Make Up a System (2.0)
McKinley Towers was built in 1976. It is a 12 story apartment building.
Panel
  • Current System: Simplex 4100ES INFOALARM (voice evacuation equipped)
  • Original System: Edwards 5721B
Initiating Devices
  • Current System: Pulls are all Simplex 4099-9001s, all behind Stopper II Covers. Hallways have 4098-9601 smokes above each elevator landing, and above the fire doors. Each apartment has 4098-9754s on 4098-9773 sounder bases. The boiler room has a 4098-9733 heat sensor.
  • Original System: Pulls were a mix of Edwards 270, EST 278, and Simplex 2099 pulls. Hallways had Edwards Ionization Detectors, with a few i3s as replacements, and each apartment had Smoke Sentinel detectors, along with replacement Gentex smokes.
Notification Appliances
  • Current System: Signals here are Simplex 4906-9151 speaker/strobes. These can be found in all hallways, public areas, and the main lobby. ADA apartments have Simplex 4906 series remote strobes. Public restrooms have ceiling mounted 4904 strobes.
  • Original System: The whole building had a mix of 7002s and 892s in the hallways. Most units had 34-24 horns. Some were replaced with Genesis horns and horn/strobes. Some had Wheelock MT24 horns.
Midsummer Place Shopping Centre Milton Keynes, United Kingdom.
Midsummer Place Shopping Centre has 476 stores, 9 of which are anchor tenants, the central part of the shopping centre has access to the toilets, car parks, lifts, stairs and escalators to the upper floor where the food court is, the frog clock that blows bubbles uses a wheel that spins round and swings a pendulum side-to-side, carrying a golden ball from the sun end of the track to the frog/clock end of the track, and spins the wheel and now empty gently swinging side-to-side pendulum back to the sun end of the track, the shopping centre has a 128 zone addressable Vantage Excel system that is connected to the fire alarm systems in the shops, car parks and food court.
Activation devices:
Mainly Vantage S5 manual call points with resettable plastic push elements, a couple of smoke/heat detectors, individual systems in the car parks, shops and food court.
A manual call point activation will initiate a stage-1 fire alarm condition, all alarm sounders in the centre itself will sound the pulsed alert tone, and all strobes in the centre will flash, the panel buzzer will sound to alert staff of the activation, if it is deemed to be a false alarm, the alarms will be silenced, the panel buzzer will be silenced, the call point reset and the panel reset, if necessary to evacuate, staff can manually activate or the panel will automatically activate a stage-2 full fire alarm condition, all lifts will recall to the ground floor, all alarm sounders will be sounding and the alarms in the centre:mk will also go off. The anchor tenants have Apollo XP95/Discovery systems, the air ducts above the frog clock have Vantage 35776 duct smoke detectors that when activated will cause a stage-2 full fire alarm condition.
Stage-1 alarm PA message: Attention please, attention please. A fire emergency has been reported in the centre, please await further instructions.
McDonald’s in the food court has a conventional system with Apollo Series 65 smoke/heat detectors, old style KAC call points with resettable plastic push elements and Fulleon motorised fire bells, the LEGO store has an Apollo XP95 system, the brand new Cineworld has an Apollo Discovery system with it’s own PA message: Attention! Attention! A fire alarm has been activated in the cinema, please evacuate the cinema, thank you.
The car parks have older Gent systems with Gent smoke detectors, panels, call points and fire bells, Burger King has a Gent Vigilon system with S4 S-Quad smoke/heat/carbon monoxide detector sounder strobes/detector strobes and S4 call points with resettable plastic push elements.
Primark has a Notifier system with KAC Notifier new-style call points with resettable plastic push elements and Notifier smoke/heat detector sounder bases/sounder beacon bases set to alternating.
Stage-2 full alarm condition PA message: Attention! Attention! A fire emergency has been reported in the shopping centre, whilst we are investigating the alarm, please evacuate the building using the nearest fire exit, do not use the lifts, use the stairs. Thank you.
Alarm PA message in the centre:mk: May I have your attention please! May I have your attention please! An incident has been reported in Midsummer Place, as such, please evacuate the shopping centre using the nearest fire exit, do not use lifts, I repeat, do not use lifts, use the stairs! Thank you!
