to a surge which killed the CPU)
    Notifier NFS2-640 with AMG (2009-present)
    A/Vs:
    Wheelock E90 remote speakers (only in the main entrance)
    System Sensor SPSR (replaced a classic)
    System Sensor SPSRLs (replaced several classics due to a fire)
    System Sensor SRLs (replaced several classics for the same reason)
    Pull Stations:
    Notifier NBG12LXs
    Smokes:
    Notifier FSP-851
    Notifier FST-851
    Notifier FSP-951-IV (replaced several FSP-851s due to a fire)
    Notifier FST-951-IV (replaced several FST-851s due to the same reason’
    Annunciator:
    Notifier FDU-80
    (System networked into the 3030)
    Building #8
    Panel: Notifier NFS2-3030 with DVC (same panel as B1,B2,B3,B9,B10)
    A/Vs:
    System Sensor SPSWs
    System Sensor SWs
    System Sensor SPSCWs
    System Sensor SCW
    System Sensor SPCW
    Smokes:
    Notifier FSP-851
    Notifier FST-851
    Pull Stations:
    Notifier NBG12LXs
    Annunciator:
    NCA2
    Building #9 has the same system as Building #8 but the devices are in red except the ones in the rooms
    Building #10
    Panel: Notifier NFS2-3030 with DVC (same one as in B1,B2,B3,B8,B9)
    A/Vs
    System Sensor SRLs
    System Sensor SPSCWLs
    System Sensor SCWLs
    Wheelock E70 remote speakers
    Pull Stations
    Notifier NBG12LXs behind STI Stopper IIs
    Smokes:
    FSP-951s
    FST-951s
    Annunciator:
    Notifier NCA2
    The massive apartment complex has passway which they put in 2013 to connect all of the buildings together. The passway wasn’t complete until 2019. The passways has one panel to control them all. Here’s the system
    2013 passways and 2016 passways
    Panel: Notifier NFS-320
    A/Vs:
    System Sensor PC2Rs
    System Sensor SCRs
    System Sensor P2RKs
    Pull Stations:
    Notifier NBG12LX
    Smokes:
    Notifier FSP-851s
    2019 passways
    N/As:
    System Sensor PC2RL
    System Sensor SCRL
    Pull Stations:
    Smokes:
    FSP-951s
    That was the apartment complex.
    Now let’s move on to the Yellwood outlet mall. The building Had a massive expansion in 2012.
    Panel:
    Simplex 4002 (1990-2012)
    Simplex 4100ES (2012-Present)
    A/Vs:
    Simplex 2901-9838s on 4903-9101s
    Simplex 4904-9101s
    Simplex 4903-9219s (replaced a few combos)
    Wheelock ASs (replaced several combos)
    Wheelock RSSs (replaced several 4904s)
    Wheelock ZNS (replaced a AS)
    Wheelock HSR (replaced 2 9219s)
    Simplex 4906-9127s
    Simplex 4906-9128s
    Simplex 4906-9129s
    Simplex 4906-9130s
    Simplex 4906-9131s
    Simplex 4904-9101s
    Simplex 4904-9102s
    Simplex 4904-9103s
    Simplex 4904-9104s
    Simplex 4904-9105s
    Pull Stations:
    Simplex 4251-20s (all replaced when the 4100ES was put in)
    Simplex 4099-9006s
    Simplex 2099-9139s
    Smokes:
    Simplex 2098-9201s (same reason as why the 4251-20s were replaced)
    Simplex 4098-9714s on addressable bases
    Annunciator:
    Simplex 4603-9101 (original system didn’t have a annunciator)
    Movie theater system.
    Panel: Siemens MXL with Voice (located in the main entrance)
    N/As:
    Siemens S-HP-MCS-Cs
    Siemens S-HP-MCS-Ws
    Siemens S-HP-MCSs
    Siemens U-MCS-Ws
    Siemens U-MCSs
    Siemens SET-MC-W (replaced a Siemens speaker strobe)
    Siemens ST-MC-R (replaced a remote strobe)
    Pull Stations:
    Siemens MSI-20Bs
    Smokes:
    Siemens FP-11s
    Siemens DT-11s
    Yellwood Grocery Store (had a massive renovation in 2010)
    Panel:
    EST 6616 (1994-2017)
    Fire Lite MS9600UDLS
    A/Vs:
    EST integritys (replaced due to renovations)
    EST Genesis (replaced all of the Integritys)
    System Sensor L-Series (replaced all of the Genesis except for the recycling center which still has EST Genesis)
    Pull Stations:
    Edwards 270SPOs (replaced due to upgrades
    Fire Lite BG12LXs
    Smokes:
    System Sensor 2400s
    System Sensor i3s (replaced all of the 2400s in 2010)
    Fire Lite SD-355s (replaced all i3s)
    Annunciator:
    Fire Lite ANN80
    Church
    System #1
    Panel:
    Cerberus Pyrotonics System 3 (1987-2001)
    A/Vs:
    Cerberus Pyrotonics HSD-24s
    Cerberus Pyrotonics MTL (replaced a dead HSD24)
    Smokes:
    Cerberus Pyrotonics DI-3s
    Pull Stations:
    Cerberus Pyrotonics MS-51s
    System #2
    Panel:
    FCI 7100
    Evax 50 (voice panel
    A/Vs
    System Sensor SP2W110s (in the main auditorium)
    System Sensor SP2C75s (in the hallways)
    System Sensor SC2475Ws (also in the hall ways)
    System Sensor S2415s (in the restrooms and other smaller rooms)
    System Sensor SP2R75s (in lager rooms)
    System Sensor SPSCWs (main alarms in the expansion areas)
    System Sensor SCWs (remote strobe in the expansion area)
    Pull Stations:
    FCI MS2s
    Gamewell FCI MS7AFs (only in the expansion areas)
    Smokes:
    FCI ASD-PL (original area’s smokes)
    FCI ATD-L (original area’s heats)
    Gamewell FCI ASD-PL2Fs (expansion’s smokes)
    Gamewell FCI ATD-PL2Fs (expansion’s heats)
    Annunciator:
    FCI LCD-7100
    Yellwood elementary
    System #1
    Panel: Faraday MCP-2000 (1991-2015)
    N/As:
    Faraday 6120s (with the magnetic strobe)
    Faraday 5508s
    Pull Stations
    Faraday F1GTs
    Smokes:
    System Sensor 1451s
    System #2
    Panel: Silent Knight 5808 (2015-present)
    A/Vs:
    Original area: (same as with the first system but set on code 3)
    Expansion areas:
    Wheelock LHSW
    Wheelock LSTW
    Pull Stations (both original and newer wing):
    Silent Knight SK-Pull-SA
    Smokes (both original and newer wings)
    Silent Knight SK-Photos
    Silent Knight SK-Heats
    Annunciator
    Silent Knight 5860R
    Community center (built in 1984,expanded in 1992,1996,2003, and 2018)
    Panel:
    Simplex 2001 with Voice Evac (1984-1992) (replaced due to the 1996 addition) (whoop with message)
    Simplex 4100+ with Voice Evac (1996-2014) (panel died to a water leakage) (4100/4100+ whoop with default message)
    Simplex 4100ES with voice (2014-present) (Simplex 4100U/ES whoop with default message)
    A/Vs:
    Original part:
    Simplex 2902-9739s
    Wheelock ET-70s (replaced 3 2902s)
    Simplex 4903-9153s (replaced 9 2902s due to water damage and a ET-70)
    1992 addition:
    Simplex 2902-9732 with 4903-9101 strobe plates (the strobes are on the bottom)
    Simplex 4904-9101s
    Wheelock E50 (replaced a combo)
    1996 additions:
    Simplex 4903-9146s
    Simplex 4904-9137s
    2003 additions
    Wheelock E70s (in red)
    Wheelock E90s (in white)
    Wheelock RSS (wall mounts are red and ceiling mounts were white)
    2018 addition:
    Wheelock LSPSTR3s
    Wheelock LSTR3s
    Wheelock LSPSTWC3s
    Wheelock LSTWC3s
    Wheelock E70WPs (outside)
    Pull Stations:
    Simplex 4251-20s (all removed in 1996)
    Simplex 2099-9754s (all removed in 1996 and used in the 1992 addition)
    Simplex 2099-9761s (replaced all 4251-20s and 2099-9754s)
    Simplex 4099-9003s (used in the 2003 addition)
    Simplex 4099-9006s (used in the 2018 addition)
    Smokes:
    Original wing:
    Simplex Whiffle balls (replaced for the same reason)
    Simplex 2098-9201s on addressable bases
    Simplex addressable heat detectors
    1992 wing:
    Simplex 2098-9201s (replaced for the same reason)
    1996 wing:
    4098-9201s on addressable bases
    2003 and 2018 wings:
    Simplex Truealarms
    Yellwood restrooms
    Panel: Notifier AFP-200
    A/Vs
    Gentex Commander 1s
    Pull Stations: NBG12LXs
    Smokes and heats:
    Notifier FSP-751s
    Notifier FST-751s
    I will never get my time back after this.
