My Junior High School has Simplex 4050s on the 2nd and 3rd Floor and 4051s in the Technical Drawing Room and First Floor and they had Edwards 270-SPO pulls. Also, my high school, despite having a Simplex Panel (I think its a 4001), has Edwards 270-SPO pulls in the modular building (but that might be because they have Edwards 982 horns there).
And I figured that is because of two possibilities…
That school used to have an Edwards system with the 270-SPO pulls, but in the 1970s or early 1980s they upgraded the fire alarms with a then-newer Simplex system, but didn’t replace the pulls.
It could be a REALLY old Simplex system from the very early 1970s. My high school, built in 1970, had a Simplex system (now with a new FCI/Gamewell panel) that had 4040 horns, but used 270-SPO pulls. I know Simplex also sometimes used Edwards heat detectors in their systems, too.
Going back on topic, here’s another middle school.
When the school was originally built, the alarms were Edwards 870 AdaptaHorns and Edwards 270-SPO non-ADA compliant local alarm pulls all on a Simplex 4208 system.
But in the mid 1980’s, all the AdaptaHorns got replaced with Simplex flush mount 4050’s except for all of the alarms in some hallways that got replaced by Edwards 874 horns.
Several years later, they took down the 874’s and they put it on Edwards chevron strobe plates (which is similar to the strobe on the 892 series) and they replaced all Edwards 270 pulls with 4251-20 pulls.
But in the late 80’s they replaced the 874’s horn with a Space Age Electronics 2DCD’s on the Edwards chevron strobe plate’s.
In the mid 90’s, they replaced all the 4050s with 4903-9237’s (4903-9238’s in the gym) and added 4903-9219’s in the classrooms and bathrooms and the panel was replaced by a 4005.
In 1998, they replaced the -9238’s and the 4903-9253’s (same as a 9252 but 110cd) and the 9237’s in the locker rooms with 4903-9252.
Then in 2000, they put a Wheelock MT-24-WM in the band room.
Then in 2003, the 9253’s were replaced with TrueAlerts (which non-SmartSync, and 110 cd.
Then in 2004, they added a hallway extension which has System Sensor SpectrAlerts in Continuous along with Simplex Generic T-Bars (2099-9138).
Finally in 2007, they added a new wing which have System Sensor SpectrAlert Advances in continuous along with Wheelock generic T-bar pulls.
Another High School is set up like this.
The Entranceway has System Sensor MA/SS’s (pre-ADA, 800Hz) with Fire-Lite BG-10L’s on a Silent Knight SK-5208.
The bathrooms in that area have Gentex GXS strobes which were added in '96 when codes changed.
The A wing has Gentex GMS’s.
The B wing has Gentex SHG’s.
The C wing has Edwards 892-2B’s.
The D wing has 4903-9220’s.
The E wing has 4903-9252’s.
The F wing has Edwards Integrities set to Code-3.
The G wing has Classic SpectrAlerts in Code-3.
The H wing has Wheelock MT’s set to Code-3 Tone.
An apartment building has the following:
Silent Knight SK-5208 System.
Notifier NBG-10L’s.
Wheelock MT’s set to siren and the panel is coded to code-3.
Uh, I don’t think Simplex was marketing the 4208 panel anymore in the mid-1980s. I believe they stopped making them in the very early 1980s, when the 42-series panels got replaced with the 2001 series. I believe they continued marketing Simplex 4050s in the mid-1980s, since there was a clip online by SimplexTech of a school with 4050s on 2903 light plates
Sorry, I don’t know a lot about fire alarm system timelines. Update: the school was originally built whenever 4208’s were around and they installed a 4208 panel when the school was built.
Another high school which has two panels tied together.
Original System
Simplex 4001 System set to continuous.
Simplex 4903-9217’s.
Simplex 2099-9754’s.
Simplex 4904-9137’s in the bathrooms.
Simplex 4903-9219’s in the classrooms.
An addition was added in the late 1990’s.
The New Addition
Simplex 4020 set to Code-3.
