Make up a system
OK, as promised that I would make up a system that have the GX90’s taken down from that building, which is an apartment building, and here it is!
Original System
  1. Simplex 2001 System (Type 2 march time)
  2. Simplex 4251-20’s
  3. Simplex 2903+2901-9838’s
Mid-90’s Upgrade
  1. The 2903’s were replaced by 4903-9501’s and the 9838’s were kept.
  2. The panel was upgraded to a 4002 (set to continuous).
  3. The 4251’s were replaced by 2099-9754’s.
  4. Some of the 4903-9501+2901-9838’s were replaced by -9219’s.
  5. Simplex rebranded Gentex GX90’s (Red) were added in the apartments a few years later.
2002 Upgrade
  1. All Alarms were replaced with Simplex TrueAlerts (110cd in the entranceway; 30cd in the corridors).
  2. The GX90’s from the apartments were replaced by Edwards Mini-Horn/Strobes (thus having the GX90’s to be ready to be hooked up to the FA System I mentioned in that quote).
  3. TrueAlert strobes (15cd) were added in the bathrooms.
  4. BIG CHANGES → the 4002 was replaced with a 4100 (which is set to code-3) and an annunciator was added.
  5. The 2099-9754’s were replaced by 4099-9001’s.
  6. Then in 2007, they have added outdoor signals, which are System Sensor weatherproof SpectrAlert Advances (P2RK’s) which are independently set to High volume code-3 and the strobe is set to 115cd.
And there you have it. Also, after the upgrade, there were 20 spare GX90’s and they ended up selling them on eBay.
If I am not mistaken, the 4040 is AC and the 4041 is DC.
I meant that it looks like a 4040.
The BRK is not necessary unless the alarm is made by BRK. And the / is not necessary either. Remember- Model numbers are different when alarms are rebranded.
BRK:
BRK MA/SS
System Sensor:
MASS
This is the system for the Caleb Rodney Elementary School in Delaware:
The First Building (which has K, 1st, 2nd, 3rd Grade, Itinerants, Computer Room) has all Simplex 4903-9237s. (continuous)
The Second Building (which has 4th, 5th, 6th Grade, Cafeteria, Library, Gymnasium), has all Simplex 4903-9219s. (continuous)
The Kindergarten Wing has 4051+4050-80s (continuous)
The Itinerant Wing has SAE 2DCD horns (continuous)
Each room there has Wheelock MIZ horns (continuous)
The Bathrooms all have TrueAlerts (continuous)
The Gymnasium has 2903+2901-9806’s (continuous)
The Locker Rooms have Gentex SHGs (continuous)
The Computer Room has a SpectrAlert Advanced (Code-3)
All the Special Ed rooms have Wheelock NSs (set at a VERY low volume) (Code-3)
The Library has a lone Edwards 892-2B alarm (continuous)
The Cafeteria has Wheelock 7002Ts (continuous)
The walkway that connects the two buildings has 5 Mircom Select a horn strobes (continuous)
Here’s a big middle school.
Panel
Notifier non-addressable panel
Main Components
  1. Edwards 892-2B’s
  2. ADT 5050-001 pulls
Bathrooms
Edwards 202-8A-T strobes that replaced broken Edwards 802 remote strobes
Cafeteria
Simplex 4903-9237’s
In-House and Detention Rooms
System Sensor “Classic” SpectrAlerts
Art Rooms
Edwards Integrities
Home Economics Room
Edwards 792-5A-006
Technology Room
Wheelock MT-24-LSM (Code-3 Tone)
Gymnasium
Simplex 2901-9838’s on 4903-9501 strobe plates
Gym Lockers
Wheelock AS’s set to low volume code 3 and set to 15cd
Auditorium
  1. Cerberus Pyrotronics MTL’s set to Code 3
  2. Cerberus Pyrotronics MS-501 Pulls
Janitors Room
EST Genesis EG1 Horn/Strobe
7th and 8th Grade Halls (New Addition)
1st Floor
  1. SpectrAlert Advance P2R’s set to code 3.
  2. SpectrAlert Advance MHR’s set to code 3 in the small classrooms.
  3. Notifier NBG-12L’s
2nd Floor
  1. System Sensor SpectrAlert Advance SCR’s on the ceilings.
  2. System Sensor SpectrAlert Advance HR’s on the walls.
  3. Same pulls as of on the first floor
I’ll get more detail on this later
The David R. Porter Middle School in Pennsylvania.
