Make up a system
The Wakefield Middle School
  1. All of the horns used to be Simplex 4051 horns on 4050-80 lamp plates, but a few of them broke down (though the majority still remains)
  2. A 4051 in the computer lab broke down, so they replaced it with a Gentex SHG instead
  3. The nurses offices 4051 horn also broke down a little later, so that was replaced with a Simplex 4903-9422 horn
  4. The art room’s 4051 horn was replaced with a Faraday 6020 on a Simplex 2903 strobe plate
  5. The auditorium has a Siemens U-HNH horn in place of the broke 4051
Davis High School System:
  1. Main horns are Wheelock 7002T horns
  2. The Media Center has a Gentex SHG
  3. The Performance Arts Center has a Faraday 5940 on a Space Age Electronics AV32 flasher
  4. The Cafeteria has Siemens U-HNH horns
  5. The Gymnasium has Simplex 4041 horns on 4050-80 flashers
Central Elementary School:
  1. The main horns in the elementary school are Simplex 2903+2901-9833 horns
  2. The music room has aWheelock 34T on a Space Age Electronics AV32 flasher
  3. The media center has a Simplex 2901-9846 on a 4903-9105 strobe plate
  4. The multi-purpose classroom has a Edwards 892-2B
  5. The computer classroom has a Amseco BZ-54VT on a Simplex 4903-9101 strobe plate
Holly Grove Middle School:
  1. Main horns are Simplex 4903-9219 horns
  2. The band room has a Gentex SHG horn
  3. The auditorium has a Wheelock 34T on a Space Age Electronics AV32 flasher
  4. The media center has a Simplex 2903+2901-9838 horn
  5. Both locker rooms have Simplex 4041+4050-80 horns
Eugene Ashley High School:
  1. Main horns are the Edwards 892-2B horns
  2. The auditorium has a Faraday 5506 horn
  3. The library has a Simplex 4041 horn on a Space Age Electronics AV32 flasher
  4. The art room has a Faraday 6120 horn
  5. The music room has a Gentex GMS
Morse Elementary School:
  1. Main horns are the Faraday 6226-W horns
  2. The computer lab has a Simple 4903-9422 horn
  3. The music room has an Edwards Adaptahorn on a Edwards 802-2B strobe plate
  4. The library has a FOS 6120 horn with the strobe on the horn itself
  5. And finally, the science room has a Gentex SHG horn
Liberty Middle School:
  1. Main horns are the Simplex 4903-9219s which are also in some bigger rooms
  2. There is a Amseco BZ-51+Space Age Electronics AV32 strobe in the EMD classroom
  3. In the resource room, there is a Edwards 881D-AW+Edwards 892 strobe plate
  4. The band room has a Cerberus Pyrotronics HDC-24C+Space Age Electronics AV32 flasher
  5. Finally, the band room has a Simplex 4903-9237
Knightdale Area High School
  1. Main alarms are Simplex 4041+4050-85s
  2. The Writing Center’s 4041 broke down so it was replaced by a 4051
  3. The auditorium had its horn replaced with a 2903+2901-9838
  4. The media center’s 4041 was also replaced, but with a 2903+2901-9833 horn
  5. Finally, the choral room got an upgrade and got a Simplex 4903-9219 horn
Alfred D. Kohn Elementary School Floor Plan
  1. Main horns are Simplex 2901+2903-9806 horn/strobes
  2. The art room has a Simplex 4051+4050-80
  3. The music room has a Simplex 4903-9422
  4. The library has a Space Age Electronics 2DCD+AV32 flasher
  5. The computer lab has a FOS 6120+AV32 strobe
Why am I the only one posting in this topic? Is this dead? Does nobody wanna make up systems anymore? It seems like nobody cares anymore. What a shame because I did like a few systems.
