I did some tests of some of the alarms that I’ve had in my collection.
Gentex GXS
Wheelock 7002T
Gentex GMS
Simplex 4901-9822
I will be uploading more alarm test videos in the near future.
Gentex GXS
Wheelock 7002T
Gentex GMS
Simplex 4901-9822
Even more tests…
Wheelock 34T (it’s actually a Wheelock 36T on the label, but it is not much different from a 34T; see video description) - This one tends to act a bit weird with the pitch.
Simplex 2901-9838
Edwards Integrity Horn/Strobe (757-7A-T; Enhanced) - I test it first on continuous because all the Intergities that I’ve heard going off in an actual installation were in Code-3.
Wheelock MT-24-LSM - This is actually my newer one with a working strobe (the strobe on my other one broke due to not taking good care of it). I only tested three out of the eight tones: Code-3 Horn, March Time Horn, and Slow Whoop.
Simplex 4903-9236
http://www.youtube.com/watch?v=e4eq1ed7pS8 Horn/Strobe test
http://www.youtube.com/watch?v=j-DqhWHmlCk Strobe Only Test - I also took my TrueAlert horn/strobe (which I will eventually get to test; see more info in the video) and put it near the strobe just for kicks…
Simplex 4903-9219 - Unfortunately, the strobe stopped working (not due to it being powered by FWR voltage, but probably for not taking good care of it).
http://www.youtube.com/watch?v=x44UpTfqrNY - Also, at the end of the video, I explain (with proof) that I have both versions.
Gentex Commander3 Horn/Strobe - I only tested five out of the seven tones of this alarm
System Sensor MASS2415ADA
http://www.youtube.com/watch?v=32pXbrMKuVA Hi-Lo (800/1000 Alternating) + Surprise
http://www.youtube.com/watch?v=InqPvasAV3k - I test six tones of this alarm since Hi-Lo was posted in the video linked above, and 800Hz was done in http://www.youtube.com/watch?v=BGa-eIyVis0 Mini Test 2.
Siemens U-MMT-MCS
http://www.youtube.com/watch?v=WxaWmr1kdXQ - Part 1; Part 2 will be coming, read the video description as to why I’m making two parts
http://www.youtube.com/watch?v=YjqwdORvcgw - Just a test of the strobe this time
Siemens U-MMT
Part 2 - http://www.youtube.com/watch?v=Vql7HKy_Ks0
Gentex Commander3
In 2400Hz Continuous and Chime Continuous/Pulse - http://www.youtube.com/watch?v=UyMaUo9ViIM
EST Genesis Horn/Strobe
Simplex 4903-9219
http://www.youtube.com/watch?v=0XQ82ztBqFY - This is take #2, but this is with a different -9219.
Wheelock MT-24-LSM
http://www.youtube.com/watch?v=Z-Irp1FXwHI - I do (yet another) test of my Wheelock MT-24-LSM horn/strobe, but the reason why I made this video is because all my other videos demonstrating all the tones of the MT did not have flashing strobe lights going off (Mini Test 5 does not count).
http://www.youtube.com/watch?v=KBc8t_PLUeQ - Another test of my EST Genesis Horn/Strobe. Not only that, but I also walk around my entire house to see how loud it is in other areas of the house.
I haven’t posted anything for at least a month, but I just recently posted a bunch of fire alarm videos on YouTube.
Please note that all videos have a disclaimer that runs for at least 20 seconds, so feel free to skip over the disclaimer.
Strobe-Only Tests
If you see a black rectangle, that’s because I had to edit out a pile of yearbooks that mentioned my school’s name and the town that I live in, due to me not being very careful where I was pointing the camera.
Another test of my SpectrAlert Classic remote strobe, but running on full power (as opposed to just a 9v battery) from my power supply, set to 30cd, along with my Fire-Lite BG-12L.
Another test of my Gentex GXS remote strobe, along with my Notifier NBG-10L
Another strobe-only test of my Integrity Horn/Strobe, along with my newer 270-SPO
Another test of my EST Remote Strobe, set to 30cd, same pull as in the previous video.
Mini-Tests
Mini Test 6; I did a similar setup to what my high school has (when it was initially installed in the 1980s); more info is in the description
Mini Test 7; A test of my Simplex 4903-9219 horn/strobe along with my 2099-9754 T-Bar
Mini Test 8; Same thing as Mini Test 7 except I’ve swapped out the -9219 for the -9236.
Once again, feel free to skip over the disclaimer in these videos.
Mini Test 8.5
The reason I call it that was because it’s almost the same thing as Mini Test 8, except without a strobe.
I was initially going to do this test right after Mini Test 8, but it had the -9838 horn behind the shell at the time, and I had trouble trying to unscrew it from the shell (problem has since been solved).
Mini Test 9
Mini Test 10
Mini Test 11
Mini Test 12
Wheelock MT-24-LSM Strobe Test
Simplex 4903-9236 Strobe Test
The next two tests consist of two different strobe plates (with just their respective strobes going off).
Wheelock RSSP (with my Wheelock MT horn attached)
Simplex 4903-9101 (with my 2901-9838 horn attached, since they were packaged together when they arrived in the mail)
Mini Test 16
A test of my Simplex 4901-9805 Horn
Another fire alarm mod that I did: swapping out the shell from the -9805 and putting the -9838 cover
If you think that I’ve gotten the model number wrong, then http://www.ebay.com/itm/SIMPLEX-4901-9817-SURFACE-MOUNT-FIRE-ALARM-RED-HORN-/320911739816?pt=BI_Security_Fire_Protection&hash=item4ab7d48ba8#ht_3806wt_1397 click here.
A test of one of the rarest alarms ever collected: my Simplex 4903 light plate.
Some of you may believe that it’s a 4903-9001 (myself included), however, from what I can gather from the label on the light plate (which I’ll post a pic of soon) has led me into question.
My 34T wired directly into my RSSP
https://www.youtube.com/watch?v=HjdSgjxNNyA - Please read the description
My Simplex 2901-9838 (different from -9838 that I’ve had for years) on my 4903 Light Plate
Same as before, but swapped out the -9838 for the 34T
Mini Test 20
Simplex 4903-9236 Strobe Test 3
Haven’t posted in long time, but I only have two videos to post for now.
A test of my Edwards Integrity horn/strobe (with only the strobe hooked up) along with my EST Genesis remote strobe.
Another test of my 4903 light plate along with my newly acquired 4251-20 T-Bar.
I know it’s been a long time since I’ve last posted alarm tests here, but here they are:
Mini Test 27
Mini Test 28
Mini Test 29
Simplex 4903-9219 and Wheelock 7002T Test
(I know this kind of setup has been done to death many times)
Simplex 4903-9219 and EST Genesis Test
I still have more videos that I need to post, though.
