Feather Hills apartments
Feather Hills apartment is a apartment complex that was formerly a hotel called Silver Hills Hotel. It’s located in the town of Silver Hill which is a very popular tourist destination due to the many lakes, trails and it hosts many events such as the Silver Hills parade and the Silver Hills car show.
Silver Hills hotel was built in 1995 with 2 buildings and a parking garage. The Hotel did very well. The Hotel got some new owners in 2009 and the service was worse and building was neglected. Due to how bad the hotel was mismanaged, the Hotel closed it’s doors in 2013. The Hotel was sold by developers that decided to make the place a apartment complex. The place was repaired and even remodeled in a few places but those were Minor. These apartments has been very successful. A 3rd and 4th building is being planned to be built and are projected to open in Fall of 2025.
The system is service by Simplex and still is by today. This complex is serviced by a small Simplex 4120 Network of 3 panels, 2 Simplex 4020s and a Simplex 4100ES that replaced a Simplex 4020.
Parking garage and basement of building 1 and 2:
Panel:
Simplex 4020 (Node 1)
Simplex 4009 NAC Extenders
Coding:
Continuous
Annunciator:
Simplex 4603-9101
N/As:
Parking garage:
Original devices:
Simplex 4903-9215s
Simplex 4904-9137s
Replacement devices:
Simplex 4903-9252
Wheelock RSS-24MCW-FR
Former Service hall:
Original:
Simplex 4903-9219s
Simplex 4904-9137s
Replacement:
Wheelock AS24MCW-FW (self coded to code 3)
System Sensor P2RL (Code 3, High)
Simplex 4903-9425
Outside:
Gentex WGMS
Pull Stations:
Parking garage:
Original:
Simplex 2099-9795s
Replacement:
Simplex 4099-9003
Simplex 4099-9006
Detectors:
Parking Garage:
Simplex 2098-9478s on MAPNET II bases
Former service corridor:
Original:
Simplex 2098-9201s on MAPNET II bases.
Simplex 2098-9478s on MAPNET II bases.
Replacement:
Simplex 4098-9417s
Notes: this was the first system installed in the complex. Installed before Building 1 and 2 were completed. This place used to have smoke detectors but due to a wild fire season in 1996 that kept setting the system off. The smokes were replaced with heat detectors. The panel is located in a FACP room that also houses building 1’s panel. Building 2’s panel is located below Building 2 also having a FACP room. On the doors of these rooms are labeled where Building 1 and Basement system like this
FACP ROOM
Building 1:
Panel:
Simplex 4020 (1995-2015) (Node 2)
Simplex 4100ES (2015-Present) (Node 2) (platinum cabinet)
Simplex 4009 IDNET NAC extenders
Coding: Continuous
Annunciator:
Simplex 4603-9101
N/As:
Main entrance:
Original:
Simplex 4903-9221s
Simplex 4904-9138s
Replacement:
System Sensor S1224MCW
Hallways:
Original:
Simplex 4903-9221s
Simplex 4904-9138s
Replacements:
System Sensor P1224MCW (Code 3 Horn High)
Wheelock AS-24MCW-FW (Code 3)
Simplex 4903-9431
System Sensor P2R (Code 3 High)
System Sensor P2WL (Code 3, 3K High)
Wheelock HSW
Gentex GEC3-24WW (Code 3 Mechanical)
System Sensor SW
Wheelock RSS
Simplex 4904-9171
Rooms:
Original:
Simplex 4903-9105s (Gentex GX90s, not the strobe plates)
Gentex GXS-4-1575WW
Gentex GEC3-24WW (Code 3 2400hz)
System Sensor P241575W (Continuous 3k)
System Sensor P2R (code 3 high)
System Sensor P2WH-LFs (Code 3)
System Sensor P2WLs (Code 3 3k)
System Sensor P2WL-LFs (code 3)
Simplex 49CMT-WWFIREs (Mixture of code 3 broadband and code 3 520hz)
Gentex GES3-24WWs
System Sensor SR
System Sensor SWs
System Sensor SWLs
Wheelock RSS-24MCW-FWs
Wheelock STW
Simplex 4904-9171s
Stairways:
Simplex 4903-9219s
Former dining hall: (no longer intact)
Simplex 4903-9221s
Simplex 4903-9222s
Simplex 4904-9138s
Lounge: (replaced the dining hall)
Simplex 4906-9130s
Simplex 4906-9104s
Simplex 4906-9129s
Simplex 4906-9103s
Pool:
Simplex 4903-9222Hs
Simplex 4903-9221Hs
Simplex 4904-9138s
Court yard:
Original:
Gentex WGMSs
Wheelock ASWPs
System Sensor P1224MCKs
System Sensor P2RK
Front entrance outside:
Gentex WGMS
Restrooms (non-rooms):
Original:
Simplex 4904-9138s
Replacement:
Pull Stations:
Hallways
Original:
Simplex 2099-9795s
Simplex 4099-9001s
Simplex 4099-9003s
Simplex 4099-9004
Simplex 4099-9006s
Stairway:
Simplex 2099-9795s
Lounge:
Simplex 4099-9006s
Pool:
Simplex 2099-9138s
Courtyard:
Simplex 2099-9138s
Detectors:
Hallways and former dining hall:
Simplex 2098-9201 on MAPNET II Bases
Rooms:
Simplex 4098-9478s on MAPNET II Bases
Pool:
Simplex 2098-9441s
Lounge:
Simplex 4098-9714s
The Simplex 4020 started out reliable but it started to have issues in late 2013. In late 2013 the panel started to bug out and set it self off at random times. The owners at the time were going to replace the entire system. There were plans to replace the system with a FireLite MS-9600UDLS but that never happened since the Hotel went out of business. The developers took note of the 4020 and got it to be replaced with a 4100ES with the devices from the 4020 remaining. The system run normally with the occasional false alarm.
This system was notable for being filmed and uploaded to a video sharing site. It was a bell test of the system. The basement and Building 2 were filmed as well. This was filmed back in 2001 and uploaded in 2006. The inspector revisited this building back in 2015 when the 4100ES was installed and revisited in 2023.
The first video in 2001 was pretty poor quality but it showed the first story of the building.
The 2015 version showed the 5th floor
The 2023 version showed the 1st floor and 2nd floor.
This building was also filmed by a visitor of the hotel in 2013 when the system false alarmed 4 times.
Building 2:
Panel:
Simplex 4020 (Node 3)
Simplex 4009 Nac extenders
Annunciator:
Simplex 4603-9101
Hallways:
Original:
Simplex 4903-9221s
Simplex 4904-9138s
Replacement:
Wheelock ZNS-24MCW-FW (code 3)
Wheelock HSR (code 3)
System Sensor P2WL (code 3 horn)
Simplex 4903-9252
Rooms:
Original:
Simplex 4903-9105s
Gentex GXS4-1575WW
Replacement:
Simplex 49CMTV-WWF
Wheelock RSS
Pull Stations:
Hallways:
Simplex 2099-9795s
Detectors:
Hallways and Rooms:
These systems are plain to say with the exception of the garage due to a expansion. The Simplex 4020 is planning to be replaced there soon. It’s unknown if the 9215s are going to be staying. But the owners of the property have thought about replacing both 4020s with Simplex 4100ES and upgrade the 4120 network to ES net.