The panel in the centre:mk is a Vantage Excel slave panel, the call points are a mixture of older and newer call points, some with resettable plastic push elements and some with glass push elements, various smoke/heat/carbon monoxide/multi-sensor detectors, some are on sounder bases/sounder beacon bases and some are not, KFC has a conventional system, the 12 anchor tenants have Apollo XP95/Discovery systems, the main centre alarms are a mixture of bells, sounders, strobes, bell-strobe combos (rare in the UK) and sounder strobes.
Whew, that was a lot of typing. I am so gosh darn glad I have finished this.
Here’s my made up system
A high school
Indoor NA’s : Gentex SHG’s and Commander 2’s.
Outdoor NA’s : Gentex GMH-24’s and System Sensor MA/SS’es
Pulls : Notifier BGX101L’s
Smoke’s : Notifier FSP-851’s
Panel : Notifier NFS-320
This Is My Make Up System. The Panel Is A Mirtone 7800 Interconnected With An Edwards 6500. The Pull Stations Are Mircom MS-401s, Silent Knight SD500-PSDAs, Notifier BNG1-Rs, Notifier LNG1-Rs, FCI MS-6s, And Simplex MS-301CBs. Smokes Are Simplex TrueAlarms, System Sensor 2400s, I3s, 2412THs, Firelite SD355s, And Notifier FSP-951s. It Is A Mix Of Edwards 439D-10AWCs (C Means Canadian) Edwards MB10-24s, System Sensor SSM24-10s, General Signal MB10-24s, Wheelock MB-G10-24s, Simplex 4030s, Amseco Motor Horns, Mircom BL-10Bs, Amseco MSB-10B-PV4s, Specturalert Advances, Mini Horns, (Siemens UMH-MCS, Gentex GX-90, System Sensor PA400R), Wheelock MTs, (MT-24-LSM-VFR), 7002Ts, EHS-DL1s, NS-24-MCW-FRs, HSR Exceders, Edwards AC And DC Adaptahorns, 10” Durabells, 792s, 892s, 757-7A-HS, And Siemens UMMTs. 4030s Are In Class Rooms, Bells Are In The Hallways, MT Is In Detention, Motor Horns Are In The Principal’s Office, Mini Horns Are In The Home Ec Kitchen, And Specturalert Advances Are Outside. All Set On Continuous. Specturalert Advances Are Set On High Volume.
439D-10AWC
Credit To Edwards Fan For 439D-10AWC. @EdwardsFan What Do You Think Of My Made Up System?
Welcome to the forums!
I do ask if you are going to use my image, to please give me the credit, please and thank you!
Make up system time!
Made Up High school: Built in the late 70’s, finished in 1980. The system had a Simplex 2001 as the main panel, devices were Simplex 4051s on Simplex 4050-80s. Pulls were simplex 4251-30s. Eventually, a few of the alarms went bad and were replaced with anything they could find. This being Edwards Adapta-horns. Eventually, in 1990, the building was added onto, with a Simplex 4002, Edwards 270-SPO pulls, and simplex 4903-9101s with 2901-9838s. Some of the devices were Wheelock 7002T-24s. Devices that failed in the 2000s were replaced with Spectralert Classics, then on, the building was added onto AGAIN! This time, in 2009, and had P2Rs and BG-12s. The panel was an MS-9200. Swapped out for an MS-9200UDLS. That’s it folks!
Massive grammar school in London England, called The London Grammar School, built in 1897 with a weird fire alarm system.
1897 building:
Original system:
240v ac fire alarm system, Vantage Electronic Smoke and Heat Warning Systems Co keyswitch fire alarm panel with break glass and press button call points, 240v ac smoke and heat detectors, Vantage motor bells and incandescent lights for visual signals.
The system was installed and commissioned in 1898 and was decommissioned in 1999 when a 1990s Gent Vigilon Compact system was installed which has been active ever since, but the original fire alarm system remains inactive having not been removed.
Current system:
Gent Vigilon Compact from 1999, 1990s Gent manual call points, Gent 34202 horn sounders on alternating tone, Gent 12511-52 sounders on the master (conventional) alarms circuit, set to alternating tone, Gent 34770 optical smoke/heat sensor sounders set to alternating tone, Gent 3400 heat sensors in some classrooms, a 1990s Gent motorised fire alarm bell in the main reception area. Lockdown tone is continuous on the Gent 12511-52 sounders only.
Science/DT block system:
Originally a wireless EMS 500 system but was removed and replaced with a Gent Vigilon with Gent S4 devices.