Belltower high
Firelite bg 6
Simplex horns
colorado school of arts built 1928
In 1933, state requirements made them put in a local alarm system. they put in a gamewell fire panel with masterbox style pulls, and 10 inch gongs. In 1956, they put in IBM pulls, and IBM 4030-1s where the previous system was. the panel was replaced with an IBM panel. In 1965, they added rousch hall. They put in honeywell pulls with LOCAL ALARM across them. they also put in simplex 4050s. the panel was a 4741 panel. the coding is slow marchtime. in 1971, a honeywell broke down. they put in a simplex 4363-1 coded pull in. in 1974, a fire destroyed the rousch hall. they built a huge building called denver hall. they had a 4208 panel with 4050-80s with a single lamp, and no β€œFIRE” lettering, and 4050s. they had 4251-30s with the 4551 heat sensors. in 1974, they also put in a 4208 in the main building with 4050-81s with 4051s, and 4251-20s, and the 4551 heat sensors. the systems are both set to slow march time. in 1975, they built 3 dorms. they had a 4207 each, with 4363-1s, and 4041 horns. they were on slow march time. in 1976, a new science building was built on to the 1928 building. they put 4051s near each exit and 4050-80 remote lights in the halls. in 1977, they built a dining hall. they put in 120 VAC 2903-9001s, with 120 VAC 2904-9001s, and 4251-20s. they had a 120VAC simplex system. in 1979, they built a HUGE new dormitory in the south side of the campus. they put in a 2120 system with 2902s on 2903-9102 strobe plates. they also had 4251-20s with the key switch inside. they had whiffleballs. the speakers were on chime and a voice message sounding after 20 beeps. in 1983, a 4050-81 broke down. they decided to replace the alarm system with a 2001 panel and 2903-9002s with 4051s. they left the pulls. in 1989, they put in a 4001 in on of the dorms. they put in 4901-9002s with 9838s. they left the pulls intact. in 1993, a 4050-80 broke. they put a 4904 vertical strobe where the light was, and left the rest. in 1998, they replaced all the panels with 4100Us and put in 4903 speakers on the strobe plates. in 2013, they put in truealert ESs in with 4099 pulls, and 4098 smokes,with a 4100ES in all the campuses.
Kealing Middle School:
  1. Main horns are the Cerberus Pyrotronics HDC-24C horns which are on Simplex 4903-9101 strobe plates
  2. The library has a DC Edwards Adapt-a-Horn on a 892 strobe plate
  3. The multi-purpose room has an Amseco BZ-54VT on an SAE AV32 flasher
  4. The CIS classroom has a Simplex 4041 on a 4050-80 flasher
  5. The English-Second-Language room has a Gentex GMS horn
Glad to see that this topic is coming back. I like making up systems. We need to have a lot more people try to make up systems. I wouldn’t mind it at all. So I’m hoping to see more posts.
St. Dominic Savio High School
  1. Main horns are Siemens U-HNH S17s
  2. The band and the weight room have Wheelock 7002Ts
  3. The Media Center has a Simplex 4903-9403 electronic horn
  4. The Theology classroom has a Federal Signal 450D+VALS strobe
  5. The journalism classroom has a Faraday 5640+AV32
Now come on everybody! We need to shower this topic more love!
Bucyrus Elementary School:
  1. Main horns are Edwards Adaptahorn DC version which are mounted on 892-strobe plates. A newer addition because before they were just Adaptahorns with no strobes.
  2. The music room which was recently renovated has a Simplex 4901-9805 on a 4903-9105 strobe plate which replaced the Adaptahorn that sounded horrible.
  3. The auditorium has a very loud FOS 6120 that is on a Simplex 4903-9101 strobe plate.
  4. The art room has a Simplex 2901-9833 on a 2903 strobe plate
  5. Finally, the media center has an Amseco BZ-51 on a Space Age Electronics AV32 flasher
    And then we have the middle and high school which is next door: the Bucyrus Middle and Bucyrus High School
  6. Main horns are the Gentex GMS horns
  7. The band room has a Simplex 2901+2903-9806
  8. The media center has Simplex 4901-9822
  9. The auditorium has Space Age Electronics 2DCD+AV32 flasher
  10. Finally, the marketing lab has a Wheelock 7002T-24
I’m still waiting for more people to post more in this topic.
Parkersburg High School:
  1. Main N/As are Simplex 2903+2901-9806 horn/strobes
  2. The Library has a Simplex 4903-9219 horn/strobe
  3. The Auditorium has a Simplex 4904-9101+2901-9838 horn/strobe
  4. The Lecture Hall has a Simplex 4051 horn on a Space Age Electronics AV32 flasher
  5. The Choral Room has a Simplex 4903-9105+2901-9833 horn
I’m wondering if anybody is noticing I’m the only one posting in this topic…
Are we making up a system or naming off systems
As the title of the topic suggests, this thread is for making up systems. Fire Alarms in Buildings 2.0 can be used for naming of interesting/unusual systems.
Ok good thank you
Alpine Middle School:
  1. Main N/As are Simplex 2903+2901-9838 horn/strobes
  2. The Technology Center has an SAE 2DCD+AV32 horn/flasher
  3. The Auditorium has an Edwards 892-1B horn/strobe
  4. The Media Center has a Gentex SHG
  5. Finally, the Drama Room has a Wheelock 7002T horn/strobe
Now that we know what this topic is about now, maybe more people can make up systems again.
Couldn’t the drama room have a black wheelock 7002t
