Specs: 10 zones minimum, but can go up to 30. Can have multiple emergency types. Can use Alterator C-Series indoor multi-signal horns. It also has automatic door release and can support agent release. I will list more once I figure out what they are. (Any input is appreciated)
Exactly! The USB ports underneath work as a failsafe option - you can plug in a generic mouse and continue to operate the panel if the touch is not responding.
I would also like to add that there are 5 possible signals: alert, wail, pulse, pulse wail, and air horn. The signals can be set to mean different emergencies.
Yes there will be. I’m still in the process of designing them and will give an update when they are done. There will be remote versions and versions that can be paired with horns.