New building system:
Apollo XP95/Discovery system, with Apollo Discovery/XP95 intelligent addressable manual call points, Apollo XP95/Discovery smoke/heat/multi-sensor sounder beacon/sounder/beacon bases and detectors only.
Kierenford School’s fire alarm system:
Main building system:
Originally a Gent System 34000 with Gent 34800-EN break glass call points, Gent 17840-01 optical smoke detectors modified to be addressable along with the call points, Gent 34202 horn style sounders.
Current system:
Gent Vigilon Compact from 2003, with Gent Vigilon 32800/32842 addressable call points, Gent 34203 horn style sounders as the Gent 34202 horn style sounders were decommissioned along with the rest of the Gent System 34000 fire alarm system, Gent Vigilon 34770 optical smoke/heat sensor sounders, Gent 34770 heat sensors, Gent 12511-52 sounders on the conventional master alarm circuits, the original system was decommissioned but is still in place.
Gent Vigilon Plus with S4 call points, detectors, S3 sounder strobes and one Gent S3 sounder only.
2 new made up fire alarm systems:
First system:
Clockgate Shopping Centre:
A rather grotty and run down shopping centre full of cheap tacky shops selling absolutely rubbish products at laughably cheap prices, all lifts in the shopping centre were Kone Ecodisc lifts modernised by generic lift companies and have horrendously bad lift logic, motors that need to be replaced, and the lifts are hardly in service.
Fire alarm system:
Unknown system, the main panel is in a security area located in secret floor 3 accessible by using a drop key.
Devices:
Unknown.
PA system:
Generic PA system rack located in the mechanical room. Generic speakers, desks and microphones.
Second system:
In 2018, Clockgate Town Council damaged their reputation when they upgraded the lifts in the shopping centre with cheap, generic lifts that are almost never out of order. In 2019, Clockgate Shopping Centre closed down for good and many YouTubers filmed urban explores of the abandoned Clockgate Shopping Centre which is still standing.
In 2021, a brand new shopping centre called The Clockgate Shopping Centre opened its doors, the shopping centre is nice and modern and in excellent condition, the large main area of the shopping centre has a bubble blowing frog clock with a golden ball mechanism with a wheel and pendulum mechanism, the lifts are The KD Lift Company Limited trading as KD Lift Co M-4000 lifts with VF drive controlled motors that have a soothing hum with epic lift logic, the fire alarm system is a networked system with addressable devices.
PA system:
Kierenford PA Systems Group PA system rack located in the centre management suite next to the main fire alarm control panel, Kierenford PA Systems Group PA speakers, microphones and PA system audio desks, linked to the fire alarm system.
Dale park shopping center
The Dale Park Shopping center was built originally as mall in 1971 going by the name Dale Park Mall. It was a mall that has 2 anchor stores which one of them be a Sears and the other one being a JCPenny.
Dale Park Mall main system
Panel:
Simplex 4208 (1971-1993)
Notifier System 5000 (1993-1999)
A/Vs:
Simplex 4041-61s
Simplex 2901-9806s (replaced 3 4041s)
System Sensor MA (replaced a 4040-60)
Pull Stations:
Simplex 4251-20s
The Mall ended up going under a massive renovation in 1999 and ended up taking the most of the indoor part of the mall out making it a outdoor mall. The system ended up getting removed in 1999 after the closure of the mall. This construction period ended up taking a long time but they finally finished in 2001 with 2 new anchor stores. One of them being a Macys and the other one being a Safeway.
Panel:
Silent Knight 5820XL (2001-2018)
Silent Knight 6820 (2018-2022)
Notifier NFS2-3030 (2022-present)
A/Vs:
Original devices:
System Sensor P241575s
System Sensor P241575Ws
System Sensor S2415s
System Sensor S2415Ws
System Sensor P24110s
System Sensor P24110Ws
System Sensor PC241575Ws
System Sensor SC241575Ws
System Sensor PC241575s
System Sensor P24110Ks
System Sensor S24110Ks
Replacement devices:
System Sensor P1224MCs
System Sensor P1224MCWs
System Sensor S1224MCs
System Sensor S1224MCWs
System Sensor P2Rs
System Sensor SRs
System Sensor P2Ws
System Sensor SWs
System Sensor PC2Rs
System Sensor SCRs
System Sensor PC2Ws
System Sensor SCWs
System Sensor P2RKs
System Sensor SRKs
System Sensor P2RLs
System Sensor SRLs
System Sensor P2WLs
System Sensor SWLs
System Sensor PC2WLs
These A/Vs were kept when the Notifier 3030 was installed.