    Herbert Elementary School was built in 1962 as a 1 story, 300 student, campus. A new media center, art, and music building was built in 1992, and a classroom addition was built in 2002.
    Fire Alarm
    Panel
    • Current System: Simplex 4100 (Voice Evac in the Gym and Cafetorium)
    • Original System: Dictograph 55-A
    Annunciator
    • Current System: Simplex 4603-9101
    Initiating Devices
    • Current System: Pulls are a mix of 4521-20s and 4099-9001s. Smoke detectors are a mix of older 2098 and newer 4098 series devices. Heat detectors are all 2098s. All AHUs have Simplex duct detectors.
    • Original System: There were five Dictograph G217 pulls and an Edwards 270. There were also Dictograph FG135 heat detectors.
    • Current System: Signals in the 1962-1992 buildings are Simplex 2901-9846 horns on 4903-9105 strobe plates. These can be found in the hallways and most large classrooms. The media center has 2 4903-9219s replacing broken alarms. Restrooms have 4904-9105 strobes. There is a Gentex GMS in the front office. All classrooms in the 1962-1992 buildings have System Sensor PA400R horns. However, dead PA400Rs were later replaced with 4903-9252s, 4906-9127s, and Wheelock NS horn/strobes. There is a Wheelock MT-24VFR horn/strobe in one part of the hallway set to code-3 horn. The cafetorium and gym and 2902-9711 speakers on 4903-9105 strobe plates, with the cafeteria having a 4906-9151 speaker/strobe replacing a broken 2902-9711. Outside, there are flush mounted 2901-9840 horns, with a few CP U-HNH-MCS horn/strobes. The 2002 addition has Simplex 4906-9127 horn/strobes throughout, with restrooms having 4904 strobes. There are two Wheelock ASWP horn/strobes outside.
    • Original System: The whole school had Federal Signal 350 horns.
    Bell, Intercom
    Intercom Head-End
    • Current System: Telecor XL, replacing a Rauland Telecenter IV
    • Original System: Stromberg
    Admin Phones/Mics
    • Current System: Telecor MCC-4 in principal’s office, at reception desk, and in clinic.
    • Original System: Shure Mic next to rack
    • Current System: In the 1962-1992 buildings, the hallways have Lowell speakers, while the classrooms have ceiling mounted Telecor S8T2570 speakers, replacing old wall mounted Rauland speakers, along with Rauland RS509 call switches. The cafeteria has Lowell ES-4T speakers, replacing Rauland speakers, and the gym has Lowell Unihorns, replacing older Tandy powerhorns. Outside, there are Rauland paging horns. The 2002 addition has ceiling mounted Telecor S8T2570 speakers throughout, with classrooms having Telecor call-in switches.
    • Original System: The school had Tandy power horns throughout the building, with classrooms having Standard Electric Time Clock/Speaker Units in them.
    Bell
    • Current System: 580hz Tone (4-seconds) over intercom, previous was 1250 hz
    • Original System: The building had Standard Electric Time 6-inch bells in the hallways, and 10 inch bells outside. All classrooms had buzzers in the clocks.
    Clock
    Master clock panel
    • Current System: Telecor replacing a Simplex 6400
    Clocks
    • Current System: The 1962-1992 buildings have a mix of Simplex, Lathem, and Telecor analog clocks. The 2002 building seems to use Telecor analog clocks
    • Original System: The school had Standard Electric Time clocks throughout the building
    Willowson University was established in 1949, with each of the buildings having varying construction dates.
    Fitzgerald Hall (co. 1949, renov. 1989, 2019) - Academic Building
    Panel
    • Current System: Simplex 4100ES, replacing a Simplex 4100
    • Original System: Coded Autocall
    Initiating Devices
    • Current System: Pulls are a mix of 4521-20s and 4099-9001s. Smoke detectors are a mix of older and newer 4098 series devices, and the same can be said about heat detectors. AHUs have Simplex duct detectors. Renovated areas have 4099-9001 pulls and 4098 series smoke detectors.
    • Original System: Pulls were Autocall Break Glass stations, with no heat detectors
    • Current System: Unrennovated areas have Simplex 2901-9838 horns on 2903-9101 strobe plates. Some were replaced with 4903-9220s and even TrueAlerts. One of the classrooms has a Wheelock ZNS. Renovated areas have Simplex 49AV-WRF horn/strobes. Unrenovated restrooms have 2904 strobes, with a few 4904 strobes as well. Renovated restrooms have ceiling mounted 49VOC-CRF strobes.
    • Original System: The old system had Autocall 10 inch bells in the hallways.
    Johnson Hall (co. 1949, renov. 1999) - Academic/Science Lab, Dining Hall
    Panel
    • Current System: Simplex 4120 with EVAC
    Initiating Devices
    • Current System: Pulls are all 4099s. Smoke and heat detectors are all Simplex 4098s. AHUs have Simplex duct detectors.
    • Original System: There were originally Autocall break glass stations, which in the mid-1980s were replaced with Edwards 270s. A few Autocall heat sensors were installed as well.
    • Current System: Main signals here are ceiling mounted ET-1080R speakers, along with wall-mounted Simplex 4904-9169 strobes. Some ET-1080Rs were replaced with 4902-9722 speakers. The dining hall has Simplex 4903-9150 speaker/strobes. All restrooms have 4904 strobes.
    • Original System: The old system had Autocall 10 Inch Bells throughout
    Misc
    • There is a Simplex 4603-9101 annunciator in main lobby.
    Clarabelle Hall (co. 1952, renov. 2002) - Academic (IT)
    Panel
    • Current System: Simplex 4100U INFOALARM
    • Original System: Simplex 2001 replacing an IBM 4201-2
    Annunciator
    Initiating Devices
    • Original System: There were IBM rebranded Chevrons and Simplex 4521-20s throughout, along with a few IBM Heat Sensors, and a few 2098 series smoke detectors.
    • Current System: Signals are all Simplex 4906-9127 horn/strobes. All restrooms have 4906-9101 strobes. There is a Wheelock AHWP outside.
    • Original System: The halls had IBM 4030-2 horns, with a single Federal 350 horn replacing a dead 4030-2.
