Make up a system
A little thing about that setup: the Simplex 2001 panel only puts out 120VAC on its NAC(s). So, 9806’s would not work. Sorry, but I had to point that out.
Then if I saw videos and heard 9806s in 90 BPM march time on YouTube, then what panel is it being produced from. :?
A hotel that had fire alarm changes over the time. This was built in the late 1980s.
  1. When the hotel was built, the alarms were 2903+2901-9838’s (C# Tone), and Simplex 4251 T-bars (mostly the -30s but they’re were some -20s) on a Simplex 2001 System (90 BPM March Time).
  2. But in the mid-90s, they replaced all the 2903+2901-9838’s (except one) with Simplex 4903-9219’s, the 4251’s were replaced with -9754s, and the 2001 was replaced by a spare 4002.
  3. Then in the late '90s, the 9219’s on the A side of the building were replaced by 9237s, the 4002 with the 4005, then in 2000, some of the 9219’s in the entrance area were replaced by TrueAlerts (-9425s), and TrueAlert strobes were added in the lavs near the lobby. However, they did one odd thing with the last 9838. They took down the 9838 and put a 4901-9825 SMACKED RIGHT on the 2903 light plate. Coding is still march time (120 BPM).
A middle school is set up like this.
  1. The main alarms are Wheelock MT’s (continuous horn).
  2. The pulls are Edwards 270-SPO’s.
  3. Wheelock MIZ-LSM mini-horns in small classrooms.
  4. Wheelock LSM strobes in the bathrooms.
  5. Some of the MT’s are replaced with Edwards Integrities set to continuous.
A high school is set up like this.
  1. The alarms are Edwards Integrities set to Code-3.
  2. The panel was an Edwards 1212B system.
  3. The pulls are the -1110’s.
  4. The 1212B ended up getting replaced with a Fire-Lite MS-5024UD FACP.
  5. The -1110’s were replaced by Fire-Lite BG-12L’s at the time when BG-12’s were new.
Another middle school has the following.
  1. Edwards 892-1B’s.
  2. ESL T-Handles.
  3. Edwards System.
  4. Wheelock MT’s (continuous horn) that replaced some 892’s.
  5. Edwards 792-7A-006’s in the bathrooms.
Another hotel is set like this.
  1. Fire-Lite BG-10L’s and BG-12L’s.
  2. Wheelock MT’s set to Slow Whoop.
  3. System Sensor SpectrAlerts (don’t worry, there are more MT’s than the Spectras) in Code-3.
  4. Siemens U-MHT-MCS’s set to Code-3 in all the hotel rooms.
The 2001 came in 12, 24 and 120 volt versions.
Ohhhhh!!! Right! I thought: Why are 4051s hooked up to a 2001 if it supplies 120VAC?
2001 panels came in 12 VDC, 24 VDC and 120 VAC versions.
Another middle school is set up like this.
  1. Simplex 4903-9219’s.
  2. Simplex 4904 remote strobes in all bathrooms.
  3. Simplex 4005 (march time) which replaced a 4002.
  4. Simplex -9754 pulls.
The -9754s started to not function properly so they replaced them with Radionics T-handles (similar to the Faraday T-Handle). The 9219s worked fine.
A college.
  1. Simplex 4903-9219’s (main alarms).
  2. Simplex 4904 remote strobes.
  3. Simplex -9754 pulls.
  4. A Simplex 4903-9221 in one area (same characteristics as a 9219 but white) just to blend in with the wall.
  5. Simplex 4005 set to march time (120 BPM).
Yet another middle school.
  1. Simplex 4099-9003 pulls.
  2. Simplex 4010 alarm system (set to code-3).
  3. Simplex TrueAlerts (model 4903-9425).
  4. Simplex TrueAlert Strobes in all bathrooms.
  5. Simplex 4903-9237’s in the classrooms.
3-Floor Office Building:
Older system was:
Simplex 2001
9833s on 4050-80s, some on 4903 Incans.
4251 T-Bars
Whiffle Ball smokes.
Office building was expanded.
New System:
EST/GE Vigilant™ panel (VS2).
Intelligent V-series detectors
EG-1 Genesis Horn-Strobes in halls,
692-7A-HSRs in offices
802-7A strobes in restrooms.
GE Vigilant™ labeled 270 pulls.
Are the EG1’s high output?
