Daaaaaaaaaaaaayum! Then that means it’s rare!
Yes indeed! I found it on eBay
That’s a neat one! The addressable module looks surprisingly compact for its age; it’s quite a contrast with the massive Edwards pull station/transponder you recently acquired.
I was thinking the same thing—this seems to be a rather uncommon version. I’ve come across these pull stations once (at a hotel in Boston), although I doubt that they were addressable models as the building appeared to have a newer EST system:
Interestingly, I’ve seen a photo of a 4050 with the older-style black body and later “Thorn Autocall” branding. I wouldn’t have expected such a variant to exist, and I have no idea if it’s older or newer than this one.
It’s funny because the transponder/pull assembly was made in '99 while the autocall pull was made in '92
Probably had some new ones left over in stock tbh.
No I think they were still supporting the ESA-2000 in '99
Same thing happened with the Simplex 4100 Classic, but they supported it longer I think.
Cursed Cerberus Pyrotronics
Actually it’s not cursed, its real
I decided to buy one of my holy grails, a gamewell m46-30. Now this pull had and still has some issues, first of all I had to replace the front cover because the cheap mild steel screw snapped off ( god forbid they use stainless steel screws ) and the back housing on the toggle switch is loose, the switch sounds normal tho. It’s also missing the little stainless steel bezel for the keyswitch. Despite all its issues its a fairly solid pull
General alarm century. I think @HenBasket owns one.
Yes he infact does, his is nicer than mine
It’s rare outside Canada nevertheless.
I don’t know why I didn’t post this sooner, I guess I forgot but I decided to get a first gen gamewell MS-95
I also compared the first and second generation modules
First gen century reminds me of…
First gen S464A
I haven’t been on here in quite a while but I recently acquired this very rare Canadian dual stage 2099
And it’s addressable too. I’m actually looking to get some acquisitions myself soon as well, from Walters State. I actually already have some.
That’s a neat find! Looks like it’s in fantastic condition.
I didn’t know that Simplex offered these pull stations with an addressable GA keyswitch. A fellow enthusiast showed me a nearly identical pull station (from 1993, if I’m not mistaken), but it had a conventional keyswitch with wire leads (and, therefore, only one board for the addressable module). I had assumed that they were all configured in that manner.
Yeah I think I know who you’re talking about, from the dates that I’ve seen on the switches and the plastic front, this pull station is either from 1994 or 1995. Which is interesting because this pull has a silver backplate I’m pretty sure the American addressable 2099’s had red painted backplates in 1995. Another interesting thing about this pull is you can take the pre sig key out in the gen alarm position. Usually those arrow hart style key switches are key retaining in the gen alarm position.