    Halon System Panel
    • Fiquench 10-038
    Halon System Initiating Devices
    • There are 2 FireLite BG-10s labeled for Halon release. There are also System Sensor 2400 smokes.
    Halon System Notification Appliances
    • There are three Fiquench 20-051+20-047 horn/strobes in the server room, along with Faraday 10 Inch Bells. Outside the room, there is a 20-047 strobe on a mounting plate.
    Biology Classroom Building (co. 1995)
    Panel
    • Simplex 4020
    Initiating Devices
    • Pulls are Simplex 2099-9759s and 4099-9001s. Smoke and heat detectors are all 4098 series devices.
    • Signals here are Simplex 4903-9220 horn/strobes, and 4904 strobes in restrooms
    Merrick Hall (co. 1987, renov. 2000) - High Rise Residence Hall
    Panel
    • Simplex 2120 with EVAC
    Initiating Devices
    • Pulls here are a mix of 4521-20s and 2099s. Smoke detectors are a mix of older 2098s and newer TrueAlarms. ESL smoke detectors are installed inside individual dorm rooms.
    • The main signals here are Simplex 2902 series speakers on 2903-9101 strobe plates. These are installed in the hallways, elevator lobbies and public areas. Some of these were replaced with Wheelock ET50 and Simplex 4906 speaker/strobes. Individual dorm rooms, as well as the bathrooms, have ceiling mounted 2902 speakers. The ADA dorm rooms have 4903-9149 speaker/strobes, with restrooms having 4904 strobes.
    Phillips Hall (co. 1959, rennov. 1998) - High Rise Residence & Dining Hall
    Panel
    • Original System: Edwards with Reel-Tape Player
    Initiating Devices
    • Current System: Pulls are all Simplex 4099 series devices. Smoke detectors and heat detectors are a mix of older and newer TrueAlarms. Individual dorms have TrueAlarms with Sounder Bases.
    • Original System: Pulls were all Edwards 270s. Edwards heat sensors and smoke detectors were installed as well.
    • Current System: Signals here are Simplex 4903-9168 speaker/strobes. These can be found in all hallways, elevator lobbies and public areas. These are also in the dining hall. There are also ceiling mounted 4902 speakers in dorm rooms, and restrooms. The ADA dorm rooms have 4903-9149 speaker/strobes, with ADA restrooms having 4904 strobes.
    • Original System: The halls and public areas had Tandy Powerhorns, with individual rooms having Lowell speakers.
    Madison Hall (co. 1979, rennov. 2008) - Residence Hall/Apartments
    Panel
    • Current System: Simplex 4010
    • Original System: Simplex 4208
    Annunciator
    • Original System: Simplex unknown
    Initiating Devices
    • Current System: Pulls are all Simplex 4099-9001s. Smoke detectors are all Simplex 4098-9714s, heat detectors are all 4098-9733s. Apartments have 4098-9714s on Sounder Bases, along with Gentex Carbon Monoxide Detectors
    • Original System: There was a mix of 4521-20 and 2099 pulls, along with Simplex rebranded Pyrotector and 2098 series smokes in the hallways, and Smoke Sentinels in the apartments.
    • Current System: Signals here are Simplex 4906-9127 horn/strobes. These can be found in the hallways, elevator lobbies, and other common areas, including the ADA Apartments. Bathrooms in the ADA Apartments have 4906-9101 strobes. All other apartments have Edwards EG1R-HD horns.
    • Original System: Each end of the corridors, along with the front lobby and the elevator lobby had a Simplex 4051 horn on 4050-85 light plates. Some 4051s were replaced with 2901-9806s, and two were replaced with Wheelock AS horn/strobes. Some apartments had a single 4051 horn.
    Stilton Hall (co. 1976, renov. 2019) - Residence Hall
    Panel
    • Current System: Simplex 4100ES INFOALARM with EVAC
    • Original System: Simplex 4207
    Annunciator
    • Simplex 4603-9101 in main lobby
    Initiating Devices
    • Current System: Current System: Pulls are all Simplex 4099-9001s. Smoke detectors are all Simplex 4098-9714s, heat detectors are all 4098-9733s. Dorms have 4098-9714s on Sounder Bases, along with Simplex CO Detectors.
    • Original System: There was a mix of 4521-20 and 2099 pulls, along with Simplex rebranded Pyrotector and 2098 series smokes in the hallways, along with Gentex smokes in the dorms.
    • Current System: Signals here are all Simplex 49SVC-WRFIRE speaker/strobes. These can be found in the hallways, elevator lobbies, public restrooms, and common areas. Individual dorms have ceiling mounted 49HF-APPLC speakers, with ADA dorms having 49SVC-CRFIRE speaker/strobes.
    • Original System: There were flush mounted 4041 horns in the hallways. A few were replaced with 2901-9846 horns, and one was replaced with an EST Genesis horn/strobe.
    Young Center (co. 1992) - Academic, Studio Arts
    Panel
    • Simplex 4002
    Initiating Devices
    • Pulls are all Simplex 2099s, and there are a few 2098 series smoke detectors.
    • Signals are all Simplex 2901-9846 horns on 4903-9101 strobe plates, with restrooms and classrooms having 4904 strobes.
    Student Union (co. 2004)
    Panel
    • Simplex 4100U INFOALARM with EVAC
    Initiating Devices
    • Pulls are all Simplex 4099-9001s. Smoke detectors are all Simplex 4098-9714s, heat detectors are all 4098-9733s.
    • Signals here are mostly Simplex 4906-9154 speaker/strobes, along with 4906-9151 speaker/strobes as well. Large rooms have Wheelock Speaker clusters with 4904 strobes.
    Performing Arts Center (co. 1950, renov. 1988, 2013)
    Panel
    • Current System: Simplex 4100ES with Evac
    • 1986-2013 System: Simplex 2001 with Evac
    Initiating Devices
    • 1986-2013 System: Pulls here were a mix of 4521-20s and 2099s. Smoke detectors were a mix of older 2098s and newer TrueAlarms.
    • Original System: There were Autocall FNCs and two Edwards 270s, a few heat sensors were installed as well.
    • Current System: Signals here are all Simplex 4906-9151 speaker/strobes, mainly in the lobby, corridors, drama classroom, band room, and choir room. The auditorium has Wheelock STH Speakers with 4906-9101 strobes. All restrooms have 4906-9151 strobes.
    • 1986-2013 System: Signals here were 2902 series speakers on 2903 strobe plates, with the auditorium having Simplex Megaphone speakers aside 2904 strobes. Some of the 2902+2903-9101s were replaced with Simplex 4903 speaker/strobes, with two ET70s in the mix.
    • Original System: There were Autocal 121-S horns throughout. Two in the theater, one at each end of the hallway, and one in the lobby.
    Facilities Services (co. 1991)
    Panel
    • Notifier System 5000
    Initiating Devices
    • Pulls are Notifier BG-8s with a few BG-12s. Smokes are CPX-551s with a few i3s in the mix.
    • Signals are Gentex SHGs, with at least 2 P2Rs and a Wheelock HSR. All restrooms have Gentex GXS strobes.
    Snyder Hall (co. 1983, renov. 2017) - High Rise Student Apartments
    Panel
    • Original System: Simplex 2001 with EVAC
    Initiating Devices
    • Current System: Current System: Pulls are all Simplex 4099-9001s. Smoke detectors are all Simplex 4098-9714s, heat detectors are all 4098-9733s. Apartments have 4098-9714s on Sounder Bases, along with Simplex CO Detectors.