Simplex 4903-9424’s (same as a -9422 but 110cd)
Simplex 4099-9003’s with Stoppers over them.
Simplex SmartSync TrueAlert Strobes in the bathrooms.
Simplex 4903-9422’s in the classrooms.
Here is my imaginary system. It takes place in a big house.
Pannel: Simplex 4100U Voice
Message: Two Code Threes, 4 Slow Whoops, “Attention, Attention, Attention, A possible fire condition has been found in the building, all ocupants walk to the nearest stairway and leave the building, do not use the elevators, do not use the elevators” three times, 20 slow whoops, same message three times, 20 slow whoops, same message three times, 20 slow whoops, same message three times, Code Three until silenced
Outdoor Pullstations: Simplex 2099-9139 (Cast Metal Dual Action T-Bar)
Indoor Pullstations: Simplex 4099-9002 (Break Glass T-Bar)
Gymnasium Pullstations: Simplex 4099-9001 (Single Action T-Bar) with guard wires
Fance Restaurant Pullstations: Simplex 4099-9003 (Dual Action Push-in Pull-Down T-Bars)
Smoke: Simplex 4098-9754 (TrueAlarm Multi Sensor) Sounders in the hallways and big rooms and kitchens, no sounders in bedrooms and smaller rooms
Heat: Simplex 4098-9162E (Simplex E-Series Electric Heat Sensors) without sounders located in the ducts with Simplex 4098-9756 Duct Housings.
Outdoor Alarms: Wheelock ET70WP Weatherproof Speaker/Strobes
Indoor Hallway Alarms: Simplex 4903-9351 (75 cd TrueAlert Speaker/Strobes) in the hallways, and some of the rooms.
Indoor Bedroom Alarms: Simplex 4903-9148 (30 cd Rectangular Speaker/Strobes) in all the bedrooms and most of the other rooms.
Swimming Pool Room Alarms: Simplex 4903-9150H (15 cd Rectangular Speaker/Strobes used for high humidity areas) are in the pool areas (all the alarm devices including the detectors and pull stations are high humidity products.
Remote Strobes: All kinds of TrueAlert strobes are in the house. 4904-9351 (75 cd wall mount strobes) are in offices where there are wall mount alarms. 4904-9357 (75 cd ceiling mount strobes) are in the ceiling mount alarm offices and elevator. 4904-9360 (white 75 cd ceiling mount strobes) are in all the bathrooms. Rectangular strobes 4904-9174 (30 cd) are in the closets.
Ceiling Alarms: Simplex 4903-9363 (TrueAlert Ceiling MountSpeaker/Strobes) are in the parking garage and fancy restaurant in the house.
Wheelock E70: We have these in the spa. We have RSS strobes in the small rooms around the spa.
Speaker only alarms: 4902-9716 (Speaker Only Wall Mount) We have a few of these in the stairwell. 4902-9721 (Speaker Only Ceiling Mount) We have some of these in the garage.
There’s the system. It’s very complex so I may have left out something by mistake.
This time, its an elementary school that I’m doing.
The hallway alarms and in other places unless specified are Simplex 2903+2901-9838s.
Several larger rooms have Space Age Electronics 2DCD horns. 5 rooms have Simplex 4903-9219s, 3 have Simplex 4903-9219s and 4 of these large rooms have Edwards 892-2B horns instead.
The elective rooms have Spectra Alerts.
The library and gym have Wheelock ASs
The Special Ed Wings have Gentex SHGs
A science museum is set up like this.
Main Components
Simplex 4100U system programmed for http://www.youtube.com/watch?v=I6YfsWzCvLI this message.
Simplex 4099-9003 T-Bars with Stopper IIs over them.
Simplex smokes.
1st Floor
The hallways have Simplex 4903-9149’s (same as a -9150 but 110cd).
Activity areas and activity rooms have Simplex TrueAlert Speaker/Strobes.
The bathrooms have TrueAlert Strobes.
McDonald’s Portion
Wheelock E70’s.