A community center is set up like this:
  1. Wheelock AS (older style)
  2. Fire-Lite BG-10L
  3. Fire-Lite MS-5024 alarm system
The panel was set to continuous when the building was built, then in 1998, a tech came by and have the panel do Code-3.
Another middle school is set up like this:
  1. A mixture of Edwards Integrities and EST Genesis’s (set to code-3).
  2. EST3 system.
  3. SIGA-278 pulls.
  4. Edwards Integrity speaker/strobes (wall mount) and EST Genesis Ceiling Mount speaker/strobes in the gym. They do this following message:
All the strobes from the speaker/strobes in the gym are all synchronized.
  1. EST Genesis strobes in all bathrooms.
  2. Edwards 692-7A-HSR’s in the smaller classrooms.
  3. Edwards 892-2B (the only 892 in the building) in the janitors office.
  4. Wheelock MT’s on the bottom of all the stairwells set to code-3 horn. There are the older style MT’s in stairwells A, B, and C while the newer style MT’s are installed in stairwells D, E, and F. This was an addition from late 2001 to early 2002.
  5. Weatherproof Integrities placed outside.
Here is where I will mention where Integrities and EST Genesis’s are located.
Integrity: Some in the halls, the locker rooms, library, technology room, some big classrooms, some of them mounted on the ceiling in the hallways, near the janitors office, near the gym, near some exits, near the courtyard exits, and in the kitchen that’s connected to the cafeteria.
Genesis: In the entrance area, most of them in the halls, near the elevator downstairs, near the stairwells, in the cafeteria, in-house (where students have suspension), the medium sized classrooms, and in one exit area.
Man this topic winds down like a music box!
Anyway, this is a BIIIIIIIIIIIIIIIIIIIIIIIIG system.
This is a hotel system (Holiday Inn). Please note that all alarm systems are interconnected.
  1. The entrance way has 4251-20 T-Bars and the alarms are 2903+2901-9833’s on a 4005 system (march time).
  2. The A side (Rooms 00-24) has 4251’s with 2903+2901-9806’s (4005 FACP in 120 BPM March Time)
  3. The B side (Rooms 25-49) has -9754’s with 9838’s on 4903-9501 100 cd strobe plates (4002 FACP in 120 BPM march time)
  4. The C side (Rooms 50-61) has -9754’s with a mix of -9219s and -9806’s on 4903-9501 100cd strobe plates (4004 set to 120 BPM March Time)
  5. And finally, the D side (Rooms 62-79) has -9001 pulls and Simplex TrueAlerts (model 4903-9426) (4120 set to code-3)
A theater FA system is set up like this
  1. Siemens system
  2. Faraday T-handles
  3. CP U-HNH-S17’s in continuous in the gym
  4. Siemens U-MMT-MCS’s set to code-3 in the newer part of the building.
For a simulation it sounds somewhat like http://www.youtube.com/watch?v=AbvaM91MKvY this.
Ooh, I found another alarm in the basement of that school. A 4901-9805 mounted on the wall! Along with an Edwards 270 Pull under it. I guess Simplex wanted to save money.
Anyway new school and new college.
The college. It is in 2 types.
Type 1
  1. Simplex 4100 System.
  2. Simplex 4099-9001 pulls.
  3. System Sensor Classic SpectrAlert horn/strobes set to Code-3.
  4. System Sensor Classic SpectrAlert strobes in all bathrooms.
Type 2
  2. Simplex -9001 pulls.
  3. System Sensor SpectrAlert Speaker/Strobes with the panel producing the default evac message with the two chimes at the beginning.
  4. System Sensor SpectrAlert Strobes in all the bathrooms.
Now for the school.
  1. Edwards system.
  2. Edwards 892-1B’s.
  3. Edwards 270 pulls.
  4. Edwards 892-7A-HSR’s in the smaller classrooms.
  5. Oddly enough, Edwards 792-7A-005’s are in the bigger classrooms.
  6. Wheelock MT-24-WM’s set to continuous horn in the gym and outside the building.
  7. Gentex Commander2 horn/strobes (red) set to code-3 in the back room in the gym.
  8. Gentex SHG in the boy’s locker room.
  9. Edwards Integrity Horn/Strobe (set to code-3) in the girl’s locker room.
  10. Oddly enough, EST Genesis Remote Strobes are used in ALL the bathrooms.
  11. Siemens U-MMT-MCS set to Vibrating Chime in the basement.
  12. Siemens U-NH-MCS in the janitors room.
This is an old Notifier system from 1983. It is an “outside” school in a rather old part of the town.