    • Original System: There was a mix of 4521-20 and 2099 pulls, along with Simplex rebranded Pyrotector and 2098 series smokes in the hallways and in the apartments.
    • Current System: Signals here are all Simplex 4906-9151 speaker/strobes in the hallways, common areas, elevator lobbies, and other areas. All apartments have ceiling mounted 4902-9721 speakers. ADA apartments have 4906-9154 speaker/strobes ceiling mounted. Public restrooms and ADA restrooms have 4906-9101 strobes.
    • Original System: There were ceiling mounted, flush mounted Federal Signal Bullseye speakers throughout, with wall-mounted Simplex lights. A number of speakers were replaced with E90s, and lights with 4904 strobes.
    McKinley Administration Building (co. 2005)
    Panel
    • Edwards EST3
    Initiating Devices
    • Pulls are all EST SIGA 278s, and smokes are all EST SIGA-PSs.
    • Signals here are EST EG1RF-HDVM horn/strobes with EST EG1RF-VM strobes in restrooms and other areas not needing horns.
    Athletic Center (co. 1954, renov. 1999, exp. 2012)
    Panel
    • Original System: Coded IBM
    Initiating Devices
    • Current System: Pulls are all Simplex 4099-9001s, behind Stopper II covers. Smokes are all Simplex 4098 series devices, with System Sensor BEAM 200 detectors in the gym, monitored by Simplex ZAM monitoring modules.
    • Original System: There were IBM Chevron Pulls, and a relay switch from the Sprinkler System.
    • Current System: Signals here are Simplex 4903-9168 speaker/strobes. Restrooms have ceiling mounted 4904 strobes. The gym has wall-mounted 4904 strobes, with ceiling mounted Wheelock STH speakers. The expansion has 4906-9151 speaker/strobes.
    • Original System: The building had IBM 8 inch bells throughout.
    Consinvile Community center
    Built in 1951 and expanded on in 1974 (major),1986 (minor),1995 (major) and 2009 (major). And renovated in 2017 (the community center didn’t have a system until 1974)
    Panel:
    Before 2017
    Original addition and 1974 addition
    Simplex 4208 (1974-1998)
    Simplex 4005 (1998-2017) (set on march time)
    1986 and 1995 addition:
    Simplex 4001 (1986-1995) (set on march time)
    Simplex 4005 (1995-2017) (set on march time)
    2009 addition:
    Simplex 4010 (2009-2017) (set on code 3
    After 2017:
    Simplex 4100ES info-alarm (2017- present) (set on code 3) (controls all of the building)
    A/Vs:
    Original building and 1976 addition:
    Simplex 4903-9252 (replaced 1 4050-80 and it was mounted vertically)
    1986 addition:
    Simplex 2901-9838s on 2903-9101s
    Wheelock NS4 (replaced a 2903)
    1995 addition:
    Simplex 4903-9221s
    Simplex 4904-9138s
    Simplex 4903-9221Hs (used in the locker rooms)
    Simplex 4903-9223Hs (used in the big pool)
    Simplex 4903-9241s (replaced 5 9221s)
    Simplex 4903-9238Hs (replaced 2 9223Hs)
    Simplex 4901-9806s (used in the stairwells)
    Simplex 4903-9252 (replaced a dead 9221)
    Simplex 4903-9431s (replaced 3 4903-9221s)
    Wheelock HSR (replaced a 4904-9138)
    Wheelock MT4s (WM strobes and used outside of the building)
    System Sensor P2RK (replaced a MT4)
    2009 addition:
    Wheelock NSs (white) (used inside the community rooms)
    Wheelock ASs (white) (used outside in the halls)
    Wheelock RSSs (white) (used in small rooms)
    Wheelock ASWPs (red) (used outside of the building)
    2017 renovation:
    Simplex 4906-9129s
    Simplex 4906-9103s
    (These alarms only replaced alarms from the 1950s section of the building)
    Pull Stations:
    Original and 1974 addition:
    Simplex 4251-20s
    FCI MS2 (replaced one 4251-20)
    Notifier BNG1R (replaced another 4251-20)
    1986 addition:
    Simplex 4251-20s
    Silent Knight PS-SATKs (replaced 4 4251-20s and 3 are remaining)
    Fire Lite BG12L (replaced one PS-SATK)
    1995 addition:
    Simplex 2099-9756s
    Edwards 278B-1120 (replaced a 9756)
    RSG RMS-1Ts (replaced 2 9756s)
    STI Stopper II (put in the pool)
    2009 addition:
    Simplex 4099-9003s
    Simplex 4099-9006s (replaced a few 4099s)
    2017 renovation:
    Simplex 4099-9006s
    (After 2017 these Pull Stations had mini Monitor modules on them with the exception of the addressable Pull Stations)
    Detectors:
    Pre 2017:
    Original building and 1974 addition
    Simplex 4255-5s
    1986 addition:
    Simplex 2098-9508s
    1995 addition:
    Simplex 2098-9201s
    System Sensor 2W-B
    2009 addition: (these smoke detectors survived the 2017 replacement)
    Addressable Truealarms
    After 2017 it was all addressable Truealarms
    Annunciators:
    Pre-2017:
    1995 addition:
    Simplex 4602-9101
    Simplex 4602-9102
    2009 addition:
    Simplex 4606-9101
    Post-2017:
    Simplex 4603-9101s (replaced all annunciators except the 4602-9101 which ended up getting plated off)
    I got tired of doing multiple systems at a time. I have one of an entire school district and I didn’t finish it yet.
    The WaterCrust Lodge is a 3 building hotel with a swimming pool,theater,restaurants,food court, and a small mall (separate building from the rest) which the first building opened in 1984 and its final building opening up in 2003. The original 1983 building undergone a massive renovation and a massive expansion in 2021.
    Building #1: Main Hotel
    System #1 (1984-2004)
    Panel:
    A/Vs:
    Simplex 2902-9735s
    Simplex 2902-9734s (installed inside the rooms)
    Simplex 2904-9101s
    Simplex 4903-9153s (replaced 18 2902s)
    Pull Stations:
    Simplex 4251-30s
    Simplex 4251-20s
    Simplex 2099-9103s (replaced a 4251-20)
    Smoke detectors:
    Simplex 2098-9636s
    The system ended up getting replaced due to the 2001 failing and false alarms started to happen more often due to dusty smoke detectors. There were also lots of missing smoke detectors as well. The building failed inspection. The hotel owners decided to replace the system in 2004. The remainder of this system is the 2001 cabinet and the back boxes for the 2902s. The rest of the back boxes were removed in 2021 due to a massive renovation. The 2001 cabinet was also removed.
    System #2: (2004-2021)
    Panel:
    Siemens MXL with Voice Evac
    Siemens PAD3s
    A/Vs:
    Siemens S-HP-MCSs
    Siemens U-MCSs
    Siemens S-HP-Ws (installed inside the rooms)
    Siemens SET-MC-Rs (replaced a few speaker strobes)
    Siemens ST-MC-Rs (replaced 3 U-MCSs)
    Pull Stations:
    Siemens MSI-20Bs
    Smoke detectors:
    Siemens FP-11s
    Siemens HFP-11s
    Annunciator:
    Siemens RCC-1
    This system meet its fate when the 2021 renovations started renovation. The Siemens system ran fine and served it’s purpose. Though the system ran fine. There are no remains of this system. The hotel owners wanted to network the 4 buildings together. So all of the systems went down.