Pre-3030 system
Pull Stations:
Original devices:
Silent Knight SD-500-PS with the lift flap
Silent Knight PS-SATKs
Replacement devices
Silent Knight PS-DALOBs
FireLite BG12LOBs
RSG RMS-1T-WPs
Detectors:
Original devices:
Silent Knight SD-505-APSs
Silent Knight SD-505-AHSs
Silent Knight SD-505-HDHRs
Silent Knight SD-505-Photos
Silent Knight SD-505-Heats
Annunciator:
Silent Knight 5860R
Silent Knight 5860
Post-3030 system
Pull Stations:
Notifier NBG12LXs
Notifier NBG12LOBs
Detectors:
Notifier FSP-951s
Notifier FST-951s
Notifier DNRs
Annunciator:
Notifier LCD-160s
Sears:
The Sears originally didn’t have a system until 1998 when they renovated the store.
System #1:
Panel:
FireLite MS-9200 (1998-2011)
FireLite MS-9200UDLS (2011-2020)
A/Vs:
Original devices:
Wheelock MTs
Wheelock RSs
Wheelock ASs
Wheelock NSs
Wheelock RSSs
Wheelock HSRs
Detectors:
Original devices:
FireLite SD-300s
FireLite SD-355s
Pull Stations:
Original devices:
FireLite BG8s with mini mods
FireLite BG12LXs
Annunciator:
Original devices:
LCD-40
Replacement:
FireLite ANN-80W
The Sears closed in 2018 and it was untouched until it was converted to a bowling alley in 2020.
Panel:
Potter AFC-1000
EVAX-100
A/Vs:
System Sensor SPSRLs
System Sensor SPCRLs
System Sensor SRLs
System Sensor SCRLs
System Sensor P2RK
Pull Stations:
Potter PAD-100-PSDA
Detectors:
Potter PAD-200-PD
Potter PAD-200-HD
Annunciator:
Potter RA-6500
The J.C.Penny’s had no system until 1994
System #1 (1994-2010)
Panel:
FireLite Sensiscan 2000
Pull Stations:
Original devices:
FireLite BG10s
Silent Knight PS-DA
A/Vs:
Original devices
Gentex GOSs (white ceiling mount)
Gentex GOSs (red wall mount)
Gentex GXSs
Gentex Commander 2s
System Sensor PC2Rs
Detectors:
System Sensor 1400s
System Sensor 5601s
This system got replaced in 2010
System #2:
A/Vs:
Leftovers from system #1:
System Sensor PC2R
Original devices:
System Sensor PC2Ws
System Sensor P2Ws
System Sensor SWs
System Sensor P2WL
Detectors:
FireLite SD-355s
FireLite HD-355s
Pull Stations:
FireLite BG-12LXs
Annunciator:
FireLite LCD80F
The J.C.Penny closure happened in 2019 due to poor sales. It was replaced by a Best Buy in 2021
Panel:
Silent Knight 6808
A/Vs
Wheelock HSRCs
Wheelock HSRs
Wheelock STRs
Wheelock ASWP
Pull Stations:
Silent Knight SK-Pull-SAs
Detectors:
Silent Knight SK-Photo-Ws
Silent Knight SK-Heat-Ws
Annunciator:
Silent Knight 5860R
Safeway:
Panel:
FireLite MS-5210UD (2001-2015)
Simplex 4006 (2015-president)
A/Vs:
Original devices:
Wheelock ASs
Wheelock RSSs
Wheelock HSRC
Pull Stations:
FireLite BG-8s
Simplex 2099-9754 (replaced a BG-8 in the mall entrance)
Detectors:
System Sensor 2100s
System Sensor 5601Ts
Annunciator:
FireLite LED-10
Simplex 4606-9101 (replaced the LED-10 when the 4006 was put in)
Macy’s:
Panel:
ADT Unimode 200 (2001-2022)
FireLite ES-200x (2022-present)
A/Vs:
Gentex Commander 1s
Gentex commander 3s
Pull Stations:
ADT ADT-BG-12LXs
Smoke detectors:
FireLite SD350s
FireLite HD350s
Annunciator:
ADT ADT-LCD-40
FireLite ANN-80 (replaced the LCD-40)
Kierenford Courthouse and Prison Facility:
Fire alarm system:
Main public areas: Gent by Honeywell S4 call points with resettable push elements, S4 S-Quad smoke/heat sensor/sensor strobes/sensor sounder strobes. Gent Vigilon panel.
