So I bought two alarms on eBay, both simplex. However, whenever I apply power to them, only the strobe lights flash. The models are simplex 4903-9217 and simplex 4903-9419. The second is a truealert, and I realize its a smart sync model, but what about the 9217? I use 3 9 volt batteries to power them, but only the strobes flash. Please help!!
Yes to the 9217. But even when I did it just made the strobe flash. The 9419 is a truealert, a non-addressable truealert. And all that one did was flash once…
The Truealert that only flashes once has the older Smartsync protocol. You’d need to pulse the strobe current at 60BPM to get the 60 flashes per minute effect you see on other strobes. I think you can also get a Smartsync module to do this.
I’m not familiar with the newer addressable Truealerts but I suppose they are two-wire and therefore use Simplex’s newer SmartSync protocol - coded pulses.