    System #3 (2021)
    Panel:
    Simplex 4100ES Touch Screen with Voice Evac
    Simplex 4009 Nac extenders
    A/Vs
    Wheelock ELSPSTWs
    Wheelock ELSPSTRs
    Wheelock ELSPSTWCs
    Wheelock ELSTWs
    Wheelock ELSTRs
    Wheelock ELSTWCs
    Wheelock ELSPK-W
    Wheelock E90-Ws (located in the rooms)
    Wheelock E70-Ws (located in the stairwell)
    Wheelock E70WP-2475W-FWs (located outside the building)
    (Note: the model number that start with EL suffix is a Wheelock Eluxa device)
    Pull Stations:
    Simplex 4099-9006s
    Simplex 2099-9139s
    Smoke detectors:
    Simplex 4098-9714s
    Simplex 4098-9613s
    Annunciator:
    Simplex remote command center
    Building #2 (built in 1995)
    This building was built due to the fact that the original building didn’t have enough rooms for demand. This building was planed in 1993 and started construction in late 1994. It opened up in 1995. The hotel building was mostly outdoors where you have to get outside to access the rooms. There were hallways inside which lead to a security office, Landry rooms, a lounge and etc.
    System #1 (1995-2021)
    Panel:
    Fire Lite Sensiscan 2000 (1995-2008) (died due to a water leakage which ruined the panel and made it non functional)
    Mircom FA-1000 (2008-2021) (served as a replacement to the Sensican panel after the water leak)
    A/Vs:
    Gentex WGMSs
    Gentex GX90s (installed inside the rooms)
    Gentex SHGs (used inside the building)
    Gentex GXSs (used in the smaller rooms and bathrooms)
    Gentex Commander 3s (replaced a few raspy GMS’
    Pull Stations
    Fire Lite BG10WPs (all were replaced in 2013 with BG12LOBs due to the recall)
    Fire Lite BG10s (replaced with BG12Ls for the same reason)
    Fire Lite BG12LOBs (replaced all BG10WPs)
    Fire Lite BG12Ls (replaced all Fire Lite BG10s)
    Smoke detectors:
    System Sensor 1451s
    This system had constant false alarms due to the BG10s backplate being overtightened and people over tightening the screw was another problem. In 2008 (when the FA-1000 took over) 1/3rd of the Pull Stations have been replaced). After the remaining BG10s were removed, there were less false alarms. The system was replaced in 2021 due to wanting to network the entire hotel campus. The remaining parts of the system were some WGMSs that were forgotten in replacement and the outdoor Pull Stations were left over.
    System #2:
    Panel:
    Simplex 4010ES
    A/Vs:
    Gentex WGMS (a few leftover due to being forgotten in the replacement)
    Wheelock ASWPs
    Wheelock RSSWPs
    Wheelock ELFHNW-Ns
    Wheelock ELHSRs
    Wheelock ELSTRs
    Pull Stations:
    Outdoor Pull Stations were Leftover from system #1
    Simplex 4099-9006s (replaced all indoor pull stations)
    Smoke detectors:
    Simplex 4098-9714s
    Simplex 4098-9613s
    Annunciator:
    Simplex 4603-9101
    Building number #3 Mall (opened in 1998)
    The mall opened up in 1998 to add more entertainment, restaurants, and shops. It’s a 1 story mall and it isn’t that big.
    System #1 (1998-2021)
    Main mall
    Panel:
    FCI FC72 (12 zone version) (1998-2014) (panel ended up getting replaced due to a surge killing it)
    Silent Knight 5208 (2014-2021)
    A/Vs:
    Wheelock MT-24-WMs
    Wheelock MT-24-LSMs
    Wheelock LS1M-24
    Wheelock HSRs (replaced some MTs)
    Wheelock RSS-24-MCWs (replaced some LS1Ms)
    (The MTs were set on code 3 tone)
    Pull Stations:
    FCI MS2s
    Silent Knight PS-DAs (replaced a couple MS2s)
    RSG RMS-1T (replaced 2 MS2s)
    Smoke detectors:
    System Sensor 2400s
    System Sensor 5601s
    System Sensor 2WB (I3s)
    Movie theater system (opened in 2000)
    Panel:
    A/Vs:
    System Sensor SP2R241575s
    Pull Stations:
    Notifier NBG12LXs
    Detectors:
    Notifier FSP-751s
    Notifier FST-751s
    (This system remained after the 2021 upgrade. The panel ended up being connected to the new panel)
    The system’s meet it’s fate in 2021 due to The hotel owner wanting to network the system. This resulted the entire system being replaced. There isn’t any remainders of the system left other then the movie theater system.
    System #2
    Panel:
    Simplex 4100ES with voice evac
    A/Vs:
    Wheelock ELSPSTWs
    Wheelock ELSPSTWCs
    Wheelock ELSTWs
    Wheelock ELSTWCs
    Wheelock E70WP-2475-FRs
    Pull Stations:
    Simplex 4099-9001s
    Smoke detectors:
    Simplex 4098-9714s
    Simplex 4098-9613s
    Annunciator:
    Building #4 (opened in 2003)
    Due to the fact that the place became a hot spot for Entertainment, Staying and Vacations. The hotel owners decided to make a new (massive) building. It would be a combination between Building 1 and 2. It also created a new entrance to the Lodge campus. This was the last building to be built. Started construction in 2001 and opened up in 2003.
    System #1: (2003-2021
    Panel:
    EST3 with Voice Evac
    A/Vs:
    Edwards Genesis Speaker strobes
    Edwards Genesis Remote Strobes
    Edwards Genesis Remote Speakers
    Edwards Integrity weather proof speaker strobes
    Pull Stations:
    Edwards SIGA278s
    Edwards SIGA270s (mounted behind STI Stopper IIs)
    Smoke detectors:
    Edwards SIGA-PS
    Edwards SIGA-HRS
    Annunciator:
    EST3-ANN with remote microphone
    This systems downfall happened due to the hotel owners wanting to network. There are no remains of the system
    System #2
    Panel:
    Simplex 4100ES (touch screen) with Voice Evac
    A/Vs:
    Wheelock E50-24MCW-FWs
    Wheelock E50-Ws
    Pull Stations:
    Simplex 4099-9006s
    Simplex 2099-9139s
    Smoke detectors:
    Simplex 4098-9714s
    Simplex 4098-9613s
    Annunciator:
    Simplex Remote command center
    All systems are networked into each other with the exception of the AFP-400.
    Ferncrest Elementary was built in 1976 as a one-story, 500 student campus. The school gained a 6-classroom addition in 1988, and a new media center in 2009.
    Fire Alarm
    Panel
    • Simplex 4100U INFOALARM, replacing a 4002 tied into the original 4208.
    • Graphic Annunciator in The Main Lobby, with a Simplex 4603-9101 right next to it.
    Initiating Devices
    • The 1976 and 1988 buildings have a mix of 4521-20, and 2099 pulls. There is a lone EST 278 pull in the kitchen. The original Simplex heat sensors in the 1976 building remain, but the original Pyrotector smokes were replaced with a mix of older and newer 2098 series devices. Areas that were the old media center have 4098 series smoke detectors. The 1988 building has newer Simplex heat detectors.The 2009 addition has 4099-9001 pulls, and 4098 series smoke and heat detectors.