Info about the building:
All criminal courtrooms have stairs leading to and from the defendant docks to the holding cells and courthouse prison facility where most people found guilty serve their prison sentences at, once the defendant is found guilty, they are taken through the door at the bottom of the stairs in the defendant docks, through the door, down more stairs, and into the courthouse prison facility where they are taken to a cell, the cell door opened and they go inside the cell, the door closed and the key in the door lock turned to the bottom position to lock the door.
Restricted areas of the courthouse:
All other areas of the building have Gent S-Quad detectors and S4 call points with resettable push elements except in the courthouse prison facility where there are S4 key operated call points.
As my last post in this thread was a while ago, I figured I’d post here again.
A bunch of made up fire alarm systems with made up back stories. Enjoy.
System 1:
East Kierenford High School:
Fire alarm system:
First system: none.
East Kierenford High School was built in 1709 as The East Kierenford Boarding School, the school originally had no fire alarm system, only having a homemade sprinkler system consisting of pvc pipes, fire sprinkler heads and a basic electric pump cobbled together in 2 days, the system works as it activated in 1956 when a fire broke out in the Sixth Form classroom after a projector started smoking, sparking, a spark landed on a piece of wood setting it on fire, the sprinkler put out the fire so there was only some minor fire damage, the fire department told the East Kierenford Boarding School to install a fire alarm system in 1957.
Second system (1957-1975):
The system consisted of an AC panel with 2 basic zones, alarm circuit and a trouble buzzer, the 2 zones had call points but no detectors, alarms were motorised bells, in 1975 a lightning strike during a severe thunderstorm hit the building, and fried the panel beyond repair, it was replaced with a 4 zone AC panel.
Third system (1975-1999):
Devices remained the same, no detectors, the panel blew up in 1999 and was replaced again with a much bigger more advanced fire alarm panel.
Fourth system (1999-2000):
The system died in 2000 when the building was severely damaged by a major fire, the school had to close for 2 years when the building was demolished.
In 2002, a brand new building was built on the site of the former East Kierenford Boarding School, the brand new East Kierenford High School opened a year later in 2003.
System 1 (2003-2009):
Very basic conventional system with detectors, bells, strobes for the deaf or hard of hearing people, call points and 4 zone conventional fire alarm control panel, the system was decommissioned in 2009 when the high school was expanded with a new building being constructed.
System 2 (2009-2010):
The system died in 2010, and East Kierenford High School was abandoned and demolished in 2010.
Next system:
Central Kierenford Boarding School was built in 1925 and had a simple and basic unknown fire alarm system installed. In 1956, the system had to be ripped out as new regulations introduced called for a much better and newer fire alarm system.
First system (1925-1956):
Unknown devices and unknown panel.
Second system (1956-2000):
AC panel, bells, call points and detectors.
This system was removed in 2000 when the boarding school was renovated, the system is a networked 6 bay addressable Vantage Sentry Plus fire alarm control panel.
Third system (2000-)
Vantage Sentry Plus with Vantage devices.
Kierenford Boarding School:
Main building:
Fire alarm system:
Networked Vantage Sentry addressable fire alarm control panel:
Devices:
Vantage call points, Vantage strobes, Vantage 34775 optical smoke/heat sensor sounders, Vantage 34776 heat sensors, Vantage motorised fire bells.
Skills Centre:
Vantage conventional panel, Vantage conventional devices.
A 1920s boarding school that has a pretty big history.
Name of school: East Texas Boarding School.
Construction started in 1918 and finished in 1919.
The school opened in 1921 as the East Texas School and originally had no fire alarm system up until 1956 when an Autocall pull rod fire alarm system was installed, in 1975, the system was replaced with a Simplex system with Simplex T-bar pull stations, Simplex whiffleball smoke detectors and Wheelock 7002T-24s on continuous, in 1999, a student got permanently suspended for damaging a pull station and a Wheelock 7002T-24 horn strobe, the pull station was replaced with a brand new T-bar and the Wheelock 7002T-24 was replaced with a System Sensor MASS sounder set to hi-lo alternating. In 2001, the remaining 7002T-24s were disconnected but were not removed as they were still in working condition, the System Sensor installer installed more System Sensor MASSes set to hi-lo alternating, in 2007, a brand new sprinkler system was installed and the flow switch was wired to the alarm circuit in the control panel so when a sprinkler activates it will trip the alarm system.
