New LED System Sensor L-Series
The 4-wire devices will be released in a separate phase.
Where did you hear that? The way I see it there’s no real reason for System Sensor to bother with 4-wire models since 4-wire isn’t really necessary anymore (for fire alarm systems at least).
Friend at System Sensor. Here is a quote from an email conversation: ”The four wire products will be launched separately in a later phase.”
Oh okay. Weird that they wouldn’t launch both those models & the others right away alongside the horn/strobe & remote strobe models though if you ask me.
System Sensor P2RLED L-Series Indoor 2-Wire LED Horn Strobe, Wall-Mount, Marked FIRE, Red (adiglobaldistribution.us)
They are starting to show up… Not in ebay yet, but still.
So, apparently the New LED L-Series doesn’t run on FWR. Looks like Eluxas might be taking over
Wait really? That would be a design flaw if FWR itself wasn’t one already. I wouldn’t put all your money on Eluxas becoming the norm though: just because they can take FWR & the LED L-series supposedly can’t doesn’t mean anything.
I like this move, it hopefully pushes manufacturers to building better supplies for their panels, and to do it right.
Yeah, & not be cheap like Simplex (or rather Hochiki since they make the majority of Simplex’s equipment nowdays) with their current products (in this case they don’t have a capacitor which would protect against FWR, thus causing them to be damaged if powered with that type of current).
Here’s a problem with that. A lot of FireLite panels are FWR (9200, 9200UD, 9200UDLS, MS-2, MS-4, MS-5UD) and all Mircom panels. This is bad for backwards compatibility. Let’s say there a MS-9200UD full of Spectralert Classics, let’s say one of the classics die and you can’t use a LED L-Series because it won’t run on FWR. You would have to replace the entire panel or add a power supply. This is incredibly stupid since there are still MS-9200UDLS out there.
How is simplex cheap, they’re power supplies are really good. The SPS is like indestructible.
True, yes: why System Sensor supposedly didn’t factor in FWR we may never know, but at least that may act as an incentive to panel manufacturers to cut the crap with FWR & make sure their panels output filtered DC, & if anyone happens to notice that the LED L-series can’t take FWR they can always go with another company’s NAs (though they likely won’t as who reads the manual to anything these days?).
For the most part yes, but they apparently got cheap &/or lazy when it came to their devices from the 1990s onward, pretty much all of which like I said lack a capacitor to compensate for FWR (though as I also said that’s pretty much Hochiki’s fault instead since they make Simplex’s devices nowdays).
And who do you think gives the specs for Hochiki to manufacture?
Ah, yeah, Simplex, so I guess it is their fault that their devices are unable to take FWR after all.
Their devices were never designed to take FWR since most their panels output filtered DC
With the exception of the 4001. It’s still stupid that they wouldn’t do what all other NA manufacturers were doing as standard though.
It doesn’t really matter, most simplex devices where installed on simplex panels so they designed their alarms to work on their panels which wait they designed.
That isn’t true and hasn’t been for a very long time.
Simplex makes its products in its own factory in Matamoros, Mexico.
What you’re talking about applies only to the older smoke detectors released before 1998 and doesn’t apply to Simplex’s other products.
What? NewAgeServerAlarm once said though (only some years back too) that Hochiki makes most of Simplex’s products for them now (prior to that Faraday was Simplex’s OEM, at least for some things).
No disrespect, but every simplex product I’ve owned was manufactured in mexico and nothing has referenced hochiki or other locations that are not mexico. Now hochiki did manufacture some smokes but these were older 2098’s I believe, that’s it.
