Been a while since I did this, but with a recent Simpsons episode I couldn’t resist!
NOTE: Some of these systems are based off bits of real-life systems I know.
SPRINGFIELD ELEMENTARY SCHOOL
Originally built in 1951 with an IBM 4216 fire alarm system, with 8" vibrating IBM bells and 4250 break-glass stations. In the cafeteria and the music room, IBM 4251-113 Chevron pulls were installed (if these existed in 1951, I am sure they did). The panel was located in an electrical closet. Break-glass stations were also installed in the classroom. Similarly, the school bells were 6" IBM bells on an old IBM clock system.
In 1964, a couple of IBM break-glass stations were replaced with Simplex 4251-113 Chevrons.
In 1975, a gymnasium wing was added onto the school. A Simplex 4207 fire alarm panel was installed in this new wing, and the signals were Simplex 4051+4050-80s, with 4251-20 pull stations and 4255 heat detectors (rebranded Chemtronics 500-series sensors). This was tied into the existing IBM system in the old part of the building. An IBM bell in the wood shop room was replaced with a Simplex 4050. The class-change bells in this area were 10" Simplex bells, but the gym had the bells behind grilles, while the other bells were not.
In 1978, the school district got a new superintendent (i.e. Superintendent Chalmers), and he disapproved of the existing 1951 section’s fire alarm system and demanded it be upgraded to meet with the then-current codes. So, the school’s old wing had another Simplex 4207 fire alarm panel installed, next to the IBM panel (they didn’t want to pay to remove the old IBM panel and install a more expensive 4208). The system was customized with both panels so it could give out both AC and DC voltage output, depending on the wiring or signals. Several of the old IBM bells, both school and fire alarm, were replaced with Simplex bells (both were 10", but the fire bells were red and behind grilles). Some of the new fire bells also had remote vertical 4050-80 lights with “FIRE” lettering installed. At the end of a few hallways, there was no alarm and the existing bells couldn’t be heard, so Simplex 4051 horns with dual-projector covers were installed there. The cafeteria (and the area outside it) and library and music room also had no alarms, so they installed Simplex 4051+4050-80s in them (with no “FIRE” lettering). Many of the IBM break-glass stations in the hallways and other areas not in classrooms were replaced with Simplex 4251-20 pulls. The school also had smoke detectors installed in hallways, stairwells, and in a couple of mechanical rooms. They were older ESL smoke detectors. They also put in Simplex 4255 heat sensors in other areas where required. 4207-series Simplex annunciators were installed at the main entrance and near the auditorium wing, to supplement the annunciator installed in the gym wing’s entrance vestibule.
In 1987, a Simplex 4051+4050-80 got smashed in a food fight in the cafeteria, so it was replaced with a Simplex 2901-9833 horn behind a 2903-9001 light plate. They also disconnected a few of the IBM break-glass stations in classrooms where there was a pull station outside the room, especially since a few of their students were the mischievous type and liked causing false fire alarms. The old IBM clock panel shorted out, and was replaced with a Simplex 2350 master time panel.
In 1993, one of the students figured out how to fool around with the Simplex 4207 fire alarm panel in the gymnasium wing, and wound up frying it, leaving the wing with no alarm controls. So they had it replaced with a Faraday MPC-2000 panel, and an RDC-700 annunciator replaced the old Simplex annunciator in this wing, too.
In 1999, some of the old IBM school bells were vandalized, so they were replaced, including most of the 10" Simplex school bells, with 6" 2901-9332 bells. Now they were easily able to tell the school bells apart from the fire alarm bells, which were still 10-inch.
In 2003, the Simplex 4207 panel in the 1951 wing shortened out, so they replaced it with a Simplex 4020 fire alarm panel. In the process, all the existing IBM 8" alarm bells, as well as all the 10" Simplex fire alarm bells, were disconnected, and they simply used the class-change bells as the fire alarm. They left the 4051s (and any 4050-80 light plates) connected, as well as the 2903+2901-9833 in the cafeteria, and the remote 4050-80 lights under the old bells.
In 2005, the 4051+4050-80s in the gymnasium were replaced with SAE VA4 horn/strobes, as was the one outside the cafeteria.
in 2007, the 4051 horn in the music room died, so they slapped a Wheelock NS horn/strobe onto the existing 4050-80 light plate!
In March 2010, something awful happened. The school collapsed! (It was, of course, Bart Simpson’s fault.) The students were placed in modular buildings behind the Springfield high school, as well as some students temporarily located to West Springfield Elementary School. Some of the surviving alarms were sold on eBay, but the others that survived the disaster were stored in boxes and held onto by the school’s fire alarm service crew.
It is unknown what the current fire alarm system will be, but it is not a voice-evacuation system (as the school district cannot afford one). Rumor is it will be a Simplex 4010 system with bells.
I may do more Springfield fire alarm systems soon