    • The 1976 building mostly has Simplex 4051 horns on 4050-85 light plates. Two 4050-85s were replaced with Simplex 4903 strobe plates. There is a 4903-9220 at one end of one of the hallways. Some classrooms have 4051 horns, with a few having them on 4050-85 light plates. There is a Wheelock 7002 in the art room. There is also a TrueAlert in the cafeteria. A few 4051s were replaced with 2901-9806s and one was replaced with a Wheelock 34T. A few classrooms have Wheelock NS horn/strobes. The gym has one 4051+4050-85 and one Gentex SHG. Areas that were the media center have Wheelock HSR horn/strobes. All restrooms have Simplex 4904 strobes. There is a 4051 outside, and two Wheelock ASWP horn/strobes. The 1988 addition has 2901-9833 horns on 2903 strobe plates in the hallways, with three classrooms having 2901-9838 horns, with one having a Siemens U-MMT-MCS horn/strobe. Restrooms have Simplex 2904 strobes. Outside, there are two flush mounted 2901-9833s. The 2009 building has Simplex 4906-9103 horn/strobes throughout, with restrooms having ceiling mounted 4904 strobes. There are Wheelock ASWP horn/strobes outside.
    Intercom, Bell
    Main Headend Equipment
    • Current System: Rauland Telecenter VI
    • Original System: Bogen
    Admin Phones, Mics
    • Current System: Rauland TC6434 at admin desk and in Principal’s Office.
    • Original System: Bogen Mic next to rack
    Speakers, Call Switches
    • Current System: Hallways have Rauland ACC1208 speakers, while all classrooms have Rauland ACC1402 speakers with TCDPB2 call switches. The cafeteria and gym has wall mounted Atlas Speakers. Outside, there are flush mounted Atlas Speakers. The media center has Rauland ACC1402 speakers ceiling mounted.
    • Original System: Bogen speakers could be found throughout the school, with Tandy Powerhorns in the gym. All classrooms had Simplex Clock/Speaker combo units.
    Bell
    • Current System: Steady tone over intercom
    • Original System: The 1976 building had Simplex 4080 series 6 inch bells in the hallways, with 10 inch bells in the gym and outside. Some of these were replaced with Federal Signal bells. The 1988 addition had Edwards 4 inch bells in the hallways, with 6 inch bells outside. Both buildings had buzzers in the classroom clocks. These all have since been removed.
    Clock System
    Master Clock Panel
    • Current System: Integrated into Intercom
    • Original System: Simplex 2350 replacing an older Simplex model
    Clocks
    • Current System: All clocks are Rauland Digital Clocks.
    • Original System: The school had a mix of Simplex, and Lathem analog clocks.
    I’m pretty sure there’s already a topic for this, called “Make Up A System (2.0)”.
    @anon8378335 Topic moved, in the future keep in mind that we’ve relaxed our “bumping” rules a bit so bumping an old topic is OK so long as you add something relevant to the discussion. Plus, this topic is pinned anyway
    The Money Bin of Scrooge McDuck was built in 1902 and rebuilt on many occasions, with the most recent rebuild occurring in 1989.
    Fire Alarm
    Panel
    • Simplex 4100 (with Voice EVAC)
    Annunciator
    Initiating Devices
    • Pulls are a mix of 4521-30s, along with a few 2099s and one 4099-9001. Smoke detectors are a mix of older and newer 2098s. Heat detectors are all Simplex 2098 series devices. AHUs have APC Duct Detectors replacing older System Sensor Models.
    • Signals here are for the most part Simplex 2902-9732 speakers on 2903-9101 strobe plates. A few were replaced with Simplex 4906-9151 speaker/strobes, plus two were replaced with 4903-9150 speaker/strobes. The penthouse of Mr McDuck has ceiling mounted Wheelock E90 speakers, with a few blank 2904 strobes, and one Simplex 4904 strobe. The vault itself has blank 2904 strobes, and Simplex 4091-14 speakers. One 4091-14 was replaced with a Wheelock STH speaker. All restrooms have Simplex 2904 strobes, but one has a TrueAlert strobe instead. Some E90s were replaced with Simplex 4902 speakers. The panel is set to play the standard Simplex slow whoop tone for any fire alarm activation.
    Server Room FM-200 System
    Panel
    • Current System: Simplex 4004R
    • Original System: Kiddie Gemini
    Initiating Devices
    • Current System: There are two Simplex 2099-9149 pulls, each has a Simplex abort button next to it. Smoke detectors are all 4098-9601s.
    • Original System: There was a single FCI MS-2, and all System Sensor 2400 smokes.
    • There are two Kiddie 6 inch bells, and two Tork Alert rebranded Siemens U-MMT-MCS horn/strobes (these replacing Kiddie rebranded 450D+VALS horn/strobes). There is a Federal Signal Strobe above the door
    Security System
    Panel
    • Diebold D1700G
    Keypad
    • Diebold rebranded Radionics 9000
    Initiating Devices
    • The front door has Amesco door contacts, as well as the doors leading to the guard desk, and to Scrooge’s office. There are several Radionics motion detectors throughout, along with a few glass break sensors, particularly in the penthouse. The door leading to the vault has a door contact, but is set up as an Instant zone, so that it alarms if opened while the system is armed. There are also a few STI panic buttons which replaced older devices. An ultraviolet sensor is installed inside the vault as well.
    • There are three ELK SS30 sirens set to yelp. And also an Edwards 10 inch bell is in the vault.
    Madison Elementary School was built in 1971 as a 300 student, single story campus. A new media center was built in 1989.
    Fire Alarm
    Panel
    • Current System: Siemens XLS
    • Original System: Simplex 4002, replacing a DC Simplex system
    Voice Evac Panel
    • Current System: EVAX 50 in cafeteria, auditorium, and gym
    Initiating Devices
    • Current System: Pulls are all Siemens HMS-Ds behind Stopper II Covers. Smoke detectors are all Siemens FP-11s. Heat detectors are all Siemens FirePrint series devices. AHUs have Siemens Duct Detectors.
    • Original System: The 1971 building had mostly Simplex 4251-11 pulls, but some were replaced with 4521-20s. The cafeteria had a 2099 pull, and there was an EST 270 in the front office. There were a number of Simplex heat detectors, but a few ESL smokes and one 2098 series smoke detector replaced a few heat detectors. The 1989 addition had 4521-20 pulls and 2098 series smoke detectors.
    • Current System: The main signals here are all Siemens ZH-MC-R horn/strobes. These are installed everywhere, except the cafeteria, gym, and auditorium. Restrooms have ZR-MC-R strobes. The cafeteria, auditorium, and gym have SEF-MC-R speaker/strobes. Outside there are Siemens AS-75-R-WP horn/strobes, with a lone Gentex WGEC24-75WR horn/strobe used as a sprinkler alarm.
    • Original System: The 1971 building had mostly Simplex 4041 horns, in the hallways and other large rooms. Areas that were previously the media center have Simplex 2901-9838 horns on 4903 strobe plates. Some 4041s were replaced with 4051s and 2901-9833s. There were two 4903-9220s in the cafeteria, both replacing 4041s. There was a 7002 in the kitchen. The gym had two 4041s, one 2901-9806 horn on a 2903 light plate, and a Wheelock 7002T. Two classrooms have Gentex SHGs. The 1989 media center had 2901-9838 horns on 4903 strobe plates, plus a TrueAlert in the studio, and 4904 strobes in the restrooms. There was a 4041 outside.
    Intercom, Bell
    Head End Equipment
    • Original System: Rauland
    Admin Phones, Mics
    • Current System: Telecor MCC300 in front office, principal’s office, and clinic
    • Original System: Mic Next to Rack
    • Current System: Speakers for the most part are Telecor STB-11s, in the hallways, cafeteria, and media center. All classrooms have Telecor 2443 clock/speaker combos, with Telecor CS-1 call buttons. The auditorium and gym have Lowel LT-15H horn speakers, and outside, there are Atlas VP14MB speakers. In the front office, staff lounge, and each of the teacher’s lounges, there are also STI Push Button Stations labeled as “LOCKDOWN”.