  1. Hallways contain Gentex GMSs
  2. The bathrooms have Simplex 4903-9237s
  3. The teachers lounge has a Wheelock 7002T
  4. The gymnasium has Wheelock NSs
  5. The cafeteria has 2903+2901-9806s
  6. The lecture hall has a Wheelock 7002T
  7. The ESL room has a SAE VA4+2DCD horn
  8. The Computer Lab has a Wheelock MT-WM-VFR
Here are 3 schools.
Middle School #1
Panel
EST3 System set to 30BPM March Time.
Components
  1. Wheelock AS-24MCW-FR’s
  2. SIGA-278 pulls
  3. Wheelock RSS-24MCW’s in the bathrooms.
Note: All the strobes and horns in the school are syncronized.
Middle School #2
Panel
EST3
Components
  1. Wheelock MT-24MCW-FR’s set to: (1) High Volume Code 3 Horn in the halls, nurses office, guidance office, and gymnasium; (2) High Volume Code 3 Tone in the health rooms, tech room, health corridor, locker rooms, and some science classrooms.
  2. SIGA-278 pulls
  3. Wheelock RSS-24MCW-FR’s in the bathrooms.
  4. Wheelock MIZ-24S-R’s set to code 3 in the classrooms.
Note: All the strobes and horns in the entire school are synchronized.
Middle School #3
When it was originally built
Panel
Simplex 4001 (March Time)
Components
  1. Simplex 4251-20’s
  2. Simplex 2903+2901-9833’s
The Renovation in the mid 90’s
  1. The 2903+2901-9833’s were replaced by Simplex 4903-9215’s and -9219’s were added in the classrooms.
  2. The 4251’s were replaced by 2099-9754’s.
  3. The panel and march time was kept.
Major changes in 2007
  1. The 4001 was replaced by a 4005 and codes changed to code 3.
  2. The alarms and the pulls were kept.
Building Expansion
  1. They added a Simplex 4100.
  2. A 4603-9101 annunciator was added.
  3. The pulls are 4099-9001’s.
  4. The alarms are SpectrAlert Advances (code 3; horn/strobes in hallways and other major parts, remote strobes in bathrooms, MHR mini horns in the small classrooms; weatherproof horn/strobes outside).
The alarms in the newer part of the building are synchronized, however, the alarms in the main part of the building are not synchronized.
The Woodrow Wilson High School over in New Jersey. Here is how the kind fire alarm companies over there set it up.
  1. Simplex 4901-9805 horns in the hallways
  2. The main gym has all Edwards Integrities
  3. The auxiliary gym has Wheelock ASs
  4. SAE V44+Wheelock 7002T horns in the Guidance Rooms
  5. Gentex Commander 3s in the Assembly Rooms
  6. Wheelock MIZs in some of the classrooms
  7. Wheelock NSs are in the bathrooms
  8. Wheelock WMs inhabit the cafeteria
  9. Simplex 4050s on 2903 strobe plates are in the library
  10. EST Genesis horn in the Psychologist Room
  11. Siemens U-MMT horns the administration office
  12. The In-House Center has a Simplex 2903+2901-9838 horn
The Merge Corp. office building in California (where Charlotte Pickles works) has its current fire alarm system as the following:
It is powered by three Simplex 4100 panels and a Simplex 2001 panel (that uses AC voltage).
The parking garage has the following alarms, and there are LOTS of them there! They have Wheelock ET-1070-LSM-24 speaker/strobes, Simplex 4050 horns on 4050-80 light plates (without “FIRE” on the lens), Simplex 2901-9833 horns on 2903 light plates, Wheelock MT-24-LSM horn/strobes (some are set to Code-3 horn, some are set to Slow Whoop!), and Simplex 4090-1 6-inch bells mounted behind red grilles. The pull stations are a mix of Simplex 4251-30 break-glass T-bars and 2099-9756 dual-action T-bars. Smoke detectors are a mix of Chemtronics heat detectors and Simplex 2098-9201 photoelectric smokes.
The main building complex just has Simplex 4903-series speakers mounted on 4903-9501 retrofit plates that use 4904-9105 strobes. All the pulls are 4099-9001s. The smoke detectors are 4098-9792 TrueAlarms. There’s a 4603-9101 annunciator near the main entrance. The restrooms and small offices have 4904-9105 remote strobes.
The first 4100 panel controls all the alarms in the main building. It does three slow whoops, plays the standard Simplex voice evacuation message three times, then continues slow whoop until it is silenced.