In 2009, the Simplex panel’s NAC circuit was fried when lightning struck the building, the panel was replaced with a newer Simplex panel, the school eventually closed down in 2010, the building was left abandoned by the school district up until 2017 when the brand new school district renovated and reopened the school building.
Hillside Middle School
Circa 1969
DISCLAIMER: SOME DATES MIGHT BE OFF
in 1970 when finished construction
Edwards 891Ds and Adaptahorns.
In places where horns are not needed, like bathrooms some classes, etc, 890 lamps were installed
Edwards horns only’s were installed in places where lights were not necessary.
1998
Eventually, the system was upgraded in 1998 with EHS-DL1 horn strobes and WS3T strobes.
Devices that failed were replaced with integrities.
Then, in 2009, a lot of the N/As were replaced with Integrities.
In 2016, most to all of the integrities were replaced with EST 757H-75PS devices. Some of the original integrities remain. Outside, there are 3 EST Outdoor integrities.
4 of the original devices remain. Still connected and working to this day. 1 891D in the gym. The horn on this 891D has been replaced with an EST remote horn. 2nd og device is an 891D in the boy’s locker room. Does have its adaptahorn. 3rd device is an 890 Lamp in the drama room. Lastly, and adaptahorn in the girl’s locker room. The strobe got replaced with a WST3 tho.
One 891D remains in an abandoned janitor’s hallway. It is connected to the system but sounds like junk. the light is burnt out and has a hole in it from a janitor hitting it with a broom. did it again and she smashed the horns grill. producing the stupid sound.
That’s it folks!
oops. I forgot to mention the panel. original panel was an edwards 6500 Custom. New panel as of 2022 is an EST3. Pulls originally were 270SPOs. Now are SIGA 270s and 278s
Sharver Convention Center
Sharver Convention center was built in 1975 as a convention center for the city of Sharver. Sharver Convention Center is a older Convention Center that isn’t really used much anymore but is still running. The company who owns Sharver Convention Center built Stanley Pokes Convention Center in 2021 which is much much bigger then Sharver Convention Center. Sharver Convention Center got a massive renovation in 1994 and 2008.
Dates may be inaccurate due to a lack of knowledge
Sharver Convention Center main:
System #1 (1975-1993)
Panel:
Edwards Custom 6500
Pull Stations:
Edwards 270-SPOs
Signals:
Edwards 6100-Ds
Detectors:
Edwards 241s
Edwards 242s
(The parking garage had the same system)
System’s Fate: it was very outdated and didn’t provide enough protection. This system was outdated for 1980s standards. The company decided to renovated the convention center so it was much nicer then it was and also expanded the convention center as well.
System #2 (1994 to present)
Panel:
Honeywell FS90 with voice evac (1994-2008)
Honeywell XLS-1000 with voice evac (2005-2018)
Tone & Message: https://youtu.be/6Sx2UWdbXCI
Honeywell XLS-3000 with DVC (2018-present)
Tone: https://firealarmcollector.com/database/Voice%20Evac%20Messages/Notifier/Tones/Temporal/Temporal%20Horn/Temporal%20horn%204%20PCM.wav
Message: https://firealarmcollector.com/database/Voice%20Evac%20Messages/Notifier/English/Female/EF%20Fire%20Evac%20Message%20002.wav
Original section:
Pre 2008 renovation:
Signals:
System Sensor SS24110ADABs
System Sensor SP-100s
System Sensor SP1W241575ADAs
System Sensor SP1W24110ADAs
Wheelock E70 (replaced a Speaker strobe)
Pull Stations:
Honeywell S464As with mini mods behind them
Smoke detectors:
Honeywell TC806A-1037s
Honeywell TC808A-1027s
Post-2008 renovation
Signals:
Honeywell XLS-G4F-S7VMs
Honeywell XLS-G1F-VMs
Honeywell XLS-GCF-S7VMs
Pull Stations:
Honeywell S464G1007s
Detectors:
Honeywell TC806B-1076s
Honeywell TC808B-1058s
Annunciator:
Honeywell XLS-LCDANN (with remote microphone) (2008-2018)
Honeywell XLS-NCA2 with Remote microphone.