    • Original System: The school had Rauland wall speakers throughout, except in the gym, where they had Tandy Power Horns. All classrooms had Simplex clock/speaker combos with Rauland Call Switches.
    Bell
    • Current System: Tone Over Intercom
    • Original System: In the 1971 building, there were Simplex STR 4017-62 bells in the hallways, and other large rooms like the cafeteria, auditorium, and gym. The areas that were the old media center had Edwards 4 inch bells. Some of the STR bells were replaced with Federal Signal Bells. Outside, they had Simplex STR 10 inch bells behind grilles. The 1989 addition had Edwards 6 inch bells throughout. All buildings had buzzers in the classroom clocks.
    Clock System
    Master Clock Panel
    • Current System: Sapling SMA3000
    • Original System: Simplex 2350, replacing the original Simplex model
    Clocks
    • Current System: The school has Sapling SBD3000 and Telecor Digital Clocks throughout the building
    • Original System: The whole school had a mix of Simplex and Lathem analog clocks.
    Brighton College
    Fire alarm:
    Current panel- Vantage Excel 64 zone addressable panel. With a Vantage Excel View repeater panel that also doubles as the access control auxiliary panel.
    Original panel- Vantage Sentry Compact 2 loop 16 zone addressable panel.
    Activation devices:
    Original system: Vantage 340-4768 manual call points, Vantage 3470 heat and smoke detectors.
    Current system: Vantage S5 manual call points, Vantage 34775-D detectors only, Vantage S5 SensorQuad detector strobes only.
    Original system: Vantage 37748 motorised fire bells, Vantage 2571-52 sounders.
    Current system: Vantage 34775-S smoke detectors with sounders set to alternating, Vantage S5 SensorQuad detector sounder strobes set to alternating.
    Sprinkler alarm bell: Vantage 33754 water powered sprinkler alarm bell located in the college mechanical room next to the sprinkler main feed pipe.
    Burglar alarm:
    Panel: KDE 9948 with onboard keypad, KDE 9478 RKP, KDE 9041 extension loudspeaker, vented bell box with electronic sounder, xenon strobe and SAB module, 20 minute bell duration, Vantage repeater panel connected to the auxiliary outputs on the security panel which is connected up to the electromagnetic locks on the main entrance doors, the repeater panel will deactivate the mag lock unlock output if the burglar alarm is activated by the lockdown panic button.
    Lockdown alarm: dedicated “LOCKDOWN” panic button connected up to the security panel.
    Access control system:
    Original system: none
    Current system: SecureSense GXM3000-24-45-82-39-57 (rebranded ATCO Access Control Systems Division AACS-29-32) tied in to the fire alarm repeater panel. A fire damaged the access control auxiliary panel, so it was replaced with an ATCO Access Control Systems Division AACS-45-15.
    New Brighton Shopping Centre
    Fire alarm:
    Original system: C-Tec XFP 2 loop 32 zone addressable panel. With a C-Tec XFP repeater panel in the security room.
    Current System: Vantage Sentry running firmware version 4.2.10, with a Vantage Sentry repeater panel.
    Activation devices:
    Original system: KAC old style call points, with address modules built into them to make them addressable, plastic resettable push element. Apollo XP95 smoke/heat detectors, Apollo XP95 duct smoke detector in the air duct above the frog clock, which uses a wheel and pendulum mechanism to carry a golden ball from the sun/bellows end to the clock/chicken/frog end of the track, if the duct smoke detector activates, it will initiate a full alarm, shut down the rooftop air handling units, gas fired heating/hot water boilers and shut down the frog clock completely until reset.
    Current system: Vantage S5 manual call points, resettable plastic push element, Vantage 34775-D smoke/heat detectors only, Vantage S5 SensorQuad smoke/heat/carbon monoxide detector strobes only.
    Both systems have been connected to each shop’s fire alarm system, some shops have Fulleon motorised fire bells from 1998, one shop has a KAC old style alarm sounder, the Argos has a KAC old style sounder strobe as well as motorised Fulleon fire bells. Holland and Barrett has a Fulleon electronic solenoid fire bell. Parts of the shopping centre have Vantage 34775-S optical heat sensor sounders set to Vantage 34775 alternating, Asda has a Protec system with Protec smoke/heat detector sounder/beacons set to alternating, and Protec sounder strobes set to alternating. The duct detector was replaced by a Vantage 35776 duct detector, JM Electronics has a Kentec Hochiki system with old style KAC call points with resettable plastic push element, custom address modules installed into them when the system was installed, Hochiki addressable smoke/heat detector sounder beacon bases set to Hochiki alternating. The lifts in the centre are tied into the alarm panel which is located in level 2 of the centre management suite. B&M has a Gent Xenex conventional 8 zone system, with conventional KAC old style call points with resettable plastic push element, conventional Hochiki smoke/heat detectors, 1990s Gent fire bells, Specsavers has a conventional Kentec system with new and old style KAC call points with resettable plastic push elements, Fulleon Roshni sounders set to Roshni alternating, sprinkler flow switch located in the basement which if activated will initiate a full alarm in the centre, shops and restaurants/cinemas which have Apollo XP95/Discovery/Hochiki systems with their own detectors/ resettable call points, sounders and panels, the Specsavers unit also has Apollo Series 65 heat/smoke detectors and Fulleon 24V DC motorised fire bells.
    December 2021 update:
    The shopping centre lost it’s JM Electronics store, when JM Electronics Stores Limited, trading as JM Electronics went into liquidation and was eventually liquidated and shut down for good, 2 weeks later the JM Electronics sign was removed from the shop unit and sold to a collector in Blackpool for £75million.
    A minor incident occurred in Specsavers, when a smoke detector was accidentally set off by a Specsavers employee, causing a full alarm activation, however that was resolved and there haven’t been any incidents since. The anchor tenant Primark has an addressable Hochiki Kentec system with new style KAC Hochiki addressable call points with resettable plastic push elements and Hochiki YBO smoke/heat/multi-sensor detector sounder beacon bases set to Hochiki alternating.
    March 2022 update 1:
    A major incident occurred when a fire started in McDonald’s kitchen which caused a full alarm condition, the kitchen was completely gutted by the fire which also caused some fire damage to part of the shopping centre.
    Here’s a another big one
    John Vale School District
    The school district founded in 1950s as a single school, divided by different wings. There a Elementary school wing, a Junior high school wing and a high school wing. Each wing being 10 classrooms each.
    System #1: (1956-1995)
    Panel:
    IBM 4201-2
    Pull Stations:
    IBM 4251-1s
    Signals:
    IBM 4030-2Bs
    In 1993 this K-12 school became a high school named John Vale high school. This was possible of the completion of the elementary school and the Junior high school.
    A addition happened in 1995 to the school in each wing. Instead of the wings being 10 classroom each. It’s now 16 classrooms for each wing. The old system couldn’t be expanded so the system got replaced.
    System #2 (1995-present)
    Panel:
    Notifier AM-2020
    Pull Stations:
    Notifier BGX-101Ls
    Notifier BNG1Rs (only in the gyms)
    Notifier NBG12LXs (replaced 2 BGX-101Ls
    Detectors:
    Notifier CPX-551s
    Notifier FDX-551s
    Signals:
    Wheelock MT-24-LSMs
    Wheelock LS1M-24s
    Wheelock MT-24-WMs (only used in the Gym,cafeteria, and auditorium)
    Wheelock MT4-24-WMs (outdoor alarms)
    Annunciators:
    Notifier LCD-80TM
    The school was moved to a different building in 2005. This building ended up becoming abandoned after the school closed. This building is planned to be remodeled to apartments.