It consists of this- a Notifier panel from around that era, model number unknown. It is rather big, and supplies 24VDC to smokes and the NAC. Only 4-wire, non addressable smokes.
In the office, where the panel is, there are D273 Bosch photoelectric smokes. Same with every other room in the school. However, in some older wings and the bathrooms, there are ESL 445Cs. All are mounted surface on Wiremold circular boxes, and some areas like the bathrooms even have exposed Wiremold raceway running across a stack of 2x4s running along the ceiling. One bathroom has one of the newer Bosch photo smokes because the old 445 that used to be there malfunctioned and broke.
In most of the areas, there are Notifier NBG-1 silver pull stations with red lettering. In some of the newer wings, there are Fire Lite BG-10L pulls instead of the older Notifiers
As for the NAC, in the main classrooms, there are PA400Rs with PS24 add on strobes surface mounted on standard single gang metal boxes near the ceiling. The main classrooms have fairly tall peaked ceilings, at about 18’ tall. In the newer wings, there are lower drop ceilings. The newer wings have red vertical Wheelock AS horn/strobes. In the cafeteria, there are 2 Wheelock 7002s on semi-flush plates since the cafeteria is really big. In the gym, right next to the cafeteria, there are 4 C7001s (not T) mounted on the ceiling, one on each corner of the gym. The gym is about 25’ tall, and is 100’ long by 75’ wide. Outside, in the hallways, there are 34-24s mounted on Wheelock weatherproof boxes.
Signal coding is continuous, and the newer vertical AS units are also in continuous.
In a few minutes, I’ll have pictures of what some of the alarms would look like.
Okay, here is a gym simulation. One of the C7001s can be seen flashing. Audio courtesy of cjgoot. (Thank you)
The question is, why did they want to use Simplex alarms?
There is a school building that has three buildings. The first building is the main building, the second one is the overflow and the third one is the gym building. The system is set up like this.
  1. All Hallways and other areas not specified have Simplex 4903-9219s
  2. The bigger rooms have Simplex 4903-9237s
  3. The basic electives (art, music, gym, health & keyboarding) each have fire alarm systems in their rooms. The art, music and keyboarding rooms have Simplex 2903+2901-9838s, while the health room & gym have a Simplex 2903+2901-4050 alarm system
  4. The secondary electives (cooking, sewing, woodworking, mechanical drawing & business technology) also have alarm systems in their rooms. The cooking room, has a Simplex 4051+4050-85 alarm in the cooking room, sewing & mechanical drawing has a Simplex 2903+2901-9806 and woodworking and mechanical drawing working rooms have Simplex 9846s.
  5. Finally, some areas of the school, such as the TV Station, Teacher’s Lounge, Spanish Room, Radio Station and ELT Room have a Simplex GX-90S-4 mini-horn
The overflow building has all Simplex 2901+2903-9833 alarms
The gym has a Simplex 2901-2903+4050 alarm and in the locker rooms and bathrooms have Simplex 4904-9138 remote strobes.
I wish I could find ALL the alarms of Simplex past on their site, but I can’t. I really wish they had them listed though.
You mean the vibratories, 2901s, 2903s, and 4903s? Well, I got an “ID Guide” from weatherdan that only focus on the 4903/4904s. IDK about the vibratories and 2901s and 2903s, though.
gets tired and takes a dinner break
My high school had an old Simplex fire alarm system from 1970 (despite using a newer Gamewell/FCI panel) and though the horns were Simplex 4040s, the pulls were Edwards 270-SPOs. And the Davis Elementary School I keep mentioning, though it has a Simplex 4208 system with 4051/4050-80s, a couple of wings have Edwards 270-SPOs for the pulls, though the rest of the school has 4251-30 break-glass T-bars.
That would be real cool to see those installed like that in an actual gym. In some ways I wish my school had an older system (thats functioning) because the system now is such a standard modern addressable system. Nothing interesting about it.
The only thing interesting about the new fire alarm systems at my college is the choice of components. A Faraday system with Chevron pulls and SAE electronic horn/strobes. Well, only two of the buildings had all the old pulls replaced, and even though the horns are loud (like continuous Wheelock MTs, IMO) they pretty much sound like any other electronic fire alarm horn, probably anything made by Wheelock or an Edwards 892
