Legacy Financial Partners Building- Bismarck, ND (Opened in 2025)
Panel: Gamewell-FCI GWF-7075 addressable FACP
Notification Appliances: System Sensor P2WL and SWL horn/strobes and strobes (likely old stock)
Pull Stations: Gamewell-FCI MS-7ASF addressable pull stations (single action BG-12 rebrands)
Detectors: Gamewell-FCI ASD-PL3 addressable smoke detectors
Fleet Farm- Bismarck, ND (Opened in May of 2025)
Panel: For some reason, a hugely overkill Gamewell-FCI E3 panel
Notification Appliances: System Sensor PC2WLED and SCWLED horn/strobes and strobes (my first time seeing LED L-Series devices!)
Detectors: Gamewell-FCI ASD-PL3 addressable smoke detectors and several duct detector variants as well
Annunciator: Gamewell-FCI LCD-E3 in the front entrance vestibule
Riegsecker Craft Barn (Shipshewana, IN)
Detectors:
<ESL 429/449-series smoke detectors throughout the building, hardwired in series
<One Dicon/Ten-Tek smoke detector (with the square test button), presumably replacing an ESL unit
Notification appliances:
<One Star Sprinkler Co. bell on the west exterior of the building (visible in Google Street View)
<One Edwards 6" Adaptabel (painted over with white paint) serving as an emergency exit alarm
Plaid Umbrella Collective (Shipshewana, IN)
Detectors:
<One ESL 429/449-series smoke detector on a support pillar
Davis Mercantile (Shipshewana, IN)
Annunciators/panel:
<Unknown, presumably Silent Knight
Detectors:
<Silent Knight SD505-APS units throughout the building
Pull stations:
<Silent Knight SD500-PS units throughout the building
<White System Sensor SpectrAlert classic horn/strobes and strobes throughout the building
Essenhaus Inn & Conference Center (Middlebury, IN)
Annunciators/panel:
<Siemens FireFinder annunciator in the entrance foyer
<Main panel unknown, but presumably at least one FireFinder XLS-series unit
Detectors:
<Siemens PE-11T(?) units throughout the building
Pull stations:
<Siemens MSI-10B units throughout the building, with at least one unit being an older variant with the Siemens insignia at the top
<Siemens MSI-20B units throughout the building
<Siemens U-MMT horn/strobes throughout the building
<Two Wheelock AS horn/strobes; one replacing a U-MMT inside, and the other a weatherproof version at the main entrance. Both are Siemens rebrands.
Other:
<This inn originally had a Simplex system! This is how I found out:
There were originally 2903-series plates prior to the building getting expanded during the 2000s, with the horns getting replaced by U-MMTs while the plates were left intact throughout! Presumably, there were also 4251-series pulls, 2908-series photoelectric detectors, and as for the panel, I’m guessing it was a 2001, 4001, or 4002.
Minneapolis-St. Paul International Airport - Terminal 1 - Fort Snelling Unorganized Territory, MN
I’ve mentioned this one several times but there’s something new!
Because the Wheelock S8 speaker/strobes were recently discontinued, newly renovated areas have Eluxa speaker/strobes.
Grand View Lodge - Gull Lake Center - Nisswa, MN
Pulls: Silent Knight SD500-PS’
Detectors: SD505-APS’
Signals: Wheelock ZNS horn/strobes
Love’s: DeFuniak Springs, FL
Residential smoke alarm in a bathroom, is this normal?
I originally posted this in the Make up a system thread lol. I just realized my mistake and had to correct it.
Probably not, but then again there should be no smoke detectors in bathrooms to begin with as that’s one of the places that should be avoided (along with kitchens & garages): instead heat detectors should be installed in such a location (& in this case installing a commercial one would allow it to be hooked to the larger fire alarm or security system if one’s in place) Wouldn’t surprise me if the owner of that particular Love’s either cheaped out or simply didn’t know any better with installing that residential detector.
might be used against vaping or smoking though
Maybe, but there are purpose-made vape & tobacco smoke detectors made specifically for such (which might be more evidence that the owner of that Love’s cheaped out on doing things right).
I have a love’s truck stop in my city that opened in 2021, and I found a firex G6 in it!!! If memory serves me right, those were discontinued decades ago.
You’re right: the G-6 & similar models go at least as far back as the 1990s, & I believe they had been discontinued for some years leading up to Kidde’s 2009 purchase of FireX (no idea then how a G-6 ended up in a 2021-built Love’s, unless someone cut corners again (was there any building there prior to the Love’s?).
None of the other love’s locations I went to had them.
Lupe Tortilla: Irving, TX
Been there once. They also have this outside.
That’s a fail. @PhotoElev wouldn’t approve.
Fire Alarms in Natick Mall:
Edwards Genesis G4F Speaker/Strobes (Set on 110CD these are very bright strobes)
Edwards Genesis G4SVWF Replacement Speaker/Strobes
Edwards GCF Speaker/Strobes
Simplex 4906-9153/9154 Speaker/Strobes
EST Genesis GCF-HDVMH Horn/Strobes in Macy’s
Some Space Age VA4s (Some have Space Age A32 reflectors!)
Wheelock Exceeder HSRC Horn/Strobes in Wegman’s (Set on 115CD but possibly higher)
Fort Worth Zoo
Second Rodeo Brewing: Fort Worth, TX
Edwards NAs on a Siemens system huh? That’s odd…(the panel also appears to be a Siemens MXL-IQ, & a rare white cabinet model no less (since normally MXLs in general come in black cabinets)
Meow Wolf: Grapevine, TX