The second and third 4100 panels are tied together, and so is the 2001. They power the alarms in the parking garage. The 2001 is hooked up to the 4251-30s and 4050/4050-80s and 4090s and Chemtronics heat detectors. It has the horn/lights sound on 90 BPM March Time. A special relay has the bells sound on Continuous. 4100 panel 2 operates the Wheelock speaker/strobes, making them do constant slow whoop. It also powers the 2903+9833s, and sets them on 120 BPM March Time. 4100 panel 3 operates the Wheelock MT-24-LSMs, and is set on Continuous so the horns can do their correct sounds without any trouble. It also plays the Simplex voice evac message once on the PA speaker system in the garage. All the other pulls and smokes in the garage are also hooked up to this panel.
The parking garage fire alarm system goes off separately from the main building’s alarm system. It goes off in a unique manner, too: Upon activation of the system, first the 4050/4050-80s activate in their 90 BPM March Time and the voice-evacuation message plays for 13 seconds, after that, they continue, but all the other alarms activate as well! It causes the whole garage to shake!
BTW: I based this alarm system off the Rugrats episode “Mommy’s Little Assets,” and made up an alternate version of the car alarm scene where Angelica accidentally triggers the fire alarm system instead of a car alarm. She walks backwards into a 2099-9756 pull station, causing it to open and the 4050s and voice-evac messages to begin. “Hey Mommy! Neat, a fire drill!” she says, but Charlotte is too busy talking on the phone and holding Tommy. She talks to Jonathan on the phone, and when the main alarms go off and the building shakes as lights and strobes flash, Angelica says “Cool!” and Tommy begins bawling. Charlotte shouts into the phone, “I can’t hear you! The fire alarm just went off! It’s a Zone 3 pull station on Level 2. Have it reset!” They go in the elevator to go up, and Charlotte reassures Tommy telling him “No more bells.” as the alarms fade. Tommy smiles, and the episode continues as normal.
I’ll try and make an audio simulation someday
Wow. That sounds kind of scary if you ask me. I’ll bet the simulation would sound scary.
I added dialogue by Charlotte, Angelica and Tommy from the original episode to the fire alarm sounds to make it more entertaining
The Edward Telfair Elementary School in Georgia
Hallways have a Wheelock NS
EST Genesis’s in the Resource Room
Simplex 2903+2901-9838s in the ESL Room
The Music Room has a Edwards Integrity
Some of the classrooms have Simplex 4903-9219s
The OT/PT room has a Simplex 4903-9236
Special Ed rooms have Simplex 4051 horns
Enrichment Rooms have Simplex 4050 horns
The Teacher’s Room has a SpectrAlert Advanced
The Art, Library & Reading/Literacy Room has a Wheelock MT4 horn
Speech Therapy has a Radionics D503S
The Conference Room and the Teacher’s Workshop Room has a Wheelock MIZ
Bathrooms have Edwards 892-2B horn
The Kindergarten Area has a Siemens U-MMT (new one)
The newer U-MMT is called the U-MMT-MCS.
Actually, the MCS means mulit-candela. Basically the Siemens way of saying MCW.
OK, I’ll check the U-HNH horn/strobes at my college to see if they are multi-candela. If they aren’t, then aren’t they just called U-HNHs?
I think so, followed by the candela. So, a multi-candela one would be U-HNH-MCS, and a fixed 15 candela would be U-HNH-S15.
The Thomas M. Waller Middle School in Connecticut
Hallways have Wheelock Model 3300 horns/lamps
The third floor has SpectrAlert horn/strobes
We have a Simplex 2901+2903-9833 horn in the computer lab
Wheelock 34T horns in the Detention Center
The gym has 8 Gentex Commander 3s
The locker rooms each have one TrueAlert
The bathrooms have Wheelock 7002Ts
The Music, Library, ESL Room, Auditorium & Speech Room has a U-MMT horn (older version)
There is a Wheelock 7002 horn in the Common Room & Performing Arts Center
The Portable has Simplex 2903+2901-9806 horns
The Technology Center, Conductive Education Unit, International Students Center, Staff Center, Woodshop & Food Service Rooms have Edwards Integrities
The Spanish Room and the IKON room both have Simplex 4030 horns on the 4050-58 lamp plate
The Chorus Room, Reading Room & Elevator Room has Wheelock AS
EST Genesis horns are in the Auditorium
The parking garage has a Edwards Integrity
The Aquaculture Room, Pool Area, Most of the Science Labs & The Technology Center has Gentex SHGs
The Spanish Room and the IKON room both have Simplex 4030 horns on the 4050-85 lamp plate