1994 section:
Signals:
Replacement/Devices that were put in later ( like cafes and gift shops) devices:
System Sensor SP2W1224MCs
System Sensor SPSWs
System Sensor SPSWLs
Wheelock E70
Wheelock RSS
System Sensor SWLs
System Sensor SP2C2475s
System Sensor SPSCWs
System Sensor SPSCWLs
Pull Stations:
Honeywell S464G1007s (replaced a few S464As)
Smoke detectors:
Original:
Replacement:
Honeywell TC806B-3010-IVs
Parking Garage #1:
Panel:
Honeywell FS90 with voice evac. (1994-2011)
Honeywell XLS-140 with XLS-NCA2 and DVC. (2011-present)
Tone: https://firealarmcollector.com/database/Voice%20Evac%20Messages/Notifier/Tones/Temporal/Temporal%20Horn/Temporal%20horn%201%20PCM.wav
Message: https://firealarmcollector.com/database/Voice%20Evac%20Messages/Notifier/English/Female/EF%20Fire%20Evac%20Message%20003.wav
(first system in this complex to use a Honeywell rebranded Notifier system)
Signals:
System Sensor V4R24110ADAs
System Sensor SS24110ADAs
System Sensor SP1W241575ADA (in the elevator lobbies only)
Wheelock ET70s
System Sensor SP2R1224MCs
System Sensor SPSRs
Honeywell XLS-G4RF-S7VMs
Honeywell XLS757-7A-RS70Ws
Pull Stations:
Honeywell S464As
Honeywell S464G1007s (replacement device)
Detectors:
Honeywell TC808As
Honeywell TC806As
Honeywell TC806A-1001s (replacement device)
Parking Garage #2:
Panel:
Tone and message: https://youtu.be/6Sx2UWdbXCI
(This is the only system in the complex to use The Signature Series of devices and the only remaining XLS-1000 remaining)
Signals:
Pull Stations:
Honeywell XLS-270s
Detectors:
Honeywell XLS-PS
Honeywell XLS-HRS
LOL speaking of making up a system, if I could invent my own fire alarm system; it would be the Fire Alert 12075-4T horn/strobe. 120 decibels, 75 candela. 4 Tones; It would produce either a steady beep, code 3 beep, code 3 chime or pulse.
Mine, elementary school : Panel is a Simplex 4002, Outdoor alarms are Wheelock MT4 horn strobes, indoor alarms are Wheelock 7002T-24’s in the hallways and the cafeteria has Wheelock MT-24-LSM horn strobes. Smokes are System Sensor 2424’s and pull stations are Simplex 4251-20s.
My old elementary school:
Panel is a Siemens annunciator, 6x Wheelock 7002’s and 7002T’s, a 6" Unknown fire bell, a EXTREMELY RARE Faraday 6170, a RARER FOS 6120 without the strobe (looks like 2 vertical row of 8 or so lines instead of 3 lines on each corner), a 34T, some siemens single strobes, some U-MHU-MCS’, FOS 6120 horn strobes, 2 ZNS’, old inactive Edwards 4" bells, a 4" Wheelock bell, and they go in Continuous. The stations are BG10’s and Siemens MSI’s. (also this is a real system, not madeup.) the smoke detectors are simplex heat detectors.
Its still here to this day and its insane
I thought up all this in a dream I had a few years ago:
A small church in North Florida that was built around 1980. The system was a Simplex 2001 with Simplex 2098-9642 “wiffle-ball” smoke detectors, 4251-1 chevrons, and 2903-9001 light plates with 2901-9806 (B2) horns on 90-bpm march time. The bathrooms had the first-gen 2904-9101 remote strobes. In 1991, all but one of the chevrons were replaced with 4251-20 t-bars. In 1993, one of the 2903s got fried in a power surge, and wouldn’t work even with a new bulb, and it got replaced with a 4903-9101 with a B4 model 9806 on top of it. A double-projector attachment was soon added on. The horns are all tuned to certain pitches, and can be very easily distinguished by them; the B4 is tuned to a D#, and has a very scratchy sound, the B2 model on the first floor is tuned to a D, and it’s 2903 has a yellowed lense, from being mounted very close to a window that faces the sun 24/7, and the other 2 B2s, which are upstairs, are tuned to about an E note.
In 2005, the march time card for the 2001 stopped working, because the code wheel got jammed. They never did replace the panel, because it all still worked, but now the system would be on continuous.