Janitor’s Room
A Wheelock MT set to Low volume continuous horn.
2nd Floor
Wheelock E70 Speaker/Strobes.
Wheelock E70 Remote Speakers in some areas.
Wheelock RSS’s in the bathrooms.
3rd Floor
Edwards Enhanced Integrity Speaker/Strobes.
Edwards Enhanced Integrity Remote Strobes in the bathrooms.
4th Floor
Wheelock http://www.cooperwheelock.com/products/speakers/images/speake53.jpg E50’s.
5th Floor (Penthouse)
System Sensor SpectrAlert Speaker/Strobes.
System Sensor SpectrAlert Strobes in the bathrooms
Post #676
A high school is set up like this.
Wheelock MT-24-LSM’s set to Code-3 tone.
Fire-Lite BG-10L’s
Edwards 278B-1120’s located in some areas aligned with some of the MT’s.
Wheelock RSS’s in some bathrooms.
One Edwards Integrity (code-3) located near the art rooms.
Gentex SHG’s (set to continuous) in the Gym.
System Sensor red Ceiling Mount SpectrAlert horn/strobes in the locker rooms set to code-3.
My 700th Post! ![]()
This is a high school that had to go through a lot of changes.
When it was originally built:
Simplex 2001 System (24VDC) (90 BPM March Time).
Simplex 4251-30 Break glass T-bars.
Simplex 2903+2901-9806’s.
Then in the late 80’s they replaced the 2001 with a 4002.
But then in the mid-2000’s, they made HUGE changes.
The 4002 was replaced by a 4100U.
The 4251s were replaced by 4099-9002 break glass T-bars.
An annunciator was added.
The 2903+2901-9806’s were replaced with red TrueAlert Speaker/Strobes.
Here’s the message
[quote] 4 1/2 whoops, "Attention. Attention. Attention. Your attention please. An emergency has been reported. All occupants walk to the nearest stairway exit, and walk down to your assigned re-entry floor or main lobby. Do not use the elevators. Walk to the nearest stairway. Do not use the elevators. Walk to the nearest stairway," repeats itself until it's reset. [/quote]My 710th Post.
This is an AWFULLY big high school with a lot of alarms.
When the school was built
Edwards Panel (from the late 80’s).
Edwards 270-SPO’s.
Edwards 892-2B’s.
Edwards 802 remote strobes in the bathrooms and classrooms.
First additional wing built in the early 90’s
Simplex 4903-9215’s.
Simplex 2099-9754 pulls.
Simplex 4904-9135’s (30cd) in some parts of the wing.
Second additional wing built in the mid to late 90’s (some point in the 1996 era)
Wheelock MT-24-LSM’s set to Code-3 Tone.
Edwards 270-SPO’s.
Wheelock LSM Remote Strobes.
Wheelock MIZ Piezoelectric Horn/Strobes in the classrooms.
Third additional wing built in 2000
System Sensor SpectrAlert Classic Horn/Strobes set to Code 3 Mechanical.
The SpectrAlert horn/strobes in the classrooms are set to 3000Hz.
Fire-Lite BG-12L’s.
SpectrAlert Advance Remote Strobes (model SR’s set to 15cd) were added in the bathrooms in 2007.
Fourth additional wing also built in 2000
Simplex TrueAlert Horn/Strobes (non SmartSync, 110cd)
Simplex 2099-9754’s (with the newer Simplex text and logo, which looks like a 4099-9001)
Simplex TrueAlert Strobes in the bathrooms.
Fifth and final additional wing built in 2004 (Algebra Wing)
Gentex Commander3’s set to the factory default tone (code-3 mechanical tone).
Notifier NBG-12L’s.
Gentex Commander3 strobe only’s in the bathrooms.
Doorway entrance extension (2003)
EST EG1 Genesis Horn/Strobes (code-3, no “FIRE” lettering)
Edwards 278B-1120 Pulls.
Main Components
The cafeteria has 24 Volt Wheelock 7002T’s.
The gym has Gentex SHG’s set to continuous.