    Now let’s move on to the elementary schools
    Sweet Oak Elementary
    This school was built in 1993 to serve the elementary school students. This is the oldest elementary school in the district with a additionin in 2019.
    System #1 (1993-present)
    Panel:
    Notifier AFP-200
    Original part (1993):
    Pull Stations:
    Notifier BGX-101Ls
    Notifier BNG1Rs (only in the gym)
    Detectors:
    Notifier SDX-551s
    Notifier FDX-551s
    Signals:
    Wheelock MT-24-WMs
    Wheelock WM1T-24
    Wheelock MT4-24-WMs (outdoor devices)
    Annunciator:
    Notifier LCD-80TM
    2019 addition:
    Detectors:
    Notifier FSP-951-IVs
    Notifier FST-951-IVs
    Pull Stations:
    Notifier NBG12LXs
    Signals:
    System Sensor P2RL
    System Sensor SRL
    System Sensor PC2WLs (in the classroom)
    Claire River Elementary
    This school was built in 2001. This school was built in response to the overcrowding at Sweet Oak. This school is bigger the sweet oak.
    System #1 (2001-present)
    Panel:
    Notifier AFP-200
    Pull Stations:
    Notifier BNG1Rs
    Detectors:
    Notifier FSP-751s
    Notifier FST-751s
    Signals:
    Wheelock ASs (used in the stairwell,gym,cafeteria, and classrooms)
    Wheelock NSs (used in the hallways)
    Wheelock RSSs (used in small scale rooms)
    Wheelock HSR (replaced a NS)
    Annunciator:
    Notifier LCD-80
    Daniel Stave Elementary
    This school was built in 2005.
    System #1 (2005-Present)
    Panel:
    Notifier NFS-640 (2005-2017) (replaced due to display displaying random characters)
    Notifier NFS2-640 (2017-present)
    Pull Stations:
    Notifier NBG12LXs
    Signals:
    System Sensor P1224MCs
    System Sensor P2R (replaced a classic in the hallway)
    Detectors:
    Notifier FSP-851s
    Notifier FST-851s
    Annunciator:
    Notifier FDU-80
    Dave oyster elementary
    Built in 2013.
    Panel:
    Notifier NFS-320
    Pull Stations:
    Notifier NBG12LXs
    Signals:
    System Sensor PC2Ws (use in the hallways)
    System Sensor P2Rs (used everywhere else)
    System Sensor SRs (small rooms)
    System Sensor P2RKs (outdoor only)
    Detectors:
    Notifier FSP-851s
    Notifier FST-851s
    Annunciator:
    Notifier FDU-80
    Stilver Elementary school
    Built in 2019
    Panel:
    Notifier NFS2-640 with DVC
    Signals:
    System Sensor SPSWLs
    System Sensor SCWLs
    System Sensor SRLs
    System Sensor SPSRKs
    Pull Stations:
    Notifier NBG12LXs
    Detectors:
    Notifier FSP-951s
    Notifier FST-951s
    Annunciator:
    Notifier FDU-80
    John Vale Middle School:
    Built in 1993 as the middle school for JVSD. The Cafeteria had its roof collapsed in 2001 due to a insane snowstorm. The Cafeteria was later rebuilt in 2003. There was a addition in 2013 which added a entire new building to the school. The library was also renovated in 2013. There is another expansion in 2018 which added a new wing as well.
    System #1
    Panel:
    Notifier AFP-400 (1993-2013)
    Notifier NFS2-3030 (2013-present) (with DVC retrofitted in 2021)
    Original part:
    Pull Stations:
    Notifier BGX-101L
    Notifier NBG12LXs (used in the rebuilt cafeteria, renovated Library and main office)
    Signals:
    Wheelock MT-24-LSMs
    Wheelock LS1M-24s
    Wheelock MIZ-24-LSMs
    Wheelock MT4-24-WM (outdoor devices)
    Wheelock AS (replaced multiple MIZs and replaced a MT in a stairwell)
    Wheelock NS (replaced several MIZs)
    System Sensor P1224MC (used in the main cafeteria,in the band , Orchestra, and choir rooms)
    System Sensor S1224MC (used as the remote strobes in the rebuilt cafeteria)
    System Sensor P2Rs (used in the renovated Library)
    System Sensor SRs (used in the library)
    Detectors:
    Notifier CPX-551s
    Notifier FDX-551s
    Notifier FSP-851s (used in the library)
    Annunciator:
    Notifier LCD-80 (1993-2013)
    Notifier LCD-160 (2013-present)
    2013 addition:
    Signals:
    System Sensor P2Rs (used in the classrooms)
    System Sensor SRs (used in small rooms)
    System Sensor PC2Ws (used in the hallways)
    System Sensor P2RKs (outdoor device)
    Pull Stations:
    Notifier NBG12LXs
    Detectors:
    Notifier FSP-851s
    Notifier FST-851s
    2021 addition:
    Signals:
    System Sensor SRLs
    Tones and messages:
    Tone:
    Message:
    Detectors:
    Notifier FSP-951s
    Notifier FST-951s
    Pull Stations:
    John Vale High School
    This school was built in 2005 to replace the older John Vale high school. The place had a cafeteria expansion in 2014,new football stadium built in 2015 and a massive expansion in 2021.
    Main School building:
    Panel:
    Notifier NFS-640 with AMG (2005-2021)
    (Tone: Slow whoop. Message: a random message (hard to find a message from the AMG series on the internet))
    Notifier NFS2-3030 with DVC (2021-present)
    (Tone:
    Message:
    http://firealarmcollector.com/database/Voice%20Evac%20Messages/Notifier/English/Female/EF%20Fire%20Evac%20Message%20001.wav)
    Original part:
    Signals:
    System Sensor PC2475Ws (used in the cafeteria)
    System Sensor SC2475Ws (also used in the cafeteria)
    System Sensor PC2Ws (used for the new part of the cafeteria)
    System Sensor P2Rs (replaced a few spectralert classics)
    System Sensor SRs (replaced a fe S1224MCs)
    System Sensor P2RLs (replaced a few classics and 2 advances)
    System Sensor SRLs (replaced 2 classics)
    System Sensor SP2R1224MC (used in the auditorium)
    System Sensor SP2C2475 (used in the A/V room)
    System Sensor P1224MCKs
    System Sensor P2RKs (replaced 2 outdoor devices)
    Pull Stations:
    Notifier NBG12LXs
    Detectors:
    Notifier FSP-851s
    Notifier FST-851s
    Annunciator:
    Notifier FDU-80 (2005-2021)
    Notifier LCD-160 (2021-present)
    2021 addition:
    Signals:
    System Sensor SRLs
    System Sensor SCWLs
    System Sensor SPSRKs (used outside)
    Pull Stations:
    Football field system:
    Panel:
    Notifier NFS-320 (networked to the 3030)
    Notifier NFC-50/100
    (Tone: https://youtu.be/A5Eotk3J6CI message: default FireLite ECC messages)
    Signals:
    System Sensor SRKs
    System Sensor SCWs
    System Sensor SRs
    System Sensor SPSRs
    Pull Stations:
    Notifier NBG12LXs
    Notifier NBG12LOBs
    Detectors:
    Notifier FST-851s
    Notifier FSP-851s
    School district office (built in 2016)
    Panel:
    Notifier NFW2-100
    Signals:
    System Sensor PC2Ws
    System Sensor SCWs
    System Sensor P2RKs
    Pull Stations:
    Notifier NOT-BG12LX
    Detectors
    Notifier NP-100s
    Notifier NH-100s
    Annunciator:
    Notifier N-ANN-80
