Listed here is my collection of panels, NAs, and initiating devices. The list is a little long, so I will keep my little “intro” here short and sweet. PLEASE don’t ask for anything. If something is for sale, it shall be found in the flea market. I apologize if I miss or misspell something.
Ademco:
2 - Model 502 Heat Detectors (135F)
4 - Model 529 Pull Stations (with several extra rings)
Chemetron:
1 - Model 502 Heat Detector (190F/ROR)
4 - “Stairgurad A” Heat Detectors (135F)
Edwards
1 - 270-SPO Pull Station
1 - 270A-SPO Pull Station (A = Wire Leads)
1 - 282B-PL Heat Detector (194F/ROR)
5 - 283B-PL Heat Detectors (135F)
2 - 340-T Adaptabels (Trouble Bells, Square “Cow” Gongs)
1 - 384 Adaptahorn
1 - 52R-N5-40WH Adaptabeacon
1 - 894B-001 Remote Strobe
Faraday
6 - 6120-5511 Horn/Strobes (1 Strobe Non-functional)
1 - 2600-5511 Speaker/Strobe
4 - F1GT Pull Stations
1 - F9962D Remote Lamp
Federal Signal
1 - VALS Strobe (24V, “HALON”, Ceiling Mount)
1 - Vibratone 350 (120V, Series A1, Paired with Fire Lite Light)
1 - Vibratone 450D (24V, Series B4, Paired with the AV-32)
1 - PA-20A “Interceptor” Siren (Not exactly a fire alarm, but still)
Fire Lite
1 - Fire Lite Triangular Light (120V, Model Number Unknown, does one exists?)
1 - BG-6 Pull Station
1 - BG-10 Pull Station
1 - BG-12 Pull Station
1 - Miniscan 124 FACP
1 - MS-5012 FACP
Gentex
1 - GEC3-24WR
Napco
2 - FW-CO1224 Carbon Monoxide Detectors
2 - GEM-P3200 Panels
Silent Knight
1- SK-6324 FACP
Simplex
1 - 4251-20 Pull Station
2 - 4050 Horns (6V, one 1.8A, the other 2.5A)
1 - 4051 Horn (Paired with the 4050-80)
2 - 2901-9833 Horns (Paired with the 2903 Plates)
1 - 2901-9333 Bell (Paired with the 4903-9101)
1 - 2901-9845 Horn (Paired with the 4903-9105)
1 - 4050-80 Light Plate (-80 = 24V with Single Bulb and No Flasher)
1 - 2903-9001 Light Plate
1 - 2903-9101 Strobe Plate (Both 2903s have those trim rings)
1 - 2904-9101 Remote Strobe (Ceiling Mount)
1 - 4903-9101 Strobe Plate
1 - 4903-9105 Strobe Plate
1 - 4903-9501 Base (Empty 4903 Plate, always good to have a spare)
1 - 4904-9001 Remote Light
1 - 4904-9053 Remote Light (120V, Ceiling Mount)
1 - 4906-9108 Strobe (Amber, “ALERT”, SmartSync)
1 - 49VO-WRF Strobe (Addressable)
1 - 2001 FACP (Several Extra Cards, will not list those at this time)
1 - 4274-5 (Haven’'t figured out what it is for yet. It has one of those 4208 wheels inside, but with only one clip.)
1 - 624-461 Dual Projector
System Sensor
1 - MA-12/24 Horn
1 - MASS121575ADA Horn/Strobe
1 - MASS1215ADA Horn/Strobe
1 - MAEH24M Horn Strobe (Ceiling Mount)
2 - PA400W Mini-Horns
1 - PA400R-PS12LO Mini-Horn/Strobe
1 - P241575 Horn/Strobe (Horn Non-functional)
1 - CHSR Chime/Strobe (No Mounting Plate)
5 - 2WT-B Photoelectric Smoke Detectors
4 - 2WTA-B Photoelectric Smoke Detectors with Sounders
1 - 2100 Photoelectric Smoke Detector
1 - 2100AT Photoelectric Smoke Detector with Sounder
1 - 2400 Photoelectric Smoke Detector
Space Age Electronics
1 - AV-32 Light Plate (Red Lens w/ Flasher)
1 - V-33 Remote Strobe (White Lens)
3 - V-33-TP24D Remote Lamps (White with Red Lenses, Steady Burn)
2 - V-33-TJ24D Remote Strobes (White with Amber Lenses)
2 - V-33-TJ24D Remote Strobes (White with Blue Lenses)
Wheelock
1 - 34-6 Horn (Yes, a 6VDC Horn)
1 - 34T-24 Horn (Formerly a 7002T, but the strobe stopped flashing)
1 - 34T-24-WS Horn/Strobe (The 4 Wire 7002T, but without the skipping)
5 - 7002T-24 Horn/Strobes
1 - 7002T-24 Horn/Strobe (“HALON”)
1 - Model 3300 “Farr-Larm” Horn/Flasher
1 - AS-121575 (Vertical Strobe)
1 - MT-2475W
1 - AMT-12/24
Other
1 - Amseco HP-24 Mini-Horn
1 - Detection Systems DS282TH Photoelectric Smoke Detector
2 - Dictograph Model F Heat Detectors (185F)
1 - Elk-100 Siren Driver
1 - Elk-110 Siren Driver
1 - FCI MS-2 Pull Station
1 - Moose JDS-108 Siren Driver
1 - Rquland-Borg Corp. Model CL4094 Nurse Call/Corridor Lamp (Red, Amber, White, Green)
1 - Whelen Strobe-Alarm