The locker rooms have U-MMT’s (older style, set to code-3).
The pool room has BRK-MA/SS’s set to Slow Whoop and a Fire-Lite BG-10.
The old 270-SPO’s were replaced with newer 270-SPO’s after 1996 which are ADA compliant. The old Edwards Panel was later replaced by an EST Non-Addressable Panel in 2001.
Whew! That’s a lot of typing!
This High school was built in 1990, With 3 wings. The alarms are:
Wing 1 (Simplex):
Hallways:2901-9806s
Classrooms:2901-9838s
Bathrooms:4904-9105s
Library:4903-9422s
Gym:4903-9425s
Pulls:2099-9795s,2099-9756s
Panel:4100
Wing 2(Edwards):
Hallways:8" Adaptabels
Classrooms:874-N5s
Bathrooms:202-8A-101
Library:Integretiys
Gym:6" Adaptabels
Pulls:270-SPOs
Panel:Custom 6500
Wing 3 (Cerberus Pyrotronics):
Hallways:HDC-24Cs
Classrooms:MTL-S15-Ss
Bathrooms:S15-Ss
Library:U-HNH S17s
Gym:MTL-S15-S
Pulls:MS-501,MS-51
Panel:FireLite MRP-2001
Soon, In 2000, 3 New wings were built. Here are the alarms:
Wing 4 (Wheelock):
Hallways:AS-24-110s
Classrooms:MT-24-LSMs
Bathrooms:RSS-24110Ws
Library:MIZ-24S-Rs
Gym:NSs
Pulls:MPSs
Panel:Mircom FA-100
Wing 5 (System Sensor):
Hallways:P2R
Classrooms:MASS24110ADA
Bathrooms:S1224MC
Library:P1215
Gym:P1215
Pulls:Cerberus Pyrotronics MS-151
Panel:Simplex 4001
Wing 6 (Mix):
Hallways:Simplex 2901-9838s
Classrooms:Edwards 874-N5s
Bathrooms:System Sensor S1224MC
Library:Cerberus Pyrotronics U-HNH S17s
Gym:Wheelock MT-24-LSMs
Pulls:Edwards 270-SPO, Simplex T Bar, Cerberus Pyrotronics MS-151
Panel:Simplex 4100
Then, In 2008, The systems were replaced with a Mega Mircom system, With Mircom Select-A-Horn/Strobes, Mircom Select-A-Strobes, Mircom MS-400 and MS-700 Pull Stations, And A Mircom
FX-2000 panel.
The Simplex 4100U didn’t come out until 2002. Instead, the 4100 was around then. I think it (the Simplex 4100) came out in the late 1980s.
A big hotel system with 6 floors and a ground level.
Panel
Silent Knight SK-5207
Corridors from the 1st floor to the 5th floor
A mixture of Gentex GMS’s and MT’s (continuous horn).
Fire-Lite BG-10L’s.
Entrance and Restaurant Areas
System Sensor SpectrAlert Classic Horn/Strobes (C3 and 30cd).
Fire-Lite BG-12L’s.
Bathrooms in the reception area
Instead of SpectrAlert Classic strobes, they put RSS strobes because they are near the MT’s.
Hotel Rooms (1st-5th floor)
Wheelock MIZ-24-LSM’s
Gentex GX90’s (w/ strobes; 15/75 cd)
Indoor Swimming Pool
Wheelock MT’s (continuous horn) and Fire-Lite BG-10L’s.
Fitness Center
Gentex HS Commander set to Code-3 and strobe is 15cd.
TV and Entertainment Halls
Wheelock MT’s and BG-10L’s
Elevator Area (Applies to all floors)
Gentex GXS Remote Strobes
New Addition (2003)
Wheelock E70-24-MCW’s (synchronized; 15cd)
Wheelock MPS Pull Stations
Voice Evacuation is a Silent Knight voice evac
Rounds of Code 3 “Star Trek” Whoop Attention please. There has been a report of an emergency. Proceed calmly to the nearest exit, and leave the building. Do not use the elevators. Use stairwells where necessary. All handicapped occupants shall use the building evacuation plan. Repeats
6th Floor (What alarms that used to be there)
Gentex SHG’s (Hallway; Code 3)
Fire-Lite BG-8’s
Gentex GX90’s (Hotel Rooms)
6th Floor (What’s there now)
System Sensor SpectrAlert Advanced (P4R’s; Code 3; 30cd; Medium volume)
BG-8’s were replaced by Notifier NBG-12L’s due to BG-8’s being easily pulled which would cause false alarms.
SpectrAlert Advanced MHR and SR (15/75cd) (next to each other) (Hotel Rooms)
Outside
Wheelock 10" Bell on a WM Strobe Plate.
This is how I’m organizing the fire alarms and their locations from now on. Look pretty neat, don’t you think?
I’ll mention two schools.
A school in California has Edwards 892 horn/strobes in big classrooms and in several halls and Edwards 892 speaker/strobes in smaller classrooms and in some hallways, and Edwards 270-SPO pulls.
The speaker/strobes do this message: http://www.youtube.com/watch?v=L12EPTkzVtw
Another school in PA (about 5 mi near Hersheypark) has:
Edwards 892-1B Horn/Strobes (main alarm) in halls and bigger classrooms
ESL Lift and Pull T-Bars
3. System Sensor MASS’s in small classrooms set to 1200Hz Interrupted
Simplex 9219s in the Gymnasium (along with Simplex 2099-9754 pulls), Health Rooms, Locker Rooms, and some Science classrooms.
A “Classic” SpectrAlert in one exit area and a weatherproof Spectra right outside the area.
An Edwards 270-SPO and Edwards Integrity set to Code-3 in the Janitor’s room.
A Wheelock MT (set to Hi-Lo) on the Bottom of all the stairwells.
Wait a sec. Those were BRK-MA/SS (Pre-ADA) set to 2400Hz steady in the classrooms.
Here are two high schools built near the late 70’s to the early 80’s era that had to go through some changes.
High School #1 (Hilton McCarthy High School)
Main Components
Simplex 4251-20’s.
Simplex 2901-9806’s by themselves and some of them hooked up to 2903-9001 light plates along with the vandal resistant grilles installed.
The Renovation (2002)
New Components
The 2001 was replaced by a 4010.
The 4251’s were replaced by 4099-9003 dual action T-bars with Stopper IIs over them except for the gym, office, auditorium, and the cafeteria.
The 2901-9806’s were replaced with SmartSync TrueAlert’s.
The 2903’s were replaced with a trim plate due to having a big hole in the walls.
SmartSync TrueAlert Strobes were added in the bathrooms.
When silence is pressed, the TrueAlert’s pulse 4 times then silence.
High School #2 (George Henry High School)
Main Components
Simplex 2001 System (24 VDC)
Simplex 4251-20 T-bars
Simplex 4041s on 4050-80 light plates
The renovation of 2004
New Components
The 4041/4050-80’s were replaced by TrueAlerts (4903-9426’s in the hallways, cafeteria, gym, and auditorium; 4903-9425’s in classrooms, locker rooms, storage rooms, and in the janitor’s office)
The 2001 was replaced by a 4005 and the 4005 is programmed for Code 3.
The 4251’s were kept.
I’ve never heard of a Simplex 4041 horn before.
It’s a 4040 style 4051. buggiecar has one of those.
It looks like it has a silver sounder plate inside. Now that I mention it, I recall seeing a fire alarm system at the place where they held the temporary public library when they were expanding/renovating the old one. That building had what appears to be an old Simplex system, judging by the annunciator. It’s like the one at my high school, complete with Federal Signal flush-mount FG grilles. But the horns in them weren’t 4040s like my high school; they had silver sounder plates in them! I guess those were Simplex 4041s. The pulls were Edwards 270-SPOs.
Come to think of it, I wonder if Simplex ever rebranded the Federal Vibratone 350 with the newer grille? (they did so with the newer 450/2901-9806)
